djaflyact
Posted: Thu Dec 26, 2013 8:45 pm Post subject: Mod 78 Christmas Miracle |
It seems that there is a Santa Claus! My airplane is back together after about 3 months of mod 78 work. I have attached a picture. I have a three day trip tomorrow, so the first flight should be on Monday.
The aileron quick connects seem to be clear of everything. The CS08 brackets clear everything. I am not sure if the flush screws were definitely needed, but the extra margin helps. It certainly helps in installing the wings. I was able to get them on the airplane by myself, which is a good sign.
The angles all seem correct, as far as I can tell. Just a few more parts left (wheel fairing) and that will make the test flight possible. I ran the engine today and it ran perfectly.
I'm planning a simple flight test. Maneuvers, stalls and a wind-up turn to at least 3 Gs. After that, pull the wings once again and inspect.
I also need to reprogram the airspeed limitations in the Dynon Skyview. Does anyone know what they are? Vmo is 127 knotrs, I think. Anyone know what maneuvering speed is? Top of the yellow?
Our long national nightmare i almost over!
Dave
A227
Mini U2
| Airplane finally ready to fly after 3 months of mod 78 |
31.24 KB |
2718 Time(s) |
| Engine run pre flight - everything perfect |
131.41 KB |
2718 Time(s) |
alan.twigg775(at)gmail.co Guest
Posted: Fri Dec 27, 2013 9:41 am Post subject: Mod 78 Christmas Miracle |
Dave, Did you use NAS 517-2-9 screws for CS08, if so I will take your earlier advice and order -8,-9 and -10.
This blow by blow of yours is great, it needs putting together in a 'how to' to supplement Mod 78.
I also bought a remote camera, as well as being helpful it showed me how much I need to clean up before I fly.
Alan Twigg
Kit 463
On Fri, Dec 27, 2013 at 4:45 AM, djaflyact <djaflyact(at)gmail.com (djaflyact(at)gmail.com)> wrote:
[quote] --> Europa-List message posted by: "djaflyact" <djaflyact(at)gmail.com (djaflyact(at)gmail.com)>
Dave
A227
Mini U2
http://forums.matronics.com/viewtopic.php?p=416237#416237
http://forums.matronics.com//files/pre_flight_142.jpg
http://forums.matronics.com//files/engine_run_pre_flight_203.jpg
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
target="_blank">http://www.matronics.com/Navigator?Europa-List
