Bolt Torque Specs
Goto page 1, 2  Next
randy(at)shadycreekoutlaw
PostPosted: Mon Jun 12, 2006 6:11 am    Post subject: Bolt Torque Specs Reply with quote
I am finishing up the center spar for my 601 XL.  There are 6, AN4-15A bolts that go through the center spar.  Are there torque specifications on these bolts that I need to follow?
Thanks in advance,
Randy
XL Wings - Plans Only
http://www.n344rb.com
larry(at)macsmachine.com
PostPosted: Mon Jun 12, 2006 7:05 am    Post subject: Bolt Torque Specs Reply with quote
Randy,
Most bolts in structural applications will have a torque value for the
place they are used.
The AN4-15A bolt is a high strength fine thread bolt with 50-70 inch
pounds standard type nuts.
You need the Standard Aircraft Handbook 6th ed or later. Most of this
kind of information is
in this handbook. Your plans have the final word on fasteners,
dimensions etc.
Larry McFarland - 601HDS at www.macsmachine.com
Thanks in advance,
Randy
PostPosted: Mon Jun 12, 2006 11:59 am    Post subject: Bolt Torque Specs Reply with quote
Thanks Larry,
My plans don't say what to torque these bolts to... Since most are kit
builders and don't have to actually build this part, since it comes from the
factory already assembled, I guess that the torque value for these 6 center
spar bolts is not 'common knowledge'... I guess my best bet is to call ZAC
and see what they can tell me...
Thanks much,
Randy
normskiroo@ukonl
PostPosted: Tue Jun 13, 2006 6:56 am    Post subject: Bolt Torque Specs Reply with quote
Hello Randy,
According to CZAW the recommended torque for the AN4 bolts are 50 to 70 in. lb. (5.6 to 7.9 Nm) the limit being 11.3 Nm.
Hope this helps.
Norman
601 XL G-DONT 40 hrs U.K.
frank.hinde(at)hp.com
PostPosted: Tue Jun 13, 2006 7:25 am    Post subject: Bolt Torque Specs Reply with quote
Actually the real limit is when you strip the threads! You cannot cause a bolt to fail in service due to over torquing. They will break (if subjected to vibrational tension changes that cuse fatigue) if you UNDER torque them.
Bottom line (and I can't wait to get flamed on this...Smile...) the listed torques specs really are on the very bottom limit for comfort and I assume are primarilly for fasteners in shear rather than tensile applications.
You would never find a cylinder head or tensile faster with so little torque, but they have been shown to work in practice . Mine are all a little tighter than this though.
Frank
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of norman
Sent: Tuesday, June 13, 2006 7:54 AM
Subject: Re: Bolt Torque Specs
Hello Randy,
Hope this helps.
Norman
PostPosted: Tue Jun 13, 2006 8:10 am    Post subject: Bolt Torque Specs Reply with quote
I thought that the reason for torquing bolts was to achieve the proper 'stretch' in the bolt...  I know in an engine, you torque rod bolts, they stretch and apply tension to the rod caps and this helps hold the cap on...  If you over torque, you 'stretch' the bolt past its elasticity and loose this extra holding capacity...
Maybe I'm wrong...??  I just hate having to tighten something as far as it will go then 1/4 turn more as the torque specs...
Thanks!
Randy
PostPosted: Tue Jun 13, 2006 8:48 am    Post subject: Bolt Torque Specs Reply with quote
Thanks Frank,
It looks like I'm gonna agree with you after all...  I just got a response back from ZAC about the torque of these bolts and here's what they said:
"For proper bolt selection and installation, please refer to the FAA
publication, Acceptable Methods Techniques, and Practices: AIRCRAFT
INSPECTION AND REPAIR AC 43.13-1B"
We all know what that says, 50-70 inch pounds...  Its a crying shame that a go-kart manufacturer can tell you specifically to torque certain bolts, used in certain applications, to an exact spec, and aircraft manufacturers can't... (I guess they're too busy keeping their rivets exactly 8mm from the edge)  Even the auto makers do this...  They'll tell you specifically how many foot/pounds or inch/pounds to tighten certain bolts, not some broad range of 50-70 inch pounds...
I guess I'll just tighten em' as tight as they'll go, then go about 1/4 turn more... that should do it..
Randy
Carlos Sa
PostPosted: Tue Jun 13, 2006 10:00 am    Post subject: Bolt Torque Specs Reply with quote
Randy, I think you are quite right.
The more torque you apply, the closer the material gets to "plastic" (as opposed to "elastic").
There is a lot of good reading material out there. I found this one to be interesting:
http://www.auf.asn.au/scratchbuilder/hardware.html
Cheers
Carlos
CH601-HD, plans
Building aeroplanes (one) since 1999. A tradition in the making.
CH601-HD, plans
Montreal, Canada
PostPosted: Tue Jun 13, 2006 10:02 am    Post subject: Bolt Torque Specs Reply with quote
There is no way on Earth you will stretch AN bolts with the miniscule listed torque specs. The AN4 is listed at about 6 ft lbs...On a cylinder head this would be more like 15lbs and it still won't stretch.
Frank
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Randy Bryant
Sent: Tuesday, June 13, 2006 9:08 AM
Thanks!
Randy
moorecomp(at)yahoo.com
PostPosted: Tue Jun 13, 2006 10:15 am    Post subject: Bolt Torque Specs Reply with quote
Randy,
Remember that the torque is to be added to the running
torque of the nut. If you are using self locking nuts,
then you need to measure the amount of torque required
to turn the nut and add it to the 50 - 70 in. lbs. If
you really want to get educated on threaded fastener
torque, go here and look at MIL-HDBK-60.
http://www.combatindex.com/mil_docs/mil_hdbk_index_01.html
This is a great link and all should bookmark it. Lots
of info here.
BTW - At the end of the handbook, it shows a chart
that looks like the AN4 bolt, which is a 125ksi
tensile material, would require approx. 100 in. lbs.
of torque, the max value given in the 43.13.
Small flame for Frank,
Excessive torque can be a bad thing too, especially if
you exceed the elastic limit of the bolt. Over time,
with cyclic loading and vibration, the preload on the
fastener will be gone, resulting in a situation you
described - undertorque. As another lister noted, bolt
stretch is commonly used as a method of checking for
proper preload. But, the value is within the elastic
limits. All of this is the reason that we go back and
retorque fasteners after a certain time. Also, in the
type of joint we are talking about, the use of many
bolts is because the majority of the shear loads are
transferred through friction of the joint components,
and the load is spread over a large area and not just
taken up by the bolt shanks. Lose the preload, and you
cause stresses to be concentrated at the bolts, thats
were elongated holes come from.
Ducking,
Craig Moore A&P
701 builder wannabe
--- Randy Bryant <randy(at)shadycreekoutlaws.com> wrote:
[quote] Thanks Frank,
refer to the FAA
Practices: AIRCRAFT
inch pounds...
it..
Randy
PostPosted: Tue Jun 13, 2006 10:44 am    Post subject: Bolt Torque Specs Reply with quote
No need to duck Craig...Smile
Good point but...the point about "stretching" the bolt is basically
taking the fastener up to the top of its elastic limit...In fact most
cyl head bolts today cannot be reused so this presumably means the have
been torqued INTO their plastic range.
I am am not talking about going anywhere near that point....10 foot
pounds say will still be well within the elsatic range of a 1/4" 125kpsi
bolt.
But I agree...You can't just keep tightening the thing at will...Smile
Frank
PostPosted: Tue Jun 13, 2006 10:59 am    Post subject: Bolt Torque Specs Reply with quote
Thanks Craig,
This is good info... This really helps... My fear was I wouldn't tighten
them enough and have to worry about that from now on after my plane is
flying, or be in fear that they are too tight and loose the preload...yet
another thing to worry about...
One more quick question for you:
Would a certain bolt such as an AN4 require the same torque regardless of
it's application (where it's being used on the plane) ?
Thanks much,
Randy
PostPosted: Tue Jun 13, 2006 12:13 pm    Post subject: Bolt Torque Specs Reply with quote
Randy,
I assume you looked at the MIL-HDBK-60. Paragraph 4.2
gives the two type of shear loaded joints. One is like
your wing attach bolts. No sliding, with shear loads
transmitted by friction. Think of the other as like a
rod end or fork fitting. This type obviously does not
use friction to transmitt the load from one fitting to
the other, it goes through the bolt. In this case, the
torque is only to hold the joint together so that
bending loads do not occur on the bolt. A castle nut,
finger tight, then tight to line up the cotter pin
hole would suffice. On a high tensile load like an
engine mount to firewall, then the clamping force of
the rated torque would be used to keep the joint
together and prevent bending. Good luck building. I'll
be there one day.
Best regards,
Craig Moore A&P
701 builder wannabe
Thanks Craig,
after my plane is
plane) ?
Thanks much,
Randy
snip
noelloveys(at)yahoo.ca
PostPosted: Tue Jun 13, 2006 2:01 pm    Post subject: Bolt Torque Specs Reply with quote
I usually go with the lower end of the range...50 - 70 In.Lb.  Use 50 In. Lb. on the first use... if the nut is removed and used again then I'll use 60"Lb. The second time it's removed may as well replace it if it is in an area of any stress.
One other thing I always turn/torque the nut....  never the bolt.
Noel [quote]
zodierocket(at)hsfx.ca
PostPosted: Tue Jun 13, 2006 2:33 pm    Post subject: Bolt Torque Specs Reply with quote
Randy not to dampen your expectations but “you are” the manufacturer, not the kit provider. It is your responsibility to ensure compliance to FAA regulations.  Zenith sells and supports kits that will someday fly. If you want an exact torque you could try AMD which manufacturers Zodiacs for the LSA market, but I doubt they will respond. ZAC’s response was correct and expected. It is up to you as to what torque you are comfortable with.
cdngoose
www.ch601.org / www.ch701.com/ www.Osprey2.com
-----Original Message-----
Thanks Frank,
[i]"For proper bolt selection and installation, please refer to the FAA[/i]
[i][i]publication, Acceptable Methods Techniques, and Practices: AIRCRAFT
[/i]
[i]INSPECTION AND REPAIR AC 43.13-1B"[/i][/i]
We all know what that says, 50-70 inch pounds...  Its a crying shame that a go-kart manufacturer can tell you specifically to torque certain bolts, used in certain applications, to an exact spec, and aircraft manufacturers can't... [i](I guess they're too busy keeping their rivets exactly 8mm from the edge)[/i]  Even the auto makers do this...  They'll tell you specifically how many foot/pounds or inch/pounds to tighten certain bolts, not some broad range of 50-70 inch pounds...
Randy
daberti(at)sbcglobal.net
PostPosted: Tue Jun 13, 2006 3:29 pm    Post subject: Bolt Torque Specs Reply with quote
50 to 70 is NOT "some broad range"  in fact + or - 10 inch lbs Is a rather standard torque tolerance.  Certificated (calibrated) torque wrenches are only good to 2 percent of the total range of the wrench so if you have a 0 to 150 in lbs wrench it's accurate to  3 inch lbs from what you set it to.  Sounds like a pretty tight specification to me, and I shoot for the mean plus the drag of the nylon stop nut.
Dave 601-HD 912ULS
[/i]
PostPosted: Tue Jun 13, 2006 9:15 pm    Post subject: Bolt Torque Specs Reply with quote
I only use the drag of the fibre lock nut (AKA friction torque) when it is specified.  Wearing of the fibres in the locknuts is the main reason I dump them after they have been tightened three times.  In the overall scheme of things they are cheap enough to use relatively new.
As for the torque wrench I tend to check mine out with a known weight every couple of months.  Right now for 200"Lb. I set for 187"LB.  checking it is easy as suspending a known weight on the handle at a specific distance from the centre of the stud and then adjusting the wrench to just click at that torque.
e.g. 16.6Lb. suspended at 12" from the centre of the stud = 200"Lb.  When calibrated this way the torque wrench should be less than 1% out.  you can also put the same weight at 6" top check the calibration of 100"Lb.
In Canada torque wrenches used on certified A/C have to have a certificate of calibration in effect before the wrench is used.
Noel [quote]
normskiroo@ukonl
PostPosted: Tue Jun 13, 2006 10:38 pm    Post subject: Re: Bolt Torque Specs Reply with quote
Randy,
A word of caution here, I have this morning checked my CZAW drawings and they specify the bolts that attach the wings on my XL are AN5 15A not AN4 15A.
The torque for these bolts according to the data CZAW gave me is -
100 to 140 in. lb. recommended 11.3 to 15.8 Nm with a limit of 25.4 Nm.
I shall, next time a am down at the aircraft use a vernier gauge to confirm the size.
During a wings off/back on operation some time ago I managed to strip the threads of one of the bolts /nuts by over tightening and I was only using a ratchet socket handle six inches long!
Needless to say the drilling of the bolt head took a while to get the whole thing out!
Norman 601 XL G-DONT 40 hours, UK
p.mulwitz(at)worldnet.att
PostPosted: Wed Jun 14, 2006 3:28 am    Post subject: Bolt Torque Specs Reply with quote
This estimate assumes the measurement of 12 inches and 16.6 pounds
have a combined error of less than 1%. I find this conclusion very
unlikely. Still, the procedure will assure a reasonably accurate
torque from the wrench.
Paul
XL wings
PostPosted: Wed Jun 14, 2006 3:31 am    Post subject: Bolt Torque Specs Reply with quote
ZAC drawings for the XL also call for AN5 -15A attach bolts on the
wings. I decided to change to AN5-14A since the originals seemed a
little too long to me.
Paul
XL wings
Goto page 1, 2  Next
Page 1 of 2
