rvdave
Posted: Fri May 09, 2014 12:30 pm Post subject: Airflow Performance install |
Wondering if anyone has photos of the AP throttle body and red cube install--and also how throttle and mixture cables are mounted? Would be greatly appreciated.
_________________ Dave Ford
Cadillac, MI |
rleffler
Posted: Fri May 09, 2014 1:47 pm Post subject: Airflow Performance install |
I should have some on my build site. Mykitlog.com/rleffler
Although, my throttle body is horizontal, which is atypical of most RV-10 installations.
Sent from my iPad
| Quote: | On May 9, 2014, at 4:30 PM, "rvdave" <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=423088#423088
_________________ Bob Leffler
N410BL - Phase I
rvdave
Posted: Sat May 10, 2014 3:05 pm Post subject: Re: Airflow Performance install |
Yes I do have the vertical induction.
Cadillac, MI |
rnewman(at)tcwtech.com Guest
Posted: Sat May 10, 2014 3:28 pm Post subject: Airflow Performance install |
Make sure you read the posting I did on vansairforce on the subject of the AFP fuel injection system, vertical install. Please secure the filtered airbox in done manner beyond the aluminum clamp doughnut.
| Quote: | From google or on vansairforce search the following: "Engine out over Kocf"
It will take you right to the thread.
Bob Newman
N541RV
rvdave
Posted: Mon May 12, 2014 1:03 pm Post subject: Re: Airflow Performance install |
Yes I did see that, thanks.
Cadillac, MI |
rvdave
Posted: Mon May 12, 2014 5:33 pm Post subject: Re: Airflow Performance install |
Bob, didn't see any photos regarding red cube location or induction on your pages. Maybe I missed them?
Does the vans cable bracket get used with AP vert induction mount?
Still searching for install photos of AP throttle body,brackets & cables. Any photos or links appreciated.
Cadillac, MI |
rleffler
Posted: Mon May 12, 2014 9:35 pm Post subject: Airflow Performance install |
Try looking in the section labeled firewall forward, but unless you also are installing Rod Bower's Ram Air mod, it won't help you much. My fuel controller is mounted horizontally and everything is in a different location.
AFP has their own set of mounting hardware that comes with the fm-200. I didn't use the vans bracket, but then again, my fuel controller is horizontal, not vertical. I also didn't use much of the brackets in the AFP kit either for the same reason.
It sounds like you don't have a copy of the AFP manual. It has quite a few photos of installations. I don't have a copy on my iPad, or I would send a you a copy. At this point of the build, nothing is prescriptive. The AFP manual shows you examples that you have to adapt to your installation. If you don't have the manual, give Don a call.
A quick search of Matronics found this thread with pictures of a very common location for the fuel sensor.
http://www.matronics.com/forums/viewtopic.php?p=421359&highlight=&sid=3afa4fba9d5e9179e9fdd4e8d529db66
Sent from my iPad
| Quote: | On May 12, 2014, at 9:33 PM, "rvdave" <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=423242#423242
N410BL - Phase I
