		Kellym
				 Posted: Mon May 27, 2013 4:00 pm    Post subject: how can I find out the gear reduction for the governor  driv |
				The only thing that determines what gear reduction you need is whether
 you have a narrow deck version or a wide deck. Which one you have
 depends on the core used to build the engine, not who assembled it.
 You can easily tell by the cylinder hold down bolts. Narrow deck have
 hollow allen key bolts. Wide deck has conventional hex nuts on studs.
 The governor Van's sells has reduction for narrow deck. (despite the
 fact that all new engines Vans sells are wide deck). While adjustments
 can be made to make the Vans governor work on a wide deck, it still
 won't be correct. Jim Ayers has often posted here the correct
 information. A wide deck engine is supposed to get a P-860-5 MT governor.
 More detail on the differences at
 http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/
 On 5/27/2013 3:51 PM, Mike Whisky wrote:
  I own an TMXIO-540 and wonder what the governor reduction drive is, I don`t have my engine documentation currently with me. Does anyone know who has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT governor is really the correct one.
  Mike
  RV-10 builder (final assembly)
  #511
  http://forums.matronics.com/viewtopic.php?p=401444#401444
 Checked by AVG - www.avg.com
KCHD |
				 Posted: Tue May 28, 2013 5:06 am    Post subject: how can I find out the gear reduction for the governor  driv |
				All TMX engines should be wide deck.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 C: 352-427-0285
 F: 815-377-3694
 On May 27, 2013, at 7:59 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
  The only thing that determines what gear reduction you need is whether you have a narrow deck version or a wide deck. Which one you have depends on the core used to build the engine, not who assembled it.
  You can easily tell by the cylinder hold down bolts. Narrow deck have hollow allen key bolts. Wide deck has conventional hex nuts on studs.
  The governor Van's sells has reduction for narrow deck. (despite the fact that all new engines Vans sells are wide deck). While adjustments can be made to make the Vans governor work on a wide deck, it still won't be correct. Jim Ayers has often posted here the correct information. A wide deck engine is supposed to get a P-860-5 MT governor.
  More detail on the differences at http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/
 > Thanks
 > Mike
 > #511
		flying-nut(at)cfl.rr.com Guest
				 Posted: Tue May 28, 2013 8:22 am    Post subject: how can I find out the gear reduction for the governor  driv |
				I'm not Kelly .... nor do I play him on       TV .... but there's a big misconception about WD/ND engines.        There's a good treatise here:
        http://tinyurl.com/qjk83xk
          Linn
        On 5/28/2013 11:47 AM, John Cox wrote:
      [quote]       Kelly, if I read your post correctly, all of the         new Lycoming engines sold by VANS of the IO-540 variant are now         only Wide Deck and not Narrow Deck.  Aren't each of the wide         deck jugs heavier and too wide to fit the stock RV-10 fiberglass         cowl design?  Or is that just for the Angle Valve Heads versus         Parallel Valve?
          John C.
          On Tue, May 28, 2013 at 7:19 AM, Kelly           McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>           wrote:
             	  | Quote: | 	 		               Assuming that they are built from new parts               kits or WD cores. It didn't occur to me that anyone would               still have an engine built from new parts kit, since Lyc               priced those out of the market about 18 months ago. As has               been noted before, if one has a wide deck engine, then the               MT P-860-5 governor is the correct unit of that brand. It               is unfortunate that Van's still only supplies the narrow               deck P-860-3 governor, when they have never sold a new               narrow deck engine. (Lyc stopped making narrow deck more               than 10 yrs before Van founded his company).
                On Tue, May 28, 2013 at 6:06 AM,                 Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>                 wrote:
                   	  | Quote: | 	 		  -->                   RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
                        Jesse Saint
                        C: [url=tel:352-427-0285]352-427-0285[/url]
                        F: [url=tel:815-377-3694]815-377-3694[/url]
                        On May 27, 2013, at 7:59 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>                       wrote:
                        > --> RV10-List message posted by: Kelly                       McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
                        >> --> RV10-List message posted by: "Mike                       Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
                        >> Thanks
                        >> Mike
                        >> #511
                        > No virus found in this message.
                        le, List Admin.
                - sent from the microchip implanted in my forearm
          05/28/13     [b]
		Kellym
				 Posted: Tue May 28, 2013 12:15 pm    Post subject: how can I find out the gear reduction for the governor  driv |
				It is more fun when the lovely Miss Rhonda shows John the errors in his
 thinking.  )
 I don't think there is more than about 1/4" difference between wide and
 narrow deck engines. Narrow deck allegedly is about 4 lbs lighter, but
 the newest ND case is likely to be approaching 40 yrs old.
 Kelly
 On 5/28/2013 9:05 AM, BPA wrote:
  John,
  That’s just for the angle head cylinders. Both narrow deck and wide
  deck engines fit the RV-10 cowl.
  Allen
KCHD |
		jkreidler
  Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
				 Posted: Wed May 29, 2013 7:50 am    Post subject: Re: how can I find out the gear reduction for the governor |
				I understand you can make the MT governor sold by Van's work by changing the arm position and making a few adjustments as that is what we did.  But can someone tell me what the operational impact is of having the incorrect one installed?  Slower reaction, incorrect pitch for a given power, pitch changes too quickly, etc.?  Just because it works doesn't mean it is right, just trying to understand what trade off is being made.  -Jason
  _________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
		lessdragprod(at)aol.com Guest
				 Posted: Thu May 30, 2013 8:27 am    Post subject: how can I find out the gear reduction for the governor  driv |
				The -3 and -5 governors are identical, except for the final adjustments.
 For the -3 governor on the wide deck IO-540 engine, the high RPM stop screw has to be turned out quite a bit to get to 2700 RPM from the factory setting of about 2550 RPM.  (For the narrow deck IO-540 engine, the initial stop setting on the -3 governor would be at about 2700 RPM.)
  The -3 governor on a wide deck IO-540 now has a longer travel to get to the low RPM stop.  The governor arm should have full travel from the high RPM stop to the low RPM stop.
 Perhaps someone already flying can say if they have full travel (stop to stop) available with Van's governor cable.
 Full governor arm travel is helpful to have for the mag check so it is possible to get the expected 450 RPM drop when the governor/propeller is cycled
		Mike Whisky
				 Posted: Sun Jun 02, 2013 2:35 am    Post subject: Re: how can I find out the gear reduction for the governor |
				Thanks everyone for your input. I'll report the adjustments I had to do in order to reach the low an high RPMs.
 Mike
  _________________ RV-10 builder (flying)
#511 |
