wschertz(at)comcast.net Guest
Posted: Tue Mar 26, 2013 4:21 am Post subject: Blind riveting ground to airframe? |
Also note that they carry 100 degree flat head with Torx drive, much nicer
for avoiding stripouts like phillips
Bill Schertz
raymondj(at)frontiernet.n Guest
Posted: Tue Mar 26, 2013 4:31 am Post subject: Blind riveting ground to airframe? |
You understood what I was saying correctly. Problem was, what I was saying was INCORRECT. The details of my mea culpa are in an earlier email. Thanks for taking the time to point out my error.
| Quote: | Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine | On 03/26/2013 06:47 AM, Jared Yates wrote:
[quote] | Quote: | --> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com> (email(at)jaredyates.com)
I think I just realized the source of my confusion. When I read "hex head" I visualized the head of an AN bolt. Maybe instead we are talking about socket heads?
On Mar 26, 2013, at 6:41, Werner Schneider <glastar(at)gmx.net> (glastar(at)gmx.net) wrote:
| Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net> (glastar(at)gmx.net)
Ray checkout http://www.microfasteners.com/catalog/products/SSC.cfm
I replaced nearly all of my Phillips with the 6 lobe screws
Cheers Werner
On 25.03.2013 22:21, rayj wrote:
| Quote: | Agreed. I was looking for some "blessed" #10 hex head bolts because I
prefer a hex head over slotted or phillips screw heads.
| [b]
Posted: Tue Mar 26, 2013 4:42 am Post subject: Blind riveting ground to airframe? |
Looks like a great source for fasteners. I wanted to be sure the ones I chose were to an specs. I ended up ordering a big assortment of small AN screws. If I could have gotten an stuff with 6 lobe recess, I would have prefered it. Definitely preferable to Phillips.
Kettle River, MN.
and all I'd have to lose is my point of view." - John Prine | On 03/26/2013 07:20 AM, William Schertz wrote:
[quote]--> AeroElectric-List message posted by: "William Schertz" <wschertz(at)comcast.net> (wschertz(at)comcast.net)
Also note that they carry 100 degree flat head with Torx drive, much nicer for avoiding stripouts like phillips
Bill Schertz
uuccio(at)gmail.com Guest
Posted: Tue Mar 26, 2013 5:58 am Post subject: Blind riveting ground to airframe? |
Does anyone know what the METRIC equivalent of an AN fastener is and where I can buy some? I'm in Italy, so preferably somewhere in Europe, though I'm willing to order from the US if necessary. I've been going nuts (no pun intended) trying to look for some but can only find a few manufacturers, nothing for the retail buyer.
On Mar 26, 2013, at 13:42, rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)> wrote:
[quote] Looks like a great source for fasteners. I wanted to be sure the ones I chose were to an specs. I ended up ordering a big assortment of small AN screws. If I could have gotten an stuff with 6 lobe recess, I would have prefered it. Definitely preferable to Phillips.
Kettle River, MN.
Bill Schertz
jay(at)horriblehyde.com Guest
Posted: Tue Mar 26, 2013 6:25 am Post subject: Blind riveting ground to airframe? |
Hello Sacha,
I have the same problem in South Africa. For non structural parts I simply use Metric sized bolts and nuts; usually stainless steel ones to protect against corrosion. Stainless steel and aluminium have relatively close galvanic potentials as far as I can see. I have given up trying to source, or even understand (!) the imperial nut and bolt thread system; its far easier to walk into a bolt store and ask for M6 x 25mm bolts and M6 nuts. J
For structural parts you must however use AN fasteners and they are not too difficult to understand (unless you need to order a tap or die…) ; I order them directly from Aircraft Spruce in the US.
Johannesburg Jay
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sacha
Sent: 26 March 2013 03:58 PM
Subject: Re: Blind riveting ground to airframe?
| Quote: | | Raymond JulianKettle River, MN. "And you know that I could have me a million more friends,and all I'd have to lose is my point of view." - John Prine |
Bill Schertz
Posted: Tue Mar 26, 2013 7:59 am Post subject: Blind riveting ground to airframe? |
Echo that... It's a shame that our US friends (and hence much of the aviation world) is still stuck using that antiquated system... Metric seems so much more coherent.
Anyway at the moment I'm presented with a situation which requires me to use metric which is why I'm asking the question. I've also been doing what you do (stainless for non structural, AN for the structural parts) but I am now presented with the following dilemma:
For some reason the previous owner has drilled some 8mm holes and appears to have been using 8mm stainless bolts to fasten the wings of the Kitfox I'm rebuilding. The original design calls for 5/16" diameter holes and AN5 bolts. But now I'm reluctant to use them because an AN5 bolt will be a bit loose (5/16" = 7.93mm) in an 8mm hole. On the other hand an M8 regular stainless bolt is not really strong enough.
The best I've found so far is A4-80 a.k.a "strong stainless" which has a shear strength of 800MPa (vs the 700MPa of regular stainless). Plugging in the numbers gives a shear capacity of an M8 bolt as 800*8*8*pi/4= 40kN which is approx 9000 lb. This is still approx 20% below that of an AN5 bolt (11500lb). Hence my search for metric "aircraft grade" fasteners...
Ok sorry for the rant and for straying OT. I thought I would try to use the vast knowledge base if this group since I'm getting nowhere with Google... (just mentioning this in for you Eric...
Sacha
On Mar 26, 2013, at 15:25, "Jay Hyde" <jay(at)horriblehyde.com (jay(at)horriblehyde.com)> wrote:
[quote] <![endif]--> <![endif]-->
Hello Sacha,
Johannesburg Jay
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Sacha
| Quote: | | Raymond JulianKettle River, MN."And you know that I could have me a million more friends,and all I'd have to lose is my point of view." - John Prine |
Bill Schertz
Posted: Tue Mar 26, 2013 8:27 am Post subject: Blind riveting ground to airframe? |
Sacha,
The only suggestions I can think of are possibly sail boat hardware suppliers, or high performance motor sports suppliers.
Good luck on your search.
Kettle River, MN.
and all I'd have to lose is my point of view." - John Prine | On 03/26/2013 10:53 AM, Sacha wrote:
Sacha
Hello Sacha,
Johannesburg Jay
Bill Schertz
gerry.vandyk(at)shaw.ca Guest
Posted: Tue Mar 26, 2013 8:38 am Post subject: Blind riveting ground to airframe? |
Sacha, have a look at Unbrako products. http://unbrako.com/ They're primarily socket head cap screws, both imperial and metric, all with rolled threads and I believe they're the highest quality fasteners for industrial use. You can download they're engineering guide to research how they compare to AN for strength and ductility, hopefully they're up to par on corrosion resistance as well. They're European base is in Ireland, I imagine their products should be available at industrial suppliers.
Gerry
Sent: Tuesday, March 26, 2013 9:53:55 AM
Sacha
Hello Sacha,
Johannesburg Jay
Bill Schertz
rlborger(at)mac.com Guest
Posted: Tue Mar 26, 2013 8:57 am Post subject: Blind riveting ground to airframe? |
Sacha,
Normally, I'd suggest that you simply go up one size to AN6 hardware. Cost a tiny bit in weight but is easy to do and the hardware is readily available through Spruce and other suppliers.
If you feel you must stay with metric hardware, you can try McMaster-Carr ( mcmaster.com ) for high-strength steel metric bolts. They have class 10.9 bolts with a structural rating of 150,000 psi or greater. They are even available partially threaded with a Zinc-Chromate finish just like good AN hardware. Go to their web site, select fasteners then select screws. Next, from the left hand column you can select metric and the size, M8.
You will have to decide if these are strong enough to meet your needs.
Good luck.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Mar 26, 2013, at 10:53 AM, Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)> wrote:
Sacha
LynnCole(at)foxvalley.net Guest
Posted: Tue Mar 26, 2013 9:05 am Post subject: Blind riveting ground to airframe? |
Sacha,The approved method for using ANx bolts for critical items like wing and strut or horizontal stab attachments is to drill the holes undersized and use an adjustable reamer to ream the holes to a tight fit for the bolts. The reamed hole will be undersized by 0.001-0.003 inches compared to the nominal size of the bolt.
Lynn Cole
LynnCole(at)foxvalley.net (LynnCole(at)foxvalley.net)
Sacha
Hello Sacha,
Johannesburg Jay
Bill Schertz
bob.verwey(at)gmail.com Guest
Posted: Tue Mar 26, 2013 10:30 am Post subject: Blind riveting ground to airframe? |
Robert, agree with you. Lets not loose sight of the fact that an AN bolt has "grip" and a relatively short thread. This is by far the most convenient feature, because with other fasteners you will end up cutting off excess thread, and you will have to go and measure for yourself what the grip is. Hardware is a fraction of the weight or cost of the project. Straying from aircraft hardware will cost you lots of time.
Also, aircraft bolts are "tough", and will bend long before they break. And they are corrosion protected with no danger of hydrogen embrittlement, and ....the list goes on.....
Bob Verwey
Bonanza ZU-DLW
Safari ZU-AJF
On 26 March 2013 18:57, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
[quote]Sacha,
Good luck.
Bob Borger
Europa XS Tri, Rotax 914, AirmasterC/S Prop.
Little Toot Sport Biplane, LycomingThunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Cel: [url=tel:817-992-1117]817-992-1117[/url]
Sacha
tp://forums.matronics.com
rv8iator(at)gmail.com Guest
Posted: Tue Mar 26, 2013 11:41 am Post subject: Blind riveting ground to airframe? |
Hello Sacha...
The quick answer is there are no AN metric fasteners... The US military never adopted the metric system so all are US ANSI standard sizes. That said acceptable metric equivalents can be found.
Stainless Steel
Stainless steel is a family of iron-based alloys that must contain at least 10.5% chromium. The presence of
chromium creates an invisible surface film that resists oxidation and makes the material “passive” or
corrosion resistant. Other elements, such as nickel or molybdenum are added to increase corrosion
resistance, strength or heat resistance.
Stainless steels can be simply and logically divided into three classes on the basis of their microstructure;
austenitic, martensitic or ferritic. Each of these classes has specific properties and basic grade or “type.”
Also, further alloy modifications can be made to alter the chemical composition to meet the needs of
different corrosion conditions, temperature ranges, strength requirements, or to improve weldability,
machinability, work hardening and formability.
Austenitic stainless steels contain higher amounts of chromium and nickel than the other types. They are
not hardenable by heat treatment and offer a high degree of corrosion resistance. Primarily, they are nonmagnetic;
however, some parts may become slightly magnetic after cold working. The tensile strength of
austenitic stainless steel varies from 75,000 to 105,000 psi.
18-8 Stainless steel is a type of austenitic stainless steel that contains approximately 18% chromium and
8% nickel. Grades of stainless steel in the 18-8 series include, but not limited to; 302, 303, 304 and XM7.
Alloy Steels
Carbon steel can be classified as an alloy steel when the manganese content exceeds 1.65%, when silicon
or copper exceeds 0.60% or when chromium is less then 4%. Carbon steel can also be classified as an
alloy if a specified minimum content of aluminum, titanium, vanadium, nickel or any other element has
been added to achieve specific results. Additions of chromium, nickel and molybdenum improve the
capacity of the alloys to be heat treated, giving rise to a wide variety of strength to ductility combinations.
SAE J429 Grade 8, ASTM A354 Grade BD, ASTM A490, ASTM A193 B7 are all common examples of
alloy steel fasteners.
ASTM A193 B7
• Tensile Strength: 125,000 PSI minimum (2-1/2-inch and under)
• Yield Strength: 105,000 PSI minimum (2-1/2-inch and under)
• Hardness: HRC 35 Maximum
SAE J429 Grade 8
• Tensile Strength: 150,000 PSI minimum
• Proof Strength: 120,000 PSI
• Yield Strength: 130,000 PSI minimum
• Hardness: HRC 33-39
ASTM A574 Socket Head Cap Screw
• Tensile Strength: 180,000 PSI minimum (through ½”), 170,000 PSI minimum (above ½”)
• Proof Strength: 140,000 PSI (through ½”), 135,000 PSI (above ½”)
• Yield Strength: 153,000 PSI minimum
• Hardness: HRC 39-45 (through ½”), HRC 37-45 (above ½”)
Metric Grade 8 hardware:
http://metric-threaded.com/items.aspx?category=Inch%20Hex%20Head%20Bolt%20Grade%208%20Zinc%20Yellow&id=7306
Chris Stone
RV-8
Newberg, OR
On Tue, Mar 26, 2013 at 8:53 AM, Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)> wrote:
Sacha
Hello Sacha,
Johannesburg Jay
| Quote: | Raymond JulianKettle River, MN.
Bill Schertz
peter(at)sportingaero.com Guest
Posted: Tue Mar 26, 2013 12:04 pm Post subject: Blind riveting ground to airframe? |
Sacha,
There is no metric equivalent to AN fasteners, different manufacturers seem to use different standards of hardware. Find your local Piper or Cessna supply house - or the mechanic at your local airfield - as they will surely have a good supply of AN hardware. In the UK LAS Aerospace have a good supply, but shipping is expensive to continental Europe. Alternatively you could try A/C Spruce as they have a reasonable network of suppliers throughout Europe.
Peter
On 26/03/2013 13:57, Sacha wrote:
[quote] Does anyone know what the METRIC equivalent of an AN fastener is and where I can buy some? I'm in Italy, so preferably somewhere in Europe, though I'm willing to order from the US if necessary. I've been going nuts (no pun intended) trying to look for some but can only find a few manufacturers, nothing for the retail buyer.
Kettle River, MN.
Bill Schertz
Posted: Tue Mar 26, 2013 2:55 pm Post subject: Blind riveting ground to airframe? |
All,
Thank you very much for all the excellent avenues to explore re metric hardware, I learnt a lot in just one evening!
I am leaning towards the solution involving the next AN size up (AN6 bolts, but will have to check whether the fittings will allow it), and will try to do it as per Lynn's instructions.
Sacha
Bob McC
Posted: Tue Mar 26, 2013 7:06 pm Post subject: Blind riveting ground to airframe? |
Sacha;
The “proper” solution to your dilemma is to ream the holes to accept AN-6 hardware of the correct length and not substitute alternative materials of unknown provenance in this critical application. The only remaining proviso is to check edge distances etc carefully for adequate strength. It’s unlikely that the difference between -5 and -6 hardware will compromise the structural integrity of the mount especially since your holes are already 8mm. Your new larger holes will only be about 30 thousandths of an inch closer to the edge. Not enough to make much difference, but still critical to check.
Good luck
Bob McC
Sent: Tuesday, March 26, 2013 11:54 AM
Subject: Re: AeroElectric-List: Blind riveting ground to airframe?
Sacha
Hello Sacha,
Johannesburg Jay
Bill Schertz
_________________ Bob McC
Falco #908
(just starting) |
bicyclop(at)pacbell.net Guest
Posted: Tue Mar 26, 2013 8:36 pm Post subject: Blind riveting ground to airframe? |
Stainless and aluminum don't play nice together. The aluminum will donate ions and corrode. Cad plated steel is the AN way. The cadmium is more anodic than the aluminum and acts as a sacrificial barrier. Eventually, it has no more ions to donate and loses it's value as a corrosion preventative. Time then for new hardware. Another approach would be to prime your hardware and install it wet.
Ed Holyoke
On 3/26/2013 7:25 AM, Jay Hyde wrote: [quote] <![endif]--> <![endif]-->
Hello Sacha,
Johannesburg Jay
Bill Schertz
fvalarm(at)rapidnet.net Guest
Posted: Wed Mar 27, 2013 10:19 pm Post subject: Blind riveting ground to airframe? |
How does the the stainless firewall riveted with aluminum rivets to aluminum sheet and angle stock play nice together?
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Holyoke
Sent: Tuesday, March 26, 2013 9:35 PM
Ed Holyoke
On 3/26/2013 7:25 AM, Jay Hyde wrote: | Quote: | (at)font-face { font-family: Wingdings; } (at)font-face { font-family: Cambria Math; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: Tahoma; } (at)font-face { font-family: Consolas; } (at)font-face { font-family: 3DȬourier; } (at)page WordSection1 {size: 612.0pt 792.0pt; margin: 72.0pt 72.0pt 72.0pt 72.0pt; } P.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } LI.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } DIV.MsoNormal { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } PRE { MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New"; FONT-SIZE: 10pt; mso-style-priority: 99; mso-style-link: "HTML Preformatted Char" } SPAN.HTMLPreformattedChar { FONT-FAMILY: Consolas; mso-style-priority: 99; mso-style-link: "HTML Preformatted"; mso-style-name: "HTML Preformatted Char" } SPAN.EmailStyle19 { FONT-FAMILY: "Calibri","sans-serif"; COLOR: #1f497d; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.WordSection1 { page: WordSection1 } OL { MARGIN-BOTTOM: 0cm } UL { MARGIN-BOTTOM: 0cm } <![endif]--> <![endif]-->
Hello Sacha,
Johannesburg Jay
Bill Schertz
-----Original Message----- From: Werner Schneider
Sent: Tuesday, March 26, 2013 5:41 AM
Cheers Werner
Kettle River, MN. | 01234567890123456789 | Quote: | | "And you know that I could have me a million more friends, | 0 | Quote: | | "And you know that I could have me a million more friends, | 1
| Quote: | | "And you know that I could have me a million more friends, | 2"And you know that I could have me a million more friends, | 3 [quote][b]
Posted: Thu Mar 28, 2013 6:09 am Post subject: Blind riveting ground to airframe? |
At 01:16 AM 3/28/2013, you wrote:
| Quote: | How does the the stainless firewall riveted with aluminum rivets to aluminum sheet and angle stock play nice together?
Bevan
I seem to recall some conversations many Many MANY moons
back about monel rivets used on firewall assemblies. Wasn't
my area of interest at the time. It would be interesting to
dig out a Cessna Service Parts catalog of the 1960's and see
what attaching parts are called out for oowl attach brackets.
Bob . . . [quote][b]
dee.whittington(at)gmail. Guest
Posted: Thu Mar 28, 2013 8:49 am Post subject: Blind riveting ground to airframe? |
Yes, Bob, that is the answer. Our Sportsman kit came with a supply of Monel rivets for the thin, stainless firewall.
Dee
On Thu, Mar 28, 2013 at 10:07 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Bevan
Bob . . . | Quote: |
DeWitt (Dee) Whittington804-677-4849 iPhone
804-358-4333 Home
www.VirginiaFlyIn.org
Building Glasair Sportsman with 3 partners
Posted: Thu Mar 28, 2013 9:03 am Post subject: Blind riveting ground to airframe? |
At 11:47 AM 3/28/2013, you wrote:
| Quote: | Yes, Bob, that is the answer. Our Sportsman kit came with a supply
Dee
I think it was in the booth at OSH that
an EAA'er said they were "harder than the
hubs of hell", was that you?
