teamgrumman(at)yahoo.com Guest
Posted: Sun Mar 24, 2013 8:05 pm Post subject: fuel tank |
Finally got the tank sealed on Friday. I spent 6+ hours on a ladder applying fuel tank sealant (OK, minus 30 minutes while the Class B sealant set up a little). All total I put in two 6 oz cartridges of Class B and then two 6 oz cartridges of Class A. From the start at 2p when I started the final cleaning and taping, I spent a total of 10 hours on the wing. Finally went home at 12:30a. By then it was 40 degrees in the tank - with lights.
Resealing wings is way more work than anyone expects.
Years ago, one Grumman owner told me that his mechanic resealed his wing in 3 hours without removing the wing. It leaked of course, so he took it back, twice.
My fingers are crossed.
Gary
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
n2_narcosis(at)yahoo.com Guest
Posted: Sun Mar 24, 2013 9:04 pm Post subject: fuel tank |
Luckily I was my own customer on my own time, scraping, and cleaning, and scraping again and sealing again. I didn't have to remove the wing because I didn't have someone breathing down my neck asking if the plane was finished. So I could sit under the wing in some heinously contorted position an hour or so at a time spread over several weeks. Once I started to hurt because of "bad posture" I would quit for the day and go shoot the shit with some of the old guys that just hang around the airport.
Brock
On Mar 24, 2013, at 11:04 PM, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]Finally got the tank sealed on Friday. I spent 6+ hours on a ladder applying fuel tank sealant (OK, minus 30 minutes while the Class B sealant set up a little). All total I put in two 6 oz cartridges of Class B and then two 6 oz cartridges of Class A. From the start at 2p when I started the final cleaning and taping, I spent a total of 10 hours on the wing. Finally went home at 12:30a. By then it was 40 degrees in the tank - with lights.
Gary
Quote: |
t">http://www.matronics.com/Navigator?TeamGrumman-List
cs.com
matronics.com/contribution
mel(at)becknet.com Guest
Posted: Sun Mar 24, 2013 9:54 pm Post subject: fuel tank |
Wow, what an ordeal! It's always a major pain dealing with sealants at low temps. It costs a fortune to heat a whole hangar, Back in Minnesota we would sometimes tent the work area within the hanger with clear plastic-- the whole plane has to be covered or the airframe will conduct away any heat you bring to bear. It got really smelly inside that tent.
-mel
Gary
Quote: |
href="http://www.matronics.com/Navigator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List
Posted: Sun Mar 24, 2013 10:08 pm Post subject: fuel tank |
I have some 60 watt spiral bulbs in each bay and I taped up the openings. I have a thermometer inside. I'll see what the temp is tomorrow.
Gary
On Mar 24, 2013, at 10:53 PM, Mel Beckman <mel(at)becknet.com (mel(at)becknet.com)> wrote:
[quote]Wow, what an ordeal! It's always a major pain dealing with sealants at low temps. It costs a fortune to heat a whole hangar, Back in Minnesota we would sometimes tent the work area within the hanger with clear plastic-- the whole plane has to be covered or the airframe will conduct away any heat you bring to bear. It got really smelly inside that tent.
-mel
Quote: | Finally got the tank sealed on Friday. I spent 6+ hours on a ladder applying fuel tank sealant (OK, minus 30 minutes while the Class B sealant set up a little). All total I put in two 6 oz cartridges of Class B and then two 6 oz cartridges of Class A. From the start at 2p when I started the final cleaning and taping, I spent a total of 10 hours on the wing. Finally went home at 12:30a. By then it was 40 degrees in the tank - with lights.
Gary
cs.com
george(at)oilhelp.com Guest
Posted: Mon Mar 25, 2013 4:28 am Post subject: fuel tank |
I spent more than 3 hours just cleaning and sealing up the access plates that were leaking on my Traveler a few months ago. His mechanic must be pretty fast if he went in the tank also in just 3 hours, but that is most likely why it wasn't fixed the first time.George DouglasN6080LSent via BlackBerry by AT&T
Sender: owner-teamgrumman-list-server(at)matronics.com
Date: Sun, 24 Mar 2013 21:04:53 -0700 (PDT)
To: Teamgrumman List<teamgrumman-list(at)matronics.com>
ReplyTo: teamgrumman-list(at)matronics.com
Subject: TeamGrumman-List: fuel tank
Finally got the tank sealed= on Friday. I spent 6+ hours on a ladder applying fuel tank sealant (= OK, minus 30 minutes while the Class B sealant set up a little). All = total I put in two 6 oz cartridges of Class B and then two 6 oz cartr= idges of Class A. From the start at 2p when I started the final clean= ing and taping, I spent a total of 10 hours on the wing. Finally went= home at 12:30a. By then it was 40 degrees in the tank - with lights.=
Years ago, one Grumman owner told me that his mechanic resealed = his wing in 3 hours without removing the wing. It leaked of course, s= o he took it back, twice.
Gary
