Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Sun Sep 08, 2013 3:11 pm Post subject: Alternator Whine in Radio Transmit |
I have the WW Corvair engine in a 601XLB and have 180 hours on it. I used your design with the JD alternator and replaced the voltage regulator/rectifier with the B&C unit "PMR1C-14". At about 170 hours the filter cap 10,000uF gave up and the ATC folks started to complain.
I have replaced the Cap and now that I know about the whine I find I can switch off the alternator during transmit and it is as clear as a bell. With the alternator switched on it does have a whine that is tolerable, but it still has a whine.
What steps can I take to eliminate the whine from the alternator and leave it switched on?
Be gentle, I'm a metal worker not an electrician.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Posted: Mon Sep 09, 2013 5:49 am Post subject: Alternator Whine in Radio Transmit |
At 06:11 PM 9/8/2013, you wrote:
Quote: | --> AeroElectric-List message posted by: "Ron Lendon" <ron.lendon(at)gmail.com>
Be gentle, I'm a metal worker not an electrician. |
It's it only on transmit? Do you hear it in the headsets
for receiving other stations? Suggest you check the microphone
and headset jacks for being grounded to the panel . . . these
should be insulated from the panel and grounded through wires
back to the intercom.
You can get insulating washers from B&C
Bob . . . [quote][b]
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Mon Sep 09, 2013 7:13 am Post subject: Re: Alternator Whine in Radio Transmit |
Link to B & C insulating washers for headset and mic jacks.
http://www.bandc.biz/insulatingwasherset1pair.aspx
_________________ Joe Gores |
Ron Lendon
Posted: Mon Sep 09, 2013 12:26 pm Post subject: Re: Alternator Whine in Radio Transmit |
The head sets jacks are insulated and grounded back to the single point ground with everything else. Do I need to move that ground wire directly to the intercom unit?
It is only on transmit, I have tried other channels but it makes no difference pilot or copilot, same thing.
CH 601 XLB
N601LT - Flying
Posted: Tue Sep 10, 2013 4:33 am Post subject: Re: Alternator Whine in Radio Transmit |
During a phone conversation with Ron Lendon, I learned that shielded wire was not used for the mic jack. I am thinking that replacing the two individual wires with shielded cable might not help reduce the alternator whine. Bob, I would appreciate your comments on the advantages of shielded wire for the mic jack.
Thanks, Joe
cyav8r(at)yahoo.com Guest
Posted: Tue Sep 10, 2013 5:48 am Post subject: Alternator Whine in Radio Transmit |
I was planning to be over in the morning, but probably leaving early afternoon.
Where is the waiver doc for sign-ins?
pt
Sent: Tuesday, September 10, 2013 7:33 AM
Subject: Re: Alternator Whine in Radio Transmit
Thanks, Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=408331#408331http://www.matronics.com/Navigat= - MATRONICS WEB FORUMS href="http://forums.matronics.com/" target="_blank">http://forums.matr &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
Posted: Tue Sep 10, 2013 6:22 am Post subject: Alternator Whine in Radio Transmit |
Sucks when you reply to the wrong email...
sorry
To: "aeroelectric-list(at)matronics.com" <aeroelectric-list(at)matronics.com>
Sent: Tuesday, September 10, 2013 8:46 AM
Subject: Re: Re: Alternator Whine in Radio Transmit
pt
Thanks, Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=408331#408331 http://www.matronics.com/Navigat= - MATRONICS WEB FORUMS href="http://forums.matronics.com/" target="_blank">http://forums.matr &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
Posted: Tue Sep 10, 2013 9:22 am Post subject: Alternator Whine in Radio Transmit |
Thanks, Joe
Joe Gores
Shielded wire is 99.9% probability of NOT being
the solution. Shielding breaks a capacitive coupling
between a strong antagonist wire with large, fast
rise signals on it and some vulnerable victim carrying
small, easily corrupted signals.
Alternator noise coupled into a vulnerable system
is most likely to be bus noise to a poorly qualified
device, magnetically coupled from some fat wire carrying
alternator current, or a ground loop.
Posted: Tue Sep 10, 2013 9:24 am Post subject: Alternator Whine in Radio Transmit |
Yes.
Ron Lendon
Posted: Sat Sep 14, 2013 3:29 am Post subject: Re: Alternator Whine in Radio Transmit |
Thanks Bob,
This is the part of the instructions from the Sigtronics Installation instructions I missed.
2. Connect all intercom mic jack grounds to a single aircraft chassis ground point - Intercom Central ground Point “A” - as shown in Figure 4. (Use the black washers supplied to insulate the intercom mic jacks from aircraft chassis ground). Note this intercom central grounding point is used to eliminate any unwanted electrical noises, such as alternator whine or strobe noise, from being induced into the intercom system through the grounds. All intercom mic jack barrels must be insulated from ground where they are mounted and connected back to Intercom Central Ground Point “A” on their own individual ground wire. Similarly, both intercom ground wires (J1 pin 4) and the push-to-transmit switch grounds must also be connected back to Intercom Central Ground Point “A” . It is not necessary, however, to connect the headphone jack barrels to Intercom Central Ground Point “A” . They can either be grounded where they are mounted or some place nearby.
I have the airplane opened up and will remedy this oversight promptly.
CH 601 XLB
N601LT - Flying
Ron Lendon
Posted: Fri Nov 22, 2013 11:36 am Post subject: Re: Alternator Whine in Radio Transmit |
Bob and all,
What really made the whine go away was adding a ground wire from the battery through the firewall to the engine. Even though I have a metal airframe it still needed the ground wire. The battery is located behind the passenger seat and the airframe was prime on all the flanges before assembly. The battery was grounded directly to the airframe with a short wire and it really wasn't working very well. The starter spins better also with this setup.
CH 601 XLB
N601LT - Flying
Posted: Fri Nov 22, 2013 7:45 pm Post subject: Alternator Whine in Radio Transmit |
At 01:36 PM 11/22/2013, you wrote:
Quote: |
Bob and all,
The 'star' system for single point grounds
radiate from the fire-wall ground penetration
where goodies on both sides come to a single
point. Your high resistance structure produced
demonstrably poor cranking performance and
laid the foundation for a really strong
ground loop for alternator ripple to generate
noise voltages.
I'm sorry we didn't ask you about your ground
system architecture earlier.
