Cockpit heater
martinburns
PostPosted: Sat Dec 07, 2013 2:58 pm    Post subject: Cockpit heater Reply with quote
Has anyone tried using the coolant to run a cabin heater?
We have carburettor heaters fitted, so it would be relatively simple to plumb a heater into the same circuit.
Martin Burns
G-OJHL
rparigoris
PostPosted: Sat Dec 07, 2013 6:44 pm    Post subject: Cockpit heater Reply with quote
Hi Martin
"Has anyone tried using the coolant to run a cabin heater?"
Cliff Shaw did:
http://www.europaowners.org/main.php?g2_itemId=25675
Ron Parigoris [quote][b]
avgashead(at)btinternet.c
PostPosted: Sun Dec 08, 2013 10:44 am    Post subject: Cockpit heater Reply with quote
Chris Piper from CKT engineering (they who make our exhausts) contacted me recently to ask if he could use my mono as a donor to develop a cabin heater. I believe he intends to sleeve the silencer as a warm air supply. Will post progress when work starts.
Richard Scanlan
G-CEIW
Sent from my iPad
Martin Burns
G-OJHL
http://forums.matronics.com/viewtopic.php?p=415078#415078
frans(at)privatepilots.nl
PostPosted: Tue Dec 10, 2013 2:42 am    Post subject: Cockpit heater Reply with quote
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
starts.
That's quite insane for an aircraft with a liquid cooling system.
Using the exhaust to heat has always been considered something to
avoid unless there are no other possibilities, like in an air cooled
Volkswagen Beetle or an air cooled Lycoming engine. It is avoided
because due to the high surface temperature it always gives a bad
smell and there is the risk of CO poisoning. Why not using the coolant
or the radiator exit air for cabin heating? It is one of the
advantages of the Rotax engine, not having to resort to exhaust based
cabin heating.
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=wXFU
-----END PGP SIGNATURE-----
grahamsingleton(at)btinte
PostPosted: Tue Dec 10, 2013 3:02 am    Post subject: Cockpit heater Reply with quote
Frans
absolutely right!
Graham
Sent: Tuesday, 10 December 2013, 10:41
Subject: Re: Cockpit heater
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
Hash: SHA1
starts.
cabin heating.
Frans
=wXFU
-----END PGP SIGNATURE; -- Please Support Your Lists This p://www.matronics.com/contribution" target="_blank">http://www.matronics.nbsp; /www.matronics.com/Navigator?Europa-List" target="_blank">http://www.matr=======
