cjhukill(at)cox.net Guest
Posted: Sun Nov 24, 2013 6:02 am Post subject: seat |
I have not yet installed my seats, and am confused about the seat plunger issue. Why is it necessary to remove the plunger from the seat to remove the seat from the rails? If it’s because you can’t get your hand down between the seat and side of the fuselage while sliding the seat aft, will the extention handle mod allow you to remove the seat without removing the plunger?
Chris Hukill
waiting for engine to arrive
rleffler
Posted: Sun Nov 24, 2013 6:30 am Post subject: seat |
There are two large nuts that the plunger will hit and prevent the seat from sliding off the rails.
Sent from my iPad
On Nov 24, 2013, at 9:01 AM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
[quote] I have not yet installed my seats, and am confused about the seat plunger issue. Why is it necessary to remove the plunger from the seat to remove the seat from the rails? If it’s because you can’t get your hand down between the seat and side of the fuselage while sliding the seat aft, will the extention handle mod allow you to remove the seat without removing the plunger?
Chris Hukill
ot;">www.aeroelectric.com
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
_________________ Bob Leffler
N410BL - Phase I
rene(at)felker.com Guest
Posted: Sun Nov 24, 2013 6:51 am Post subject: seat |
Nope, there is a stop on the rail that cannot be removed (without mod). The plunger cannot get past the stop and thus needs to be removed for the seat to slide off the back of the rails. I have looked at ways of making the stop removable (like others have done), but looks like too much work on completed airframe. You would not want to remove the stop permanently for safety reasons……i.e. the Cessna seat rail issue and mod. You would not want the pilot sliding into the back seat on rotation……..if the plunger go stuck in the up position.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Sunday, November 24, 2013 7:01 AM
To: matronics
Subject: seat
Chris Hukill
0123456789012345678
woxofswa
Posted: Sun Nov 24, 2013 7:04 pm Post subject: Re: seat |
I posted an explanation on the other thread before reading this thread.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
