ogdenk
Posted: Tue Nov 19, 2013 8:38 am Post subject: Roll Servo Wiring for RV-10 |
Hi all,
I am trying to get my wings closed up on my RV-10, but I would like to get all the wiring in first if possible. I haven't decided on an autopilot yet, but I was wondering if the roll servos that are out there would use a more or less similar wiring harness. If, for example, I got a SteinAir wiring harness for a Trutrak servo, would it be compatible with another AP? I guess I don't know how many different servos there are, do different AP's use basically the same servos?
Kent
timrhod(at)aol.com Guest
Posted: Tue Nov 19, 2013 8:47 am Post subject: Roll Servo Wiring for RV-10 |
You may be able to use the same wires perhaps relocating a few pins but the servos differ depending on which autopilot you use. I switched from a blue mountain system to a truetrac and was able to use the same wires already installed just had to relocate the pins.
Sent from my iPad
On Nov 19, 2013, at 11:36 AM, "Kent Ogden" <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)> wrote:
[quote] Hi all,
Kent
Posted: Tue Nov 19, 2013 9:28 am Post subject: Roll Servo Wiring for RV-10 |
On 11/19/2013 11:36 AM, Kent Ogden wrote:
I would determine the max number of wires required for any AP servo, then get the Trutrak harness with any extra wires bundled in with it. That number is probably zero. Stein can probably answer that one off the top of his head.
You will find you have plenty of access for adding/changing the terminating plug once the wing is closed up. But routing the wire is much easier before you close things. A good service loop is desirable at that servo location in any case. Go for it.
Bill
[quote] Hi all,
Kent
Kellym
Posted: Tue Nov 19, 2013 11:42 am Post subject: Roll Servo Wiring for RV-10 |
Dynon sells 20" servo wire bundles which IIRC were 5 wire, which are
specific to their servos. I do know Trutrak wiring is different, even
though the servos physically interchange with each other. Dynon did a
fair amount of development to magnify force and travel for their RV-10
elevator servo. I don't know what the others have, the Dynon was a
simple install...drill a few holes and bolt it in. Well thought out.
Bill
> Hi all,
> servos?
> Kent
KCHD |
dee.whittington(at)gmail. Guest
Posted: Tue Nov 19, 2013 11:57 am Post subject: Roll Servo Wiring for RV-10 |
Kent,
Please send your question to Chuck Busch at Trio Avionics in California. We have bought the Trio Pro Pilot and Gold Series servos for our Sportsman. Although we aren't flying yet, I still think Trio is the top of the heap for auto pilots in experimental aircraft.
Email him at ezflyr82(at)cox.net (ezflyr82(at)cox.net) or info(at)trioavionics.com (info(at)trioavionics.com)
He's a super nice guy. I always make it a point to talk to him and the Trio team at Oshkosh and Sun 'n Fun. If you ever get the chance, either in person or on the phone, have Chuck explain the special, unique features of the Gold Series servos. You'll be amazed.
I'm copying him on this email so he'll know of your question.
Dee
DeWitt (Dee) Whittington Richmond, VA
804-677-4849 iPhone
804-358-4333 Home
On Tue, Nov 19, 2013 at 2:42 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote] --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Dynon sells 20" servo wire bundles which IIRC were 5 wire, which are specific to their servos. I do know Trutrak wiring is different, even though the servos physically interchange with each other. Dynon did a fair amount of development to magnify force and travel for their RV-10 elevator servo. I don't know what the others have, the Dynon was a simple install...drill a few holes and bolt it in. Well thought out.
Bill
| Quote: | Hi all,
Kent
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
sam.marlow
Posted: Tue Nov 19, 2013 6:56 pm Post subject: Roll Servo Wiring for RV-10 |
Kent Ogden wrote:
| Quote: | Hi all,
servos?
Kent
Don't hold up your build for wiring, you can add all the wires after the
skin is on!
bakerocb
Posted: Wed Nov 20, 2013 9:57 am Post subject: Roll Servo Wiring for RV-10 |
11/20/2013
Hello Kent, One way to solve the problem of getting wires from the fuselage to the wing tip, for now and in the future, is to install a thin wall plastic tube like sprinkler systems use in the wing as a conduit to run the wires within. Very easy to snake in additional wires if required.
āOCā
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
Time: 08:38:10 AM PST US
From: "Kent Ogden" <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)>
Subject: Roll Servo Wiring for RV-10
Hi all,
Kent
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed Nov 20, 2013 10:58 am Post subject: Roll Servo Wiring for RV-10 |
One additional hint....always pull a string through with the wire and tie off at both ends. That way you have a pull line to use if you ever need to add an additional wire for some reason.
BOB
To: ogdenk(at)upstate.edu; aeroelectric-list(at)matronics.com
Sent: Wednesday, November 20, 2013 11:56 AM
11/20/2013
āOCā
Subject: AeroElectric-List: Roll Servo Wiring for RV-10
Hi all,
Kent
[quote]http://www.aeroww.buildersbooks.com/" target="_blank" rel="nofollow">http://www.buildethelp.com/" target="_blank" rel="nofollow">http://www.homebuilthelp.com= * Race Consulting [b]
Posted: Wed Nov 20, 2013 12:45 pm Post subject: Roll Servo Wiring for RV-10 |
At 12:56 PM 11/20/2013, you wrote:
| Quote: | One additional hint....always pull a string through with the wire and tie off at both ends. That way you have a pull line to use if you ever need to add an additional wire for some reason.
BOB |
Yeah . . . but be sure to pull a new string in with the new
wires or you only get to do it the easy way once . . .
[quote] Bob . . .[/b] [quote][b]
Robert Reed
Posted: Wed Nov 20, 2013 12:56 pm Post subject: Roll Servo Wiring for RV-10 |
Been there, done that, have recorded the choice words for posterity.
Bob
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Wednesday, November 20, 2013 2:44 PM
Subject: Re: Roll Servo Wiring for RV-10
BOB |
[quote] Bob . . .
| Quote: | | http://www.aeroelectildersbooks.com/" target="_blank" rel="nofollow">http://www.buildersboo.com/" target="_blank" rel="nofollow">http://www.homebuilthelp.com/ * Race Consulting | [b]
wschertz(at)comcast.net Guest
Posted: Fri Nov 22, 2013 5:33 am Post subject: Roll Servo Wiring for RV-10 |
Depending on how tight the existing wire bundle is, you can tie a cotton wad onto a string and pull it through with a shop vac.
OR, I have pushed a 1/4ā polyethylene tubing (which is stiffer than the wire) through the conduit, then pushed the wire through the tubing and then pulled the 1/4ā tube out, leaving the wire.
Sent: Wednesday, November 20, 2013 2:53 PM
Bob
BOB |
[quote] Bob . . .
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.mrrace.com">www.mrrace.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
