Bajajim
Posted: Thu Dec 05, 2013 9:16 am Post subject: RV 10 Aileron Trim easy fix... |
Easy Cheap Dependable fix…
<![if !supportLists]>1) <![endif]>Replace your “Flap Toggle Switch” with a Double Pole (on) off on switch. (Same as original but Double Pole)
<![if !supportLists]>2) <![endif]>On the 2nd pole (not controlling your flaps) install a single pole double throw “Relay”.
Install the relay so when your flaps are in the -3degree position (Cruse position) the relay is activated.
Any other position “Off” (On) climb out or landing configuration the relay will not be energized or normally closed.
<![if !supportLists]>3) <![endif]>Split the 14v power to both legs of the relay (Line side of the relay) “Normally open and normally closed legs of the relay”.
<![if !supportLists]>4) <![endif]>On the “Normally Closed” (1st leg) pin on the relay (Load side of the relay) run your 14 volt power through the closed contacts,
You now have full power to your trim motor.
You will need full speed trim for takeoff and landing configurations.
<![if !supportLists]>5) <![endif]>On the 2nd leg of the relay (load side) the relay hook up a 9 volt 7809t voltage regulator with a capacitor.
Connect the 9 volt wire to the 14v wire on the (LOAD SIDE OF THE RELAY) that connects back to your trim motor power.
Now when you are in the -3 Degree cruse position the relay is activated.
You are now feeding your trim motor with 9 volts and this will slow your trim motor down enough for “Fine Feathering”.
<![if !supportLists]>6) <![endif]>So when your flap switch is in the Off or (ON) position your relay will be closed and feeding 14volts to the trim motor.
When your flaps are in the ON position (Normal Cruse -3 degrees) your relay is active and switches the power to 9volts for your trim motor speed reduction.
Works like a dream.
Costs about $20.
$10 for the Double Pole On Off (ON) toggle switch
$5 for the 12v/14v relay (Fog light, horn, etc relay) Checker auto
$3 for the voltage regulator Radio Shack or Fry’s
$2 for the capacitor Radio Shack or Fry’s
Optional computer fan 3 wire plug to plug the voltage regulator into for easy termination $.99. Radio Shack or Fry’s
Jim Villani
Kit# 41084
164.3 hours
Flying 11 months
Jim(at)JimVillani.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Thursday, December 05, 2013 7:49 AM
Subject: RE: Re: RV 10 Aileron Trim
I would like to know also as I have the identical setup as John. Thanks!
0123456789012345678
Bob Turner
Posted: Thu Dec 05, 2013 11:23 am Post subject: Re: RV 10 Aileron Trim easy fix... |
A few thoughts.
I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously.
If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch.
I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like.
_________________ Bob Turner
RV-10 QB |
Bajajim
Posted: Thu Dec 05, 2013 6:51 pm Post subject: RV 10 Aileron Trim easy fix... |
You don’t have a separate "Cut off switch" for flap motor?
Put it in the Minus 3 position then turn it to off (center position) still
works at full speed...
It is On "top position" Off "Middle position" (On) "bottom position."
It stalled because you didn’t use a capacitor...
And if the Pulse Modulator fails?..
I like the KISS plan...
Keep it simple...
Jim Villani
Cell: (702) 379 5524
Fax: (702) 946-1185
Email: Jim(at)Sold702.com
Posted: Fri Dec 06, 2013 9:10 am Post subject: RV 10 Aileron Trim easy fix... |
Since I'm not there yet, is the flap speed really a 'problem' worth all
this trouble? Is the flap position 'critical' for safe operation?
Linn
On 12/5/2013 2:23 PM, Bob Turner wrote:
A few thoughts.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=414938#414938
Checked by AVG - www.avg.com
Tim Olson
Posted: Fri Dec 06, 2013 9:18 am Post subject: RV 10 Aileron Trim easy fix... |
Flap speed is not a problem. Elevator trim speed is definitely a
problem in cruise,
and I'd call it critical for safe operation that the speed be reduced
above about
110kts.
On 12/6/2013 11:09 AM, Linn Walters wrote:
all this trouble? Is the flap position 'critical' for safe operation?
Linn
> A few thoughts.
> Bob Turner
> RV-10 QB
Bob Turner
Posted: Fri Dec 06, 2013 9:25 am Post subject: Re: RV 10 Aileron Trim easy fix... |
I think you mis-read, this post is about pitch trim motor speed, not flap speeds. One poster has tied a change in trim speed to his flap position, others are using a speed sensitive device (safe trim).
Yes, the trim speed as it comes from Vans is about right for takeoff and landing but too fast for cruise.
Edit: Tim answered while I was typing.
RV-10 QB |
jdriggs49(at)msn.com Guest
Posted: Fri Dec 06, 2013 9:42 am Post subject: RV 10 Aileron Trim easy fix... |
I've not found the trim speed to be that much of a problem. I just have 'bumped' the hat switch in the direction it needs trim. At least that's the way it works on the -10 I've flown. My suggestion is to see how your plane operates and then make changes as needed. There may be some variations between individual systems and or operator desires.
| Quote: | Date: Fri, 6 Dec 2013 12:09:57 -0500
To: rv10-list@matronics.com
Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix..
--> RV10-List message posted by: Linn Walters <flying-nut@cfl.rr.com>
Linn
> --> RV10-List message posted by: "Bob Turner" <bobturner@alum.rpi.edu>
> A few thoughts.
> Bob Turner
> RV-10 QB
> No virus found in this message.
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * AeroElectric www.aeroelectric.com
_-= * The Builder's Bookstore www.buildersbooks.com
_-= * HomebuiltHELP www.homebuilthelp.com
_-= * My Pilot Store www.mypilotstore.com
_-= * Race Consulting www.mrrace.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
Posted: Fri Dec 06, 2013 9:50 am Post subject: RV 10 Aileron Trim easy fix... |
Thanks Bob, getting old sucks!!!
So, to continue on with the thread, why not install a PW control as you
suggested or run the trim off 6V?
Linn
On 12/6/2013 12:25 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=414984#414984
rene(at)felker.com Guest
Posted: Fri Dec 06, 2013 9:54 am Post subject: RV 10 Aileron Trim easy fix... |
I have not had a problem. I did put in the safety trim system so the most I can do is 3 seconds at a time. I think 3 seconds at cruse could lead to a little bit of challenge, but not impossible to handle.
Rene' Felker
N423CF
801-721-6080
Sent: Friday, December 06, 2013 10:42 AM
Subject: RE: Re: RV 10 Aileron Trim easy fix...
From: flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)
Subject: Re: Re: RV 10 Aileron Trim easy fix...
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
Linn
> --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
> A few thoughts.
> Bob Turner
> RV-10 QB
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.matronics.com/contribution">http://www.matronics.com/cBrowse, Chat, FAQ,<br= --> http://www.matronichref="http://forums.matronics.com">http://forums.matronics.com
0123456789012345678
Bajajim
Posted: Fri Dec 06, 2013 9:55 am Post subject: RV 10 Aileron Trim easy fix... |
I use to bump my hat also with limited control.
With the speed reduction in cruse position your adjustment is so fine it is almost like an altitude hold.
A 30% reduction in speed really makes a difference in feathering the trim.
Jim Villani
Kit# 41084
Sent: Friday, December 06, 2013 9:43 AM
Linn
> A few thoughts.
> Bob Turner
> RV-10 QB
0123456789012345678
Tim Olson
Posted: Fri Dec 06, 2013 9:57 am Post subject: RV 10 Aileron Trim easy fix... |
Danny,
This isn't an issue of how easy it is to trim, this is an issue of safety.
Yes, bumping it for a fraction of a second will indeed make it trim reasonably
slow and you can indeed use it that way.
The issue of safety is what happens when you accidently hit the switch.
Even as early as my flyoff period, I had a clipboard hit the trim hat,
and within a couple seconds I was in a hard nose-up climb. I did some testing
later after adding safety trim to see just how bad it gets, and really if you
have anything (ipad, book, checklist, chart, person) lay on that switch for a
full second or more, it gets scary and for much longer than a second you
could get close to having g-rating problems perhaps. So best to just
do speed reduction for sure. The side benefit is that you can then even
have MORE fine control over trim, because that same bump you use now
is reduced to maybe 1/8th what it is.
On 12/6/2013 11:42 AM, Danny Riggs wrote:
[quote] I've not found the trim speed to be that much of a problem. I just have 'bumped' the hat switch in the direction it needs trim. At least that's the way it works on the -10 I've flown. My suggestion is to see how your plane operates and then make changes as needed. There may be some variations between individual systems and or operator desires.
> To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
> --> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com> (flying-nut(at)cfl.rr.com)
> Linn
> > --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu> (bobturner(at)alum.rpi.edu)
> > A few thoughts.
> > Bob Turner
> > RV-10 QB
Bajajim
Posted: Fri Dec 06, 2013 10:05 am Post subject: RV 10 Aileron Trim easy fix... |
I concur 100%.
That is what drove me to slow it down, a sudden bump and you are in another world…
Jim Villani
Kit# 41084
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson
Sent: Friday, December 06, 2013 9:57 AM
Danny,
Linn
> A few thoughts.
> Bob Turner
> RV-10 QB
http://www.matronic=================[/b][/quote]http://forums.matronics.com[/url]=====[/b][b]
Posted: Fri Dec 06, 2013 12:41 pm Post subject: RV 10 Aileron Trim easy fix... |
I have the flap controller install just as Van's provides. Works just fine.
Flap position indication is a simple look out the window.
I have the two speed safety trim controller and I recommend it. After 10
years of flying an 8A with just the single speed elevator & aileron trim I
am used to not having the slow trim speed option - so I rarely use it in the
RV-10.
Carl
Bob Turner
Posted: Fri Dec 06, 2013 3:03 pm Post subject: Re: RV 10 Aileron Trim easy fix... |
| Tim Olson wrote: |
[b] |
Because of this I did not put a top hat on the right side (there is a panel rocker switch for when I fly from the right seat).
RV-10 QB |
Posted: Fri Dec 06, 2013 5:12 pm Post subject: RV 10 Aileron Trim easy fix... |
I wired both stick in parallel ..... with a switch in the co-pilot
ground to disable that stick.
All the other buttons on the co-pilot side can cause consternation to
the pilot!!!!
Linn
On 12/6/2013 6:03 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=415016#415016
Posted: Fri Dec 06, 2013 5:29 pm Post subject: RV 10 Aileron Trim easy fix... |
Yep - I did the same except the switch on the panel controls the common
ground such that the pilot or co-pilot trim top hat and flaps work. This
way if the pilot stick switch breaks (as on sticks shut) moving the panel
toggle switch to the co-pilot position isolates the fault as well as
restores trim/flap control buy using the co-pilot grip switches.
Carl
Posted: Fri Dec 06, 2013 5:41 pm Post subject: RV 10 Aileron Trim easy fix... |
I like that idea! Simple switch change. Thanks.
Linn
On 12/6/2013 8:28 PM, Carl Froehlich wrote:
Carl
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Sat Dec 07, 2013 7:13 am Post subject: RV 10 Aileron Trim easy fix... |
My aileron trim consists of switching the fuel selector to to heavy side. Works every time and no runaway issues.
N312F - flying again after the bird strike repairs!
Jim C
On Dec 6, 2013, at 12:25 PM, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
_________________ RV-10 -> N312F - Flying as of 12/2008 |
johngoodman
Posted: Tue Dec 10, 2013 7:45 am Post subject: Re: RV 10 Aileron Trim easy fix... |
The Vertical Power systems have trim speeds built in, and runaway cutoff as well.
Bob Turner
Posted: Tue Dec 10, 2013 9:39 am Post subject: Re: RV 10 Aileron Trim easy fix... |
Unfortunately VP has just been sold. Remains to be seen if the new company will continue production and support for E-AB equipment.
RV-10 QB |
