		ellismcgaughy(at)gmail.co Guest
				 Posted: Wed Nov 27, 2013 5:57 am    Post subject: Elevator bending brake |
				I'm building my second set of rv7a elevators as I found my first set warped by about 1/2" at the inboard trailing edges.
 I'm preparing to bend the skins and was wondering if anyone that might live within a hundred miles or so from Fayetteville NC might already have a bending brake I could use.   Otherwise, I will plan to dive through all the warped lumber at my local neighborhood hardware store.
 Ellis
 A&P and Grumman tiger owner.
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		george(at)oilhelp.com Guest
				 Posted: Wed Nov 27, 2013 6:14 am    Post subject: Elevator bending brake |
				Ellis, I don't know anything about your project other than I plan to buy an already built RV 7 down the road. I have a traveler presently and keep it at my strip in TN at 2tn7.  Are you building the RV to replace your tiger?
 George
  	  | Quote: | 	 		   On Nov 27, 2013, at 8:57 AM, Ellismcgaughy <ellismcgaughy(at)gmail.com> wrote:
  Ellis
		ceengland7(at)gmail.com Guest
				 Posted: Wed Nov 27, 2013 6:46 am    Post subject: Elevator bending brake |
				On 11/27/2013 7:57 AM, Ellismcgaughy wrote:
  Ellis
 I'm not close, but might be able to offer a tip or two on doing the bend
 if you build your own bender. 1st, using a dowel (wood, welding rod,
 etc) taped into the trailing edge can help with preventing a too-sharp
 bend. Also, I found that my home made brake tended to roll the bend
 forward on the side that was on top side of the brake. I made the bend
 in multiple steps, checking after each step by clecoing the skin onto
 one side of the skeleton & checking hole alignment on the other side
 while manually pressing the skin down against the skeleton.
		dan.pat.b(at)gmail.com Guest
				 Posted: Thu Nov 28, 2013 6:28 pm    Post subject: Elevator bending brake |
				EllisI still have the homemade brake I made about 10 years ago out of 2' x 8's and 3.5" hinges - you'd be welcome to it - problem is I'm in Massachusetts - wish I could offer you some advice - as I recall the bending process was pretty straight forward - only thing I can think of is make sure the lumber pieces you make your brake with are perfectly true with not the slightest sign of a warp - keep flipping the skins over after each press to avoid rolling the bend too far forward on one side or the other - good luck and stay with it -
  Dan Bergeron
 RV-7A - N307TB
 442 hours since first flight
      on Aug 4, 2009
 On Wed, Nov 27, 2013 at 9:45 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
  [quote]--> RV7-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
   	  | Quote: | 	 		   --> RV7-List message posted by: Ellismcgaughy <ellismcgaughy(at)gmail.com (ellismcgaughy(at)gmail.com)>
  Ellis
  I'm not close, but might be able to offer a tip or two on doing the bend if you build your own bender. 1st, using a dowel (wood, welding rod, etc) taped into the trailing edge can help with preventing a too-sharp bend. Also, I found that my home made brake tended to roll the bend forward on the side that was on top side of the brake. I made the bend in multiple steps, checking after each step by clecoing the skin onto one side of the skeleton & checking hole alignment on the other side while manually pressing the skin down against the skeleton.
  om" target="_blank">www.aeroelectric.com
  ooks.com" target="_blank">www.buildersbooks.com
  et="_blank">www.homebuilthelp.com
  et="_blank">www.mypilotstore.com
  "_blank">www.mrrace.com
  le, List Admin.
  rget="_blank">http://www.matronics.com/Navigator?RV7-List
  http://forums.matronics.com
