DAG
Joined: 08 Apr 2011 Posts: 3 Location: Cape Town South Africa
Posted: Sun Dec 22, 2013 10:41 pm Post subject: Yak 52 Radio |
I have recently got my aircraft back from its annual inspection.The radio was working fine but now it is only transmitting carrier wave.
Any suggestions will be appreciated.
ssssskippy
Posted: Sun Dec 22, 2013 11:26 pm Post subject: Yak 52 Radio |
Hi
In my own opinion something is unplugged betwin the mike and the radio...,,
Olivier V
Posted: Mon Dec 23, 2013 4:45 am Post subject: Yak 52 Radio |
Agree with Olivier. First, why not try transmitting from the rear
cockpit? If the rear cockpit is also not working, then what I would
suggest is discuss the situation with your mechanic with the
understanding you are trying to see if something was accidentally
disconnected or broken while rooting around inside the cockpit. I was
told many, many years ago when something is not working after someone
worked on the airplane, always go back to the last thing that was worked
on first.
You could also slide the Baklan 5 radio (the VHF radio) out of the radio
rack and re-seat it, making sure you tighten the thumb nuts completely
when re-seating it. In fact, ask the mechanic if he removed the "box"
from the rack during the inspection.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 12/23/2013 1:26 AM, ssssskippy wrote:
Hi
Olivier V
> http://forums.matronics.com/viewtopic.php?p=416096#416096
DAG
Posted: Mon Dec 23, 2013 6:09 am Post subject: Yak 52 Radio |
Thanks for the suggestions so far.I have tried transmitting from the rear cockpit and have tried using different headsets.
The mechanic says he did not touch any radio equipment.
On Mon, Dec 23, 2013 at 2:43 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote] --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Agree with Olivier. First, why not try transmitting from the rear cockpit? If the rear cockpit is also not working, then what I would suggest is discuss the situation with your mechanic with the understanding you are trying to see if something was accidentally disconnected or broken while rooting around inside the cockpit. I was told many, many years ago when something is not working after someone worked on the airplane, always go back to the last thing that was worked on first.
You could also slide the Baklan 5 radio (the VHF radio) out of the radio rack and re-seat it, making sure you tighten the thumb nuts completely when re-seating it. In fact, ask the mechanic if he removed the "box" from the rack during the inspection.
Dennis
A. Dennis Savarese
[url=tel:334-285-6263]334-285-6263[/url]
[url=tel:334-546-8182]334-546-8182[/url] (mobile)
www.yak-52.com
Skype - Yakguy1
| Quote: | --> Yak-List message posted by: ssssskippy <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
Hi
Olivier V
Le 23 déc. 2013 à 07:41, "DAG" <robdayton(at)gmail.com (robdayton(at)gmail.com)> a écrit :
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
rget="_blank">http://www.matronics.com/Navigator?Yak-List
GeorgeCoy
Posted: Mon Dec 23, 2013 6:21 am Post subject: Yak 52 Radio |
Tru messing with the swich panel on the original audio panel. As I remember both little switchjes need to be in the up position. By the way, does the intercom work OK?
George
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Robert Dayton
Sent: Monday, December 23, 2013 9:09 AM
To: yak-list(at)matronics.com
Subject: Re: Yak 52 Radio
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Hi
Olivier V
--> Yak-List message posted by: "DAG" <robdayton(at)gmail.com (robdayton(at)gmail.com)>
le, List Admin.
01234567890123456
Have you been told by whoever is receiving your transmission there is no audio and only carrier? Or is it that you have no sidetone in your headsets?
Dennis
| Quote: | A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1 | On 12/23/2013 8:08 AM, Robert Dayton wrote:
[quote] Thanks for the suggestions so far. I have tried transmitting from the rear cockpit and have tried using different headsets.
| Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Hi
Olivier V
le, List Admin.
| [b]
DAG
Posted: Mon Dec 23, 2013 6:57 am Post subject: Yak 52 Radio |
I was told by other aircraft that they were only receiving carrier wave.Also no side tone.
Intercom is working fine.
On Mon, Dec 23, 2013 at 4:20 PM, George S. Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)> wrote:
George
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Robert Dayton
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Hi
Olivier V
le, List Admin.
0 12 345678 901 2345 6
7
Posted: Mon Dec 23, 2013 7:05 am Post subject: Yak 52 Radio |
OK. I would remove the Baklan 5 radio from the radio rack and try reseating it.
The radio may have coincidentally gone T.U. If you know anyone with a Yak 52, try swapping out the radio and then test it.
Dennis
334-285-6263
www.yak-52.com
Skype - Yakguy1 | On 12/23/2013 8:57 AM, Robert Dayton wrote:
[quote] I was told by other aircraft that they were only receiving carrier wave. Also no side tone.
George
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
Hi
Olivier V
le, List Admin.
1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7
8
| 9 [b]
LawnDart
Posted: Mon Dec 23, 2013 1:22 pm Post subject: Re: Yak 52 Radio |
Common problem. All of our "long-term" Balkan-5 radios have experienced this problem. In each case, we sent the radio to US expert and had them repaired.
Mine failed in flight. Return to home base was interesting.
