Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Tue Sep 10, 2013 12:24 pm Post subject: Fuel Flow Meter |
Hello ALL.
I spent to much money at the LAA Sywell show. At 67 I must be crazy considering the price of second-hand aircraft at the moment.
I purchased a MGL Flow meter, 2 Flowscan Senders, and line fittings,
An incredible £650, the final job will cost nearer a £1000, as I will need a few more bits and a new externally mounted compass, as I need the panel compass hole for the new meter, and they tell me I will need new 8.33 radio in 4 years time, Crazy Country.
However, a couple Questions,
914 rubber fuel hose, what type and Where do I get this from,?
The instruction for the Flow scan senders, at low fuel flows ie the 914 it recommends installing a jet in the fuel line before the flow meter, no picture of this jet, no item number or price, just give a different K value to use,
Anybody know what this is all about.???!!!!!
Regards.
Alan
rampil
Posted: Wed Sep 11, 2013 7:31 am Post subject: Re: Fuel Flow Meter |
Alan,
Floscan makes 3 models of the 201 sender for varying expected mean
flow rates of gasoline. The appropriate unit for the 914 is the 201A
model which handles 0.3 - 30 gal per hour.
If a jet is added, at least in my imagination of what a "jet" or orifice might
be, it will add turbulence and reduce accuracy of the flow turbine. I could
not find a reference to such an addition in the FloScan site. Further, in a
914 application, the meaningful flow regime is roughly 3 - 7 gal/hour, well
within the linear range of system. Does it really matter if the measured
flow rate at idle power (less than 2 gal/hr) is slightly off?
The only place where the flow rates are less than that is in the return line
to the tank. In my 912s application, the return flow is unmeasured, but
very small, since my measured forward flow rate are right at what Rotax
predicts in the manual. It is much less than the LAA posited rate of 0.8
gal/hr through the 0.35mm orifice.This was after I independently
calibrated my Floscan at three different flow rates. Perhaps the LAA
used a higher than Rotax max pressure head of 5 psi through the orifice?
The slight apparent increase in fuel flow rate (by not measuring the return
flow and subtracting it in the totalizer) seems to me a a safety feature.
BTW, any additional "jet" in the return line, if that is what you were
contemplating is a direct violation of the engine install instructions for the
914 which requires a low resistance path bach to the tank after the
pressure regulator.
The return flow rate situation with the 914 may be a bit different than
with the 912s, though the pressures and the return orifice are the same.
I recognize that if the LAA tells you that you must have return flow measured, if measuring flow at all, you must comply.
It is just my opinion that trying to measure flow rates under 0.5 gal/hr will
be inherently inaccurate with the Floscan 201A in an aircraft environment
and isnot worth the trouble and expense. On the other hand, many
builders have this feature installed.
Best of luck!
Posted: Wed Sep 11, 2013 9:29 am Post subject: Fuel Flow Meter |
Alan, I go along with that. My 914/twin Floscan set up has
worked nicely without any sort of jet. The only relevant
stipulation I can remember is that there should be a
reasonable length of fairly straight hose leading into
each Floscan as sharp corners will produce turbulence and
false readings. One of the key points with the Floscan I
believe is that even if its spinner jams it will not
significantly impede flow. It seems a bad idea to put
anything in the flow if you don't have to.
Regards, David Joyce, G-XSDJ
On Wed, 11 Sep 2013 08:31:34 -0700
"rampil" <ira.rampil(at)gmail.com> wrote:
Alan,
expected mean
914 is the 201A
site. Further, in a
- 7 gal/hour, well
if the measured
off?
unmeasured, but
right at what Rotax
posited rate of 0.8
independently
Perhaps the LAA
a safety feature.
what you were
tank after the
pressure regulator.
different than
comply.
hand, many
Best of luck!
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=408424#408424
Un/Subscription,
Forums!
Admin.
daseitz(at)cfl.rr.com Guest
Posted: Wed Sep 11, 2013 9:46 am Post subject: Fuel Flow Meter |
The 914 does not have a low flow rate. It pumps around 20 gal per hour from the tank and returns all of that minus what the engine used back to the tank. Feed is around 20 gal/hr and return is about 15 gal/hr at cruise. At idle it's almost 20 gal/hr return.
---- David Joyce <davidjoyce(at)doctors.org.uk> wrote:
> Alan,
>expected mean
>914 is the 201A
>site. Further, in a
>- 7 gal/hour, well
>if the measured
>off?
>unmeasured, but
>right at what Rotax
>posited rate of 0.8
>independently
>Perhaps the LAA
>a safety feature.
>what you were
>tank after the
> pressure regulator.
>different than
>comply.
>hand, many
> Best of luck!
> Ira N224XS
>Un/Subscription,
>Forums!
>Admin.
jan_de_jong(at)casema.nl Guest
Posted: Wed Sep 11, 2013 11:25 am Post subject: Fuel Flow Meter |
I saved a message by Jim Butcher on a blue-mountain-avionics forum where
he reported measuring a flow of 41 gph into a bucket. The Rotax 914
installation manual gives 30 gph as the rated flow for 1 pump at 300 hPa
(airbox at sea level pressure) to 25 gph at 1000 hPa (airbox at 16000'
with full boost). The second pump would increase this by a small amount.
Floscan 201A-6 seems marginal, 201B-6 seems better.
I bought from Floscan 2 of type 231 ("marine use only"), similar to
201B-6 but heavier (steel). And less expensive. And no fretting with
aluminium adapters...
Alan, if you have a 914 I believe you might get the 914 installation
manual - it has a flow graph for the pump (Pierburg E1F no. 7.21440.78.0).
And you might check out the Floscan website. There are 2 aviation pages.
Regards, Jan de Jong.
On 9/11/2013 7:45 PM, Dean Seitz wrote:
>> Alan,
>> expected mean
>> 914 is the 201A
>> site. Further, in a
>> - 7 gal/hour, well
>> if the measured
>> off?
>> unmeasured, but
>> right at what Rotax
>> posited rate of 0.8
>> independently
>> Perhaps the LAA
>> a safety feature.
>> what you were
>> tank after the
>> pressure regulator.
>> different than
>> comply.
>> hand, many
>> Best of luck!
>> Ira N224XS
>> Un/Subscription,
>> Forums!
>> Admin.
Posted: Wed Sep 11, 2013 11:32 am Post subject: Fuel Flow Meter |
Jan, I wonder whether he was measuring what came out of
the pump, rather than what came back through the return
hose with the engine not going,
once the fuel had gone through the pressure release
valve., which will be quite a bit less I guess.
Regards, David Joyce, G- XSDJ
On Wed, 11 Sep 2013 21:24:13 +0200
Jan de Jong <jan_de_jong(at)casema.nl> wrote:
blue-mountain-avionics forum where he reported measuring
pump at 300 hPa (airbox at sea level pressure) to 25 gph
at 1000 hPa (airbox at 16000' with full boost). The
similar to 201B-6 but heavier (steel). And less
expensive. And no fretting with aluminium adapters...
installation manual - it has a flow graph for the pump
aviation pages.
><daseitz(at)cfl.rr.com>
>>has
>>and
>>> Alan,
>>> expected mean
>>> 914 is the 201A
>>> site. Further, in a
>>> - 7 gal/hour, well
>>> if the measured
>>> off?
>>> unmeasured, but
>>> right at what Rotax
>>> posited rate of 0.8
>>> independently
>>> Perhaps the LAA
>>> a safety feature.
>>> what you were
>>> tank after the
>>> pressure regulator.
>>> different than
>>> comply.
>>> hand, many
>>> Best of luck!
>>> Ira N224XS
>>> Read this topic online here:
>>> Un/Subscription,
>>> Forums!
>>> Admin.
Un/Subscription,
Forums!
Admin.
rampil
Posted: Wed Sep 11, 2013 12:20 pm Post subject: Re: Fuel Flow Meter |
I defer to those with 914 experience!
Posted: Wed Sep 11, 2013 12:53 pm Post subject: Fuel Flow Meter |
David, "I measured actual fuel flow (ran pump into a bucket) and
determined it is 41 gph."
The maximum operating flow through the forward flow sensor would be
slightly smaller than 41 gph - the difference between 300 hPa and 0 hPa
in the pump diagram is between 1 and 2 gph.
I agree that the return flow is 0 (engine off) to 10 gph (115%) smaller
than the forward flow.
On 9/11/2013 9:32 PM, David Joyce wrote:
Jan, I wonder whether he was measuring what came out of the pump,
rather than what came back through the return hose with the engine not
going,
once the fuel had gone through the pressure release valve., which will
> where he reported measuring a flow of 41 gph into a bucket. The Rotax
> 914 installation manual gives 30 gph as the rated flow for 1 pump at
> 300 hPa (airbox at sea level pressure) to 25 gph at 1000 hPa (airbox
> at 16000' with full boost). The second pump would increase this by a
> small amount.
> 7.21440.78.0).
>>>> Alan,
>>>> expected mean
>>>> 914 is the 201A
>>>> site. Further, in a
>>>> - 7 gal/hour, well
>>>> if the measured
>>>> off?
>>>> unmeasured, but
>>>> right at what Rotax
>>>> posited rate of 0.8
>>>> independently
>>>> Perhaps the LAA
>>>> a safety feature.
>>>> what you were
>>>> tank after the
>>>> pressure regulator.
>>>> different than
>>>> comply.
>>>> hand, many
>>>> Best of luck!
>>>> Ira N224XS
>>>> Un/Subscription,
>>>> Forums!
>>>> Admin.
> Un/Subscription,
> Forums!
> Admin.
Alan Carter
Posted: Thu Sep 12, 2013 5:40 am Post subject: Re: Fuel Flow Meter |
Hello All.
Sorry but I may have got into a bit of a muddle over this.
1. At LAA Show Rotax Stand, said the flow rate being pumped around the system on a 914 was about 100 Ltr/Hr.and my sender could cope with measuring up to 136 an hour.
Does not fit in with what the Forum are saying, but maybe the bods on the Rotax Stand have it wrong.
2. On Advice from the Rotax Stand, and the MGL Stand, I purchased the
Flowscan "A" model 0 to 30 gallons and hour, ("B" modal was 0 to 60 Gph) for larger engines.
3. The MGL instructions referring to installing these in line Jets before the sender, which it clearly states, but give no information on,
I believe may be only relating too, and with installing a MGL Flow Sender,!!
However I think the whole lot is very poor with the instruction, and what Sender to use.
Rotax Stand, Rotax don,t approve of any Flow sender being install in the fuel line,
Regards .
Alan
rparigoris
Posted: Thu Sep 12, 2013 6:02 am Post subject: Fuel Flow Meter |
Hi Group
Curiosity question, has anyone had a Flowscan fuel flow sender fail because of stale auto fuel? Somehow I think I remember pulses are created optically, not magnetically and was always wondering if stale fuel would cloud the optics. If the optics do cloud, is there any procedure to clean?
Ron Parigoris [quote][b]
Alan Carter
Posted: Thu Sep 12, 2013 6:33 am Post subject: Re: Fuel Flow Meter |
Hi All.
MGL. Instructions. It is highly recommended a small jet is installed on engines with low fuel flows.
The sender is delivered with a small jet that can be installed in the flow senders inlet, Installation of this jet is recommended with engine with fuel flows less than 30 gal/Hr, this would apply to most small 2 stroke and 4 stroke engines.
The FF-1 is shipped with the fuel flow sender calibration set for the jet installation, in a good installation you can expect an accuracy of +- 3% you can calibrate the sender yourself to a higher degree of accuracy if you desire.
So it the FF-1 , mentioned here, so what about other makes of senders,
does this only apply to the FF-1 ?????
Alan
Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Posted: Thu Sep 12, 2013 8:53 am Post subject: Re: Fuel Flow Meter |
Maybe try the MGL Knowledge Base http://www.mglavionics.com/kb/ or ask the MGL people if they have install instructions specifically for the Floscan sensor?
HTH
