tim2542(at)sbcglobal.net Guest
Posted: Wed Jul 24, 2013 2:25 pm Post subject: Adhesive |
I have a little DC-DC converter(pc board & components) robbed out of a Cig adapter that Im relocating into a plastic utility box. I need to pot it in position.
Is Shoe Goo a good choice here? IF not what is? The adhesive will need to contact the "verks" and be non conductive or corrosive
Thanks in advance!
Posted: Wed Jul 24, 2013 3:03 pm Post subject: Adhesive |
At 05:23 PM 7/24/2013, you wrote:
| Quote: | I have a little DC-DC converter(pc board & components) robbed out of
Thanks in advance!
shoe-goo is a close cousin to E6000 which
is solvent based, water clear, and non
conductive. HOWEVER, it may attack your
plastic box.
Alternatively, RTV sealant used for
aquarium sealing is an option.
also, 5-minute epoxy won't attack the
plastics . . . but may not get a
really good grip on smooth, bright
surface of plastic box.
jonlaury
Posted: Thu Jul 25, 2013 3:17 pm Post subject: Re: Adhesive |
[quote="nuckolls.bob(at)aeroelect"]At 05:23 PM 7/24/2013, you wrote:
snip....
Bob . . . |
You can overcome the lack of adhesion to plastic by drilling some counter sunk holes on the outside of the box. Force epoxy through them to the inside and clamp your electronic guts to the inside over the epoxy. When the epoxy sets, your electronic gizmo is held by epoxy 'rivets'.
If your epoxy runs, turn the project so the counter sunk holes are facing up or use a thixotrope like cabosil (fumed silica) to make it into more of a paste.
