kheindl(at)msn.com Guest
Posted: Sun Jun 23, 2013 4:36 am Post subject: tank vent and drain taps |
Having recently re-arranged/replaced all fuel lines, vent lines and sight tube I am still at odds with two items:
1. What exactly is the reason again for having the tank vent in the airstream instead of a static position? Are we doing this because everybody else has always been doing it or is there a real safety aspect ? I have been given six reasons, but none of them make sense to me and there is no proof. A static vent can handle any air flow in and out of the tank. I don't see the need for pressurization, especially since this must be miniscule, in a pump driven system. Maybe in a gravity fed fuel system it might make sense, or where there are two fuel tanks. Some of you have moved the vent to the bottom of the fuselage, where it could easily be clogged by mud or insects. It has happened twice to my pitot tube.
2. Why has no PFA/LAA or other inspector ever pointed out the fact that the drain tap arrangement is completely useless ? There would have to be an awful lot of water in the tank before any of it would show up in a drain cup.
But it could get to the engine in a steep descent. The obvious reason is the high point of the fuel exits and the high barb fitting on the taps themselves. This would be especially so in a mono. The only sensible installation would be flush fitting taps in the tank itself. I am tempted to remove that plumbing and use the tap on my mini-gascolator .
Karl
Posted: Sun Jun 23, 2013 5:48 am Post subject: tank vent and drain taps |
On 06/23/2013 02:36 PM, Karl Heindl wrote:
| Quote: | 1. What exactly is the reason again for having the tank vent in the
I think it is the first. Especially when you have the tank vent
connected to the cobra, there is no risk of sucking the fuel out of the
tank even if there would be a negative pressure.
| Quote: | I don't see the need for pressurization, especially since this
In our soft tanks pressurization is even harmfull. It may cause the tank
to jam the aileron control, or abrasion of the tank when it repeatedly
expands, or other bad things. Best thing would be a neutral or slightly
negative pressure (the latter helping to keep fuel fumes out of the
cockpit). Like you said, we don't have gravity fuel feed like Cessna's
but we are dependant on a fuel pump anyway.
| Quote: | 2. Why has no PFA/LAA or other inspector ever pointed out the fact that
drain cup.
I never got any drop of water out of these drains, and have never heard
of anyone else who got any water out of it.
(If anyone has, I would like to hear about it, and also whether this
water showed up in the gascolator as well).
Instead, I think the drains and associated plumbing are increasing the
risk of leaks, and are a hazard during an accident: if the gear is
ripped off the next thing to contact the ground and be ripped off are
the fuel drains, and together with the unavoidable sparks this will for
sure trigger a fire. And the drains can not be closed with the fuel
valve so there is nothing you can do about it.
The next time I will have maintenance on the fuel plumbing I will take
the drains out. It is just a matter of judging the safety advantages
against the safety disadvantages, and to my judgement the latter puts
more weight in the equation here.
The only things I found them useful for is for draining the entire tank
for maintenance and inspection (I have valves that can be locked in the
open position) and to fill the bottle of my camp stove. But all this can
also be accomplished by other methods.
Avoiding water in the tank can also be accomplished by refueling after
each flight so there is only little air left in the tank. Having said
that, I was surprised after the winter stop in an unheated barn with
only a little fuel in the tanks that despite all the temperature cycles
(and associated "breathing" of the tank) and our wet climate that no
water at all condensed in the tank, not a single drop!
Also, how is this arranged with cars? I have never seen a car with a
fuel drain, but yet water in the fuel seems to be unheard off (obvious
causes of forgetting to put the cap on the tank not counting). What's
the story here?
| Quote: | The obvious reason is
themselves.
I have copper tubes inside the tank running to a position lower than the
fuel outlet for the engine. So in theory it could work.
Frans
Posted: Sun Jun 23, 2013 3:00 pm Post subject: tank vent and drain taps |
Hi! Franz/all.
I can confirm that Once in particular when parked overnight at ZelamZee in a
particularly violent down pour I emptied about half a litre of water from
one of my water drain taps .
Since then I have tried to ensure that the whole tank filler cap is blanked
off by tape especially the lock.
I do have a mop out access hole in the tank top and most winter grounding
periods I drain out and mop out to ensure both tanks are started with a
clean charge of fuel. I have also occasionally had small amounts of water
show depending on the level parking of the aircraft too.
Bob Harrison G-PTAG
Posted: Mon Jun 24, 2013 1:48 am Post subject: tank vent and drain taps |
On 06/24/2013 12:59 AM, Bob Harrison wrote:
Hi! Franz/all.
Ok but in your case it seems that the water is due to rain water
invasion via the fuel cap.
I'm more concerned about water condensation in the tank, but as fas as
my experience goes in our rather wet climate, this doesn't seem to be a
problem in the Europa.
Frans
Posted: Mon Jun 24, 2013 5:54 am Post subject: tank vent and drain taps |
Yes Frans, that is as near correct as can be. I'm confident that my two mini
gascolators would cater for condensation ...no problem.
Bob Harrison.
