Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Thu May 16, 2013 2:30 pm Post subject: Garmin Skymap 111C |
Hello All.
My Skymap 111c is working on Menu and Maps, but states , No position fix,
go to GPS, page it is not picking up any satellites,??
Power, and Aerial all plugged in the back of the unit,
See the aerial wire going behind the panel, then lost.
What does this GPS aerial look like.??
Alan
Ivor Phillips
Posted: Sun May 19, 2013 11:40 pm Post subject: Garmin Skymap 111C |
Hi Alan
the normal ariel is a plastic sqaure box about the size of a cigarette box, but on mine
i fitted a slightly smaller unit with a built in amplifier,
http://www.ebay.co.uk/itm/SMA-RP-SMA-GPS-Antenna-3-meter-3m-3-0m-Cable-BRAND-NEW-FULL-WARRANTY-/321117484231?pt=UK_In_Car_Technology&hash=item4ac417f4c7#ht_2099wt_1132
one of these from ebay is a cheap way to check if it is a ariel problem or not,
regards
ivor
On 16 May 2013 23:30, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
[quote]--> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hello All.
Alan
http://forums.matronics.com/viewtopic.php?p=400810#400810
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
Alan Carter
Posted: Mon May 20, 2013 10:05 am Post subject: Re: Garmin Skymap 111C |
Hello Ivor./Bob.
Hope you are still doing those long flight,
I have spoken the sky force at Chichester today, they are sending me out a
stick on cheap aerial to test with.
Its all working but states on the GPS page acquiring but this stay the same for an hour, so its no receiving a signal, on the aerial state it says 4Ma.
Regards.
Alan
Alan Carter
Posted: Wed May 22, 2013 1:54 pm Post subject: Re: Garmin Skymap 111C |
Hi All.
Sky Force sent me an aerial, plug it in and all was working again, so that
is the problem. just go to find the other end of my old cable,??
Alan [/code]
stranfaer(at)btinternet.c Guest
Posted: Wed May 22, 2013 2:02 pm Post subject: Garmin Skymap 111C |
Alan I think I have a spare skyforce Ariel and wire with plug on if you want to renew?
rgds
David
Sent to you from David Joyce
www.eastmidsspas.com
Sent: Wednesday, 22 May 2013, 22:54
Subject: Re: Garmin Skymap 111C
Hi All.
Alan [/code]
http://forums.matronics.com/viewtopic.php?p=401136#401========================http://www.matronics.com/Navigator?Eurp; --> [quote][b]
Alan Carter
Posted: Wed May 22, 2013 2:18 pm Post subject: Re: Garmin Skymap 111C |
Hi David.
The aerial Sky force sent me was a small black box about 2.5"x2" internally mounted on the top of the instrument panel.
Thanks will let you know if i need one.
I would like to find just where my wire goes to.?
Alan.
Don,t happen to have a spare trigger coil.
