KeysFox
Posted: Mon Dec 16, 2013 8:46 pm Post subject: Kitfox touring trailer measurements |
Dan,
I have two trailers.
Since we started towing with a small motorhome, I currently use the
shorter 9' wide trailer that is 24 feet long inside, no room for camper
features in this trailer. The plane is about 22 feet long folded leaving
about one and a half feet between wing tips and front of trailer. I
position the plane with about 6 inches from spinner to ramp door at the
back of the trailer. Since the tail is up on the tail wheel trailer I can
crouch down under the wing tips to get behind the plane and access the
stuff stored there. This trailer weighs in at 3900 lbs empty and has dual
3500 lb axles so with a gross weight of 7,000 lbs there is plenty of left
over weight carrying capacity.
Initially I bought an 8'6" wide trailer with a 27 foot long inside
dimension so I could have room for some camper features up front (before
the motorhome). In this case I was loading the plane nose first instead of
tail first. which means easy access around the nose of the plane to
bench/bunk, marine toilet, collapsible shower, AC unit, and generator.
Empty weight was just over 4,000 lbs with dual 3,500 lb axles.
In either case there is good room to take the engine cowl off and work on
it as well as work in the cabin area while the plane is loaded.
There you have it, a hanger, a shop with parts, tools, and spares storage,
serving as a toy hauler and even as a camper. Can't help but smile.
BJ
BJ,
How long is your trailer ? Much room from tip to tail inside?
Sent from my iPad
> On Dec 15, 2013, at 9:07 PM, "SkySteve" <Wilson(at)REinfo.org> wrote:
> Pete,
> Yes, great question.
> BJ,
> Great answer(s), on both issues. That helps us other old timers. Having
> pulled many farm type trailers down the road most of my life I have
> learned the best approach is to just keep going down the road like you
> know all the laws and you are most often left alone.
> Steve Wilson
> Huntsville, UT
> Kitfox Model 1- 85DD
> 912A / 3 Blade Warp Drive
> Convertible Nosewheel & Tailwheel
> http://forums.matronics.com/viewtopic.php?p=415641#415641
_________________ B Jones
N154K
443-480-1023 |
KeysFox
Dan,
BJ
BJ,
Sent from my iPad
> Pete,
> BJ,
> Steve Wilson
> Huntsville, UT
N154K
443-480-1023 |
dan(at)rdan.com Guest
Posted: Mon Dec 16, 2013 10:50 pm Post subject: Kitfox touring trailer measurements |
Excellent information! Your livin the dream!!
Dan
7SS building
WA
Sent from my iPad
KeysFox
Posted: Tue Dec 17, 2013 7:52 am Post subject: Kitfox touring trailer measurements |
Join the FUN!
Dan
7SS building
WA
Sent from my iPad
> On Dec 16, 2013, at 8:45 PM, bjones(at)dmv.com wrote:
> leaving
N154K
443-480-1023 |
