fvalarm(at)rapidnet.net Guest
Posted: Fri Feb 14, 2014 3:49 pm Post subject: Fat wires and plumber's solder |
Bob,
I am in the process of integrating a power input module (Cole Hersee 11041)
see http://www.colehersee.com/home/item/cat/248/11041/ and am wondering
about the best method for connecting a heavy wire to it. The power port is
sized for "up to" 0 AWG wire but the biggest I want to connect to it is 4 or
maybe 2 AWG. The 11041 uses a brass solder socket and is way too big for 2
awg wire. What is the best way to fill up excess space in the socket? I
don't want to simply fill it with solder. Maybe some short wire segments
same length as the depth of the socket?
The second question comes to solder. Normally we don't solder much on
aircraft (at least I haven't) and all of my solder rolls at work are very
small diameter for electronics with flux inside. If I was to use this
solder, I would probably use a ton to tin and drown the heavy wire into the
brass cup. So I had a look at some plumbing solder that I had left over
from a plumbing project. I recall that plumbing solder is not to be used
for electrical connections (corrosive?) but it is nice and thick (maybe
3/16ths) and the label says "LEAD FREE" and "SILVER". I can understand that
for potable water systems, lead free is a good idea but is it really lead
free and is it really silver solder? Most importantly, can this be used for
a beefy electrical solder job?
It might be a good time to have a discussion on plumbing solder and why it
should or should not be used for electrical stuff.
Bevan
ceengland7(at)gmail.com Guest
Posted: Fri Feb 14, 2014 5:33 pm Post subject: Fat wires and plumber's solder |
On 2/14/2014 5:48 PM, B Tomm wrote:
Bob,
Bevan
Before you use it, you might want to price what it will cost you to
replace it. Real silver solder does have a significant percentage of
silver in it.
Bob has a 'comic book' showing how to fill out the space in the crimp
ring with short lengths of copper wire. Basically, cut short (~1/2")
pieces of #12 or #14 solid wire (cut it from household 'romex' wiring),
sharpen one end, & drive it into the strands of your cable in the open
end of the connector until it's filled tight with copper. Then solder.
It's usually plumbing flux that's corrosive, not the solder itself,
unless you have some with flux made into the solder (unlikely with
plumbing solder). However, one issue besides the price of silver solder
is that it usually requires a higher temperature, so you're more likely
to melt your insulation.
Charlie
raymondj(at)frontiernet.n Guest
Posted: Fri Feb 14, 2014 6:13 pm Post subject: Fat wires and plumber's solder |
My experience with lead/tin plumbing solder is that it is frequently available in "acid core" configuration in 1 and 5 lb. spools. The lead free plumbing solder, which is typically solid wire, is a 95% tin/ 5% antimony alloy. It does have a higher melting point than the typical lead/ tin alloys, with or without an "acid core". How it's melting point compares with silver bearing solder, I don't know. I don't know what it's electrical properties are either.
| Quote: | Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine | On 02/14/2014 07:32 PM, Charlie England wrote:
[quote]--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com> (ceengland7(at)gmail.com)
| Quote: | --> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net> (fvalarm(at)rapidnet.net)
Bob,
Bevan
| Before you use it, you might want to price what it will cost you to replace it. Real silver solder does have a significant percentage of silver in it.
Bob has a 'comic book' showing how to fill out the space in the crimp ring with short lengths of copper wire. Basically, cut short (~1/2") pieces of #12 or #14 solid wire (cut it from household 'romex' wiring), sharpen one end, & drive it into the strands of your cable in the open end of the connector until it's filled tight with copper. Then solder.
It's usually plumbing flux that's corrosive, not the solder itself, unless you have some with flux made into the solder (unlikely with plumbing solder). However, one issue besides the price of silver solder is that it usually requires a higher temperature, so you're more likely to melt your insulation.
Charlie
Posted: Sat Feb 15, 2014 5:57 am Post subject: Fat wires and plumber's solder |
Bob,
about the best method for connecting a heavy wire to it. |
See http://tinyurl.com/m85ohwx
| Quote: | It might be a good time to have a discussion on plumbing solder and why it
should or should not be used for electrical stuff. |
"Plumbing" solder is not a very definitive
term. Solders come in all sorts of alloys
including the modern lead-free versions. They
each have a unique set of behaviors for joining
parts.
The best-we-know-how-to-do solders are 63/37
Tin-Lead alloys popular with the electronics
industry among others.
63/37 is, perhaps not the optimum structural
alloy but it has some over-riding properties
that make it the joining material of choice
for the things we do.
Lowest melting point of all tin-lead ratios
known as 'eutectic'. This property promotes
joining with the least possible heat stress
on parts and their surrounding insulators.
Nearly zero plastic range . . . it moves
quickly between solid and liquid phases
during temperature excursions. Hence, you
have to work at it to get a 'cold' solder
joint. See Chapter 8 of The 'Connection.
When the occasional task calls for soldering
fat wires to equally fat terminals, I pull off
6 feet or so of my fine-wire, 63/37 and
fold it into a 6-8 strand, twisted bundle.
This offers a nice does of flux into the
joint while increasing the delivery rate
of solder into the melt.
Bob . . . [quote][b]
Posted: Sat Feb 15, 2014 6:02 am Post subject: Fat wires and plumber's solder |
CORRECTION: CHAPTER 9
Posted: Sat Feb 15, 2014 8:46 am Post subject: Fat wires and plumber's solder |
Thanks Bob and all,
I was concerned that 63/37 may add too much flux causing undesirable effects. Twisting is together is an excellent idea.
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Saturday, February 15, 2014 5:56 AM
Subject: Re: Fat wires and plumber's solder
Bob,
parts.
Bob . . . [quote]
Posted: Sat Feb 15, 2014 9:27 am Post subject: Fat wires and plumber's solder |
At 10:46 AM 2/15/2014, you wrote:
| Quote: | Thanks Bob and all,
Bevan |
The 'service life' of flux in electronic
solder is measured in seconds. The active
features in the chemistry evaporate pretty
quickly as they dissolve the products of
corrosion from surfaces to be joined. The
residuals do not add to the appearance
of the finished joint but it'a all on
the surface. It wipes off with a rag wetted
with lacquer thinner or acetone. I keep
cans of "carburetor cleaner" around for
spray de-greasing and de-fluxing of work
product.
But there's no risk of deleterious effects
for having left it in place . . .
gerry.vandyk(at)shaw.ca Guest
Posted: Sat Feb 15, 2014 10:17 am Post subject: Fat wires and plumber's solder |
However the acid core of structural solder would have a lasting corrosive effect on electronics. By all means be sure you use electrical solder.
The specific alloy percentages have little bearing on weather it's electronic or structural solder, the application determines what flux you need to use.
Gerry
mrspudandcompany(at)veriz Guest
rmkeith(at)gwi.net Guest
Posted: Sat Feb 15, 2014 1:51 pm Post subject: Fat wires and plumber's solder |
One thing to remember with the 95-5 Tin / Antimony Solder is that it does not fill gaps well. It was common practice when using 95/5 to flood the joint with 50/50 solder after first adding the 95/5. Another point is that real "Silver Solder" AKA "Silver Braze" has 35 of 45 % silver with the remainder being bronze and melts typically around 1100 degrees f or more. Plumbers "silver solder" is basically a 95/5 solder with a little silver so it will fill gaps better and melts around 450 f. I have used rosin core solder to tin a joint then add the plumbers silver solder to complete the connection.
Russ
jrevens
Posted: Sun Feb 16, 2014 8:17 pm Post subject: Fat wires and plumber's solder |
I believe that one thing to keep in mind is that if the solder you’re using is truly 95-5 alloy, it is not advisable to use it with brass. There is a chemical reaction in the presence of moisture that causes long-term porosity & pitting of the joint. I’m not sure, but that may be due to the antimony reacting with something in the brass.
How about the “high-tech” silver-bearing electrical solder, available from Radio Shack? I’ve been using it for a few years, believing it to be superior to the 60-40 standard. I’m sure many of us have seen older radios or other electronic equipment that suffered multiple deteriorated solder joints. I had a nice S.A.E. amp at one time that I had to re-solder just about all of the capacitor leads after it started having “issues”. I’m not sure why that happened, and it probably had more to do with the soldering technique used in manufacture rather than the solder itself. That probably doesn’t have much to do with the current discussion, but I wonder if the “high-tech” stuff might ultimately be more stable.
[b] [/b][b]John[/b][b] [/b]
[b] [/b]
_________________ John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying) |
