Kelly McMullen
Posted: Sat Feb 15, 2014 9:19 pm Post subject: Forward baffle & governor cable |
Unless you are seeking a show award, should be easy to place a doubler on the underside to cover the hole and move on.
On Sat, Feb 15, 2014 at 10:02 PM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Got it, thanks Bill--did you use the Vans supplied bracket underneath per plans? Or something else? I see you placed the cable bracket across the bend for positioning? I may also have to place the bracket on the other side of the bend, not sure if I have to modify it or not.
But it looks like I'll be ordering a new front baffle--another delay...
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=418775#418775
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
schmoboy
Posted: Sun Feb 16, 2014 6:09 am Post subject: Forward baffle & governor cable |
That's exactly what I did after misplacing the hole. Here's a pic:
http://www.flickr.com/photos/stephensville/8500973713/in/set-72157627874989973
Enlarged the misplaced hole and added doubler on to. Looks fine
-Sean #40303 (still 90% done, 90% to go)
| Quote: | Kelly McMullen <mailto:apilot2(at)gmail.com>
February 15, 2014 at 11:19 PM
