sidsel.svein(at)oslo.onli Guest
Posted: Sat Jun 22, 2013 7:31 am Post subject: SV: Routing to and from Duxford |
Thank you very much, David W. and David J., for the good info from both of
you.
David J.: As we are most probably approaching DVR from Holland through
Belgian and French airspace - yes, the Belgian permit is obtained and paid
for - on a VFR flight plan, we would prefer to be in contact with the
appropriate ATC (basic service) also on our way up to Duxford, passing the
points that you mention, but in the reverse order. Keeping a steady track
that at no point indicates that we intend to cut a corner through Stansted
TMZ, I assume that we just remain on the ATC frequency and with whatever
squawk they give us along the way?
Svein
Posted: Sat Jun 22, 2013 10:01 am Post subject: SV: Routing to and from Duxford |
Svein, In the vicinity you tune into Stansted on 120.625
and squawk 0013 WITHOUT talking to them, and with mode C
(or S if you have it). If they think you are too close or
are heading into their space they may radio 'plane
overhead XXX contact us on frequency YYY.' It is a system
quite widespread in the UK called Listening Squawks, you
do not need to talk to them at all, but they can contact
you if they think you are heading into trouble. If you
want to actually talk to someone then you can talk to
London Info anywhere in UK and they will give you local
QNH or weather at your destination if you ask them. I will
copy the CAA leaflet on Listening Squawks to you and
include it on the Europa website.
Regards, David Joyce, G-XSDJ
On Sat, 22 Jun 2013 17:30:40 +0200
"Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
wrote:
info from both of
you.
Holland through
obtained and paid
contact with the
and with whatever
Svein
Un/Subscription,
Forums!
Admin.
