tomhanaway
Posted: Thu Mar 20, 2014 4:19 am Post subject: How to determine drill bit sharpness? |
Working on drilling longerons. Any general guidelines for determining when a #40 has lost its edge?
10, 50, 100. 300 holes?
_________________ RV-10. Built and sold
RV-8a. Building |
halbenjamin101(at)gmail.c Guest
Posted: Thu Mar 20, 2014 5:41 am Post subject: How to determine drill bit sharpness? |
Hi Tom,
I think you should be able to get a few hundred pretty easily. When in doubt, try a new bit to see how it compares. When it starts taking significantly longer to drill a hole, change it out.
Hal Benjamin
RV-4 Flying
Sent from my iPad
| Quote: | On Mar 20, 2014, at 8:19 AM, "tomhanaway" <tomhanaway1(at)gmail.com> wrote:
RV-8a. Building
http://forums.matronics.com/viewtopic.php?p=420665#420665
bifft(at)xmission.com Guest
Posted: Thu Mar 20, 2014 7:21 am Post subject: How to determine drill bit sharpness? |
On Thu, 20 Mar 2014, tomhanaway wrote:
Go by how it drills. If you are getting long spirals of aluminum it is
sharp. If you are getting small chips it is dull.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 baffling.
kenbrooks(at)charter.net Guest
Posted: Fri Mar 21, 2014 1:23 pm Post subject: How to determine drill bit sharpness? |
The other responders have it right - if you don't think it's cutting through fast enough, it's probably dull... try a new one. For those of you (like me), always looking for an excuse to buy another tool, you might invest $50 on a Drill Doctor bit sharpener. Mine works great and it saves trips to the DIY store aviation aisle. Just follow the instructions that come with it closely and practice with a few old broken bits if you have any. The cam action puts a beautiful, sharp edge on the bit, perfectly beveled. I give it four and a half stars, and looks swell on the tool shelf.
http://www.drilldoctor.com/drill-sharpeners-and-accessories/drill-sharpeners/drill-doctor-model-350x.html
Ken Brooks
Really Slow RV-8 QB
Pushing to the end!
jluckey(at)pacbell.net Guest
Posted: Fri Mar 21, 2014 2:11 pm Post subject: How to determine drill bit sharpness? |
I have a Drill Doctor DD500X and agree w/ Ken - it is very handy. It is really great for bits greater than about 3/16 in. (and those are the more expensive bits so being able to re-sharpen them is great). But I don't have much luck w/ drills smaller than 3/16 in.
When it comes to #30 or #40 drill bits, I buy them in the jobber 5-pack from my local industrial supply. IIRC it's usually around $1 per bit. Nothing beats the factory edge on an industrial-quality drill bit.
-Jeff
PS - I recommend the DD500X even thought it's more expensive (you can find them on sale for around $100). It has a jig that makes it quick & easy to position the bit to be sharpened in the sharpening mandrel. It only takes a couple of seconds to get the bit chucked-up in the mandrel correctly. I don't think the lower models have this feature. It's worth the extra 50 bucks.
To: rv-list(at)matronics.com
Sent: Friday, March 21, 2014 2:22 PM
Subject: RV-List: Re: How to determine drill bit sharpness?
--> RV-List message posted by: Ken Brooks <kenbrooks(at)charter.net (kenbrooks(at)charter.net)>
http://www.mat=====================
