		jeff(at)westcottpress.com Guest
				 Posted: Mon Jul 08, 2013 11:51 am    Post subject: Safety Wire for Plane-Power Alternator Installation |
				Does anyone have pics of their safety wiring the tension arm bolts? The distance between them seems a bit much to tie one to the other.
 Jeff Carpenter
 40304
		kdbelue(at)charter.net Guest
				 Posted: Mon Jul 08, 2013 11:55 am    Post subject: Safety Wire for Plane-Power Alternator Installation |
				Safety wire the bolt to the arm....
 On Jul 8, 2013, at 2:51 PM, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
  Jeff Carpenter
  40304
		tsts4
				 Posted: Mon Jul 08, 2013 1:50 pm    Post subject: Re: Safety Wire for Plane-Power Alternator Installation |
				Ran into the same issue a few months back.  Just drill some small holes into the tension arm and run the safety wire from the bolt to the hole and tie it off.
  _________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
		Kelly McMullen
				 Posted: Mon Jul 08, 2013 7:25 pm    Post subject: Safety Wire for Plane-Power Alternator Installation |
				While it may be "okay" to drill a hole, there is no need to. You can easily safety directly to the arm. That is done all the time on certified aircraft.
  On Mon, Jul 8, 2013 at 2:50 PM, tsts4 <tsts4(at)verizon.net (tsts4(at)verizon.net)> wrote:
  	  | Quote: | 	 		   --> RV10-List message posted by: "tsts4" <tsts4(at)verizon.net (tsts4(at)verizon.net)>
  Todd Stovall
  aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace
  RV-10 N728TT
  Empacone, Wings, Fuse, Finishing
  www.mykitlog.com/auburntsts
  http://forums.matronics.com/viewtopic.php?p=404239#404239
  le, List Admin.
  - sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
		dhmoose
				 Posted: Sun Jul 14, 2013 7:46 am    Post subject: Re: Safety Wire for Plane-Power Alternator Installation |
				I re-read AC43.13 and didn't find any mention of a limit to the length of safety wire that can be used. I simply brought the wire from bolt to bolt in a typical arrangement and the span looks to be about 3". Is this a problem? Seems ok to me.
  _________________ David Halmos
RV-10
Flying!
Portland, OR |
				 Posted: Sun Jul 14, 2013 7:57 am    Post subject: Safety Wire for Plane-Power Alternator Installation |
				There's no doubt that shorter is better.  The longer the span the
 'potential' for loosening becomes greater.
 So, ask yourself what the consequences of that (those) particular
 fasteners loosening a little.
 This could be an 'experiment' so get back to us ......
 IMHO, of course.
 Linn
 On 7/14/2013 11:46 AM, dhmoose wrote:
  David Halmos
  RV-10
  Electrical/avionics
  Portland, OR
  http://forums.matronics.com/viewtopic.php?p=404667#404667
  Checked by AVG - www.avg.com
		dhmoose
				 Posted: Sun Jul 14, 2013 8:38 am    Post subject: Re: Safety Wire for Plane-Power Alternator Installation |
				I suspect, in my experiment, I'll get a "backup alternator" light illumination on my panel. I'll then fly on or land...and adjust the belt tension when back on the ground. I'll then recall this thread, enjoy a good chuckle... and press on.
 Or... I'll re-safety it now prior to first flight.  Haha.
  	  | flying-nut(at)cfl.rr.com wrote: | 	 		  There's no doubt that shorter is better.  The longer the span the
 IMHO, of course.
 Linn
  David Halmos
  RV-10
  Electrical/avionics
  Portland, OR
RV-10
Flying!
Portland, OR |
