rparigoris
Posted: Sat Feb 08, 2014 2:57 pm Post subject: Re: Motorglider wings |
Hi Ian
Why would you need to change bungee tension between long and short wings as is hinted at from #6?
6. Undercarriage bungees. The tension had been adjusted and was now considered satisfactory. For future long wing or convertible aircraft, the manual needs to include advice about how to set the bungee tension to suit the two different configurations.
Ron Parigoris
deford.dave(at)gmail.com Guest
Posted: Sat Feb 08, 2014 3:46 pm Post subject: Motorglider wings |
Quote: | Why would you need to change bungee tension between long and short
It isn't necessary to change the tension between long and short wings, but
the difference in retraction/extension force is significant. Particularly
at higher speeds, aerodynamic forces on the flaps push them toward the
retracted position, giving a reduction in retraction force (and an increase
in extension force) toward the "down" end of the cycle. After changing from
short wings to long, I am always surprised for the first few flights that I
have to push forward on the gear lever to start it moving after releasing it
from the latched-down gate. Of course, the difference in force is minimal
near the fully retracted position. A builder of a dedicated motorglider
might choose to optimize the bungee tension differently from an airplane
with short wings only, but we did not adjust the tension when we added the
long wings to our flying short-wing XS mono.
Dave DeFord
N135TD
rparigoris
Posted: Sat Feb 08, 2014 8:07 pm Post subject: Re: Motorglider wings |
Hi Dave
Thx. for your reply about bungee tension.
It sounds like you switch back and forth between short and long wings on your XS Mono.
Did you do Mod 78? If so how did you get your flap push-rod to clear post mod 78 spars, airbrake cable and pitch cross tube?
Ron Parigoris
iancook_1(at)hotmail.com Guest
Posted: Sun Feb 09, 2014 12:41 am Post subject: Motorglider wings |
My actual solution to the difficult U/C retraction was to extend the
retraction lever handle (hand grip) so that you have a much firmer hand
hold, it was surprising just how much that minor mod helped to get over the
problem of loss of aerodynamic help from the flaps. My aircraft has flown
with both short and long wings since conversion with no obvious flap
problems/fouls, but I will have a much closer look next time I change wings.
Ian cook
G-CBHI
Posted: Sun Feb 09, 2014 1:01 am Post subject: Motorglider wings |
I loaned my A/C to the Europa factory to do the modification and obtain the
first UK Permit to Fly just as the wing spar broke during structural
testing, it was therefore the first completed UK example post the wing
strengthen Modification. Europa were jointly in charge of developing the
Flight Test Programme, as agreed with the LAA. That is why I do not have
the full background to all of the engineering changes. I am just trying to
drive the completion of the modification programme through to get the Permit
to Fly and then hopefully to obtain the increase in all up mass. All this
started way back in September 2009. So it has been a real game of patients!
Ian
G-CBHI
Posted: Sun Feb 09, 2014 6:04 am Post subject: Motorglider wings |
Ron,
We did switch back and forth between short and long wings, accumulating 90
hours on the long wings, before we heard about the Mod 78 structural
problems and quit using them.
The long wings would not fit into the fuselage of N135TD with the taller
spar tangs of Mod 78. Building according to the current instructions 15
years ago (modified shortly thereafter), our tank is set low enough that the
"shelf" at the top front interfered with the short wing spar tangs. I
heated the tank locally to deform it enough to pass the starboard tang, and
then had to do it again for the slightly taller long wing spars. We would
have to cut open the cockpit module and replace the tank in order to gain
enough clearance for the modified spars, which we are not prepared to do.
Since the long wings are of no use to us, we would be happy to sell them at
just about any price to someone who could use them (after applying Mod 78,
of course).
Dave DeFord
N135TD
Quote: | It sounds like you switch back and forth between short and long wings
on your XS Mono.
Ron Parigoris
alan.twigg775(at)gmail.co Guest
Posted: Sun Feb 09, 2014 9:38 am Post subject: Motorglider wings |
Bonded wing fittings today, off to pray and drink beer. Will look on Tuesday.
Angles all seem ok.
Alan
[quote] On 8 Feb 2014, at 21:22, Ian Cook <iancook_1(at)hotmail.com> wrote:
Hi Jim,
Mine is a mono with retro fit MG wings but not aware of foul you
describe. Still trying to find the details behind 17 myself.
Ian
Posted: Sun Feb 09, 2014 9:43 am Post subject: Motorglider wings |
Would have loved to speak one year ago having just completed my long wings.
Like Dave I have removed the aileron quick connects to fit countersunk bolts and skim the edges otherwise although tight they fit, just.
Alan
Quote: | On 9 Feb 2014, at 14:03, "David DeFord" <deford.dave(at)gmail.com> wrote:
Ron,
of course).
Dave DeFord
N135TD
> on your XS Mono.
> Ron Parigoris
djaflyact
Posted: Sun Feb 09, 2014 2:20 pm Post subject: Re: Motorglider wings |
Lots of topics here. Mine is registered as an aircraft/motorglider. I don't intend to use the short wings, so I don't have the issue with the flap rod. I will be getting some glide performance numbers once we get back to good weather.
I found that at glide speed, the back of the wingtips had turbulent flow and there was even reversed flow. I think they are drag at that point. I have removed the outer portion of the tips that were not producing lift at glide speed. Still not sure what to do about the wingtips.
My gear has the fairing and is very easy to operate. There is no flap rod attached to it, of course.
With the 914 engine, i get about 150 knots TAS at 17,500 feet. It has easily made the flight from Minden, NV to OshKosh in one day - including a 3 hours enroute stop to time the arrival at OSH.
Dave
budyerly(at)msn.com Guest
Posted: Sun Feb 09, 2014 5:24 pm Post subject: Motorglider wings |
Just a note on sink rates in 419PL:
From my 1000 miles in the MG (copies in Europa Flyer or my website www.customflightcreations.com accessories and tips look under techniques).
Sink Rates observed: Engine off, prop feathered from one test flight:
90 Kts 400fpm
80Kts 300fpm
70 Kts 300 fpm
65 Kts 250 fpm
55 Kts 350 fpm trimmed nearly full aft.
Since Mod 78 makes the spar the same height from root spar to the tip of the spar, it should not be a major problem normally. Careful construction only thickens the spar about 1/16 of an inch. I am sorry Dave, that your tank was put in too low. If the interior is not hard to remove, consider moving the tank up. Yes its a mess but in a week it could be done. I know it is easy for me to say, as one mistake and the cost of a new tank gets figured in makes the job a real knuckle biter.
I do not do tech support for Europa any longer, but if you come to Sun 'n Fun (Site 33 this year) you can look over what we have done to ensure the Mod 78 spar clears controls, includes a spar cup/support for rigging ease, and I'll show how to remove the crosslink bolts and add countersunk screws which preserves all the structure. If you can't make the show, then email me off line and I'll send you what I have.
I supplied Europa with drawings on modifying the flap push rod to clear the spars as that is a real problem on the mono. Trigear is a piece of cake. Keep the spars thin and it will work.
The extra 100 pounds the glider wing adds can make the plane a single seat only aircraft unless you built light. It does move right along if you go really high, but below 10,000 MSL it is basically an economical 120 knot bird. You can really stretch the range with the long wings.
Once the health becomes a concern, it is also quite nice to fly as a glider with no medical.
Bud Yerly
Quote: | From: deford.dave(at)gmail.com
Subject: RE: Re: Motorglider wings
Date: Sun, 9 Feb 2014 06:03:17 -0800
--> Europa-List message posted by: "David DeFord" <deford.dave(at)gmail.com>
Ron,
of course).
Dave DeFord
N135TD
> on your XS Mono.
Posted: Sun Feb 09, 2014 10:36 pm Post subject: Motorglider wings |
Bud, details of post Mod 78 Spar cup(s) would be most welcome. Wing root fittings bonded on yesterday, I removed the aileron cranks as I need to trim them and have my countersunk bolts ready as Dave Anderson and you describe. Next job after removing wings and drilling + bolting the fittings is to countersink the Aileron cranks. Any advice on doing this in sittu would be welcomed . Regards
Alan Twigg
90 Kts 400fpm
80Kts 300fpm
70 Kts 300 fpm
65 Kts 250 fpm
Bud Yerly
> To: europa-list(at)matronics.com
> Ron,
churchy
Posted: Tue Feb 11, 2014 3:57 am Post subject: Motorglider wings |
Bud
Thanks for this info - I assume these were all at 1,370 lbs? I see 419PL is a trigear so I assume we can expect slightly better than -250 fpm from a mono set up at the same weight?
regards
Richard
90 Kts 400fpm
80Kts 300fpm
70 Kts 300 fpm
65 Kts 250 fpm
Bud Yerly
> Ron,
Posted: Sat Feb 15, 2014 1:14 pm Post subject: Motorglider wings |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Richard,
I would assume the mono with wheel retracted would be slightly better. Those three sticks can generate a bit more drag even with wheel pants.
Bud
Posted: Sat Feb 15, 2014 1:15 pm Post subject: Motorglider wings |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Alan,
I'll get back with you off line. Had a go at the cancer center and clients in the shop which has tied me up. I have a bit of time to go in and see if I have some info. / photo's.
Bud
