n8vim(at)arrl.net Guest
Posted: Sat Mar 30, 2013 7:38 am Post subject: F-1013 Twist: R but not L ? |
Hi all,
I'm on section 29-3, Step 3: "Clamp the F-1013-R Fwd Fuse Longeron
in a padded vise at the "forward twist mark". Twist the fwd fuse
longeron with a crescent wrench as shown in Figure 2 to obtain the
dimension shown in Figure 3. Clamp the fwd fuse longeron at the "aft
twist mark". Repeat the process using the twist direction shown in
Figure 1 to obtain the dimension shown in Figure 3."
So they say to twist the forward and aft parts of the right longeron,
but what about the forward part of the LEFT longeron? (The aft twist
does not apply to the left longeron, since the dimension shown won't
allow it.)
I can't see any difference in symmetry in the forward sections of either
L or R F-1013 longerons. Is it the plans missing it, or are you really
not supposed to twist the forward part F-1013 left longeron?
Thanks for your time!
-Jim #40384
charliewaffles
Posted: Sat Mar 30, 2013 4:19 pm Post subject: Re: F-1013 Twist: R but not L ? |
You twist both front ends the same way, as shown in Figure 2. You are essentially twisting the longeron UP so that it transitions to the firewall weldaments later on.
Posted: Sat Mar 30, 2013 5:14 pm Post subject: F-1013 Twist: R but not L ? |
That was my first thought as well, but if you read the whole page
carefully, it never says to twist the left F-1013.
Although it wouldn't be the first omission I've seen so far (the most
recent was the roll construction angles - it doesn't say what thickness
material to use!).
-Jim 40384
Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Sat Mar 30, 2013 6:32 pm Post subject: F-1013 Twist: R but not L ? |
You will find many places they give drawing/instructions for one side
and tell you to mirror image the other side, if they mention it at all.
thickness material to use!).
-Jim 40384
> http://forums.matronics.com/viewtopic.php?p=397362#397362
Checked by AVG - www.avg.com
KCHD |
