kleh(at)dialupatcost.ca Guest
Posted: Tue Jun 03, 2014 4:55 am Post subject: Economical solid state pressure sensors |
I only seem to get a few hundred hours out of name brand
electromechanical engine pressure sensors so I tried a 30 psi $25. solid
state Chinese sensor for coolant pressure monitoring. Quite a bit
cheaper than what I was using and seemingly good specifications which
I've copied below. While it calibrates perfectly at room temperature, it
reads at least 5 psi low when it gets hot (ie. 4 psi when it should be
9). The zero point changes similarly and I confirmed all this with raw
voltage readings and scope traces to make certain. This sensor was
mounted on the firewall and tee'd into a 5/16" coolant hose so the
coolant likely warmed it up to about 80*C. Seems it would need to be
installed on a stub line on the cool side of the firewall to be useful.
The temperature specification of Maximum:0.05%FS/ºC would indicate up to
1.5 psi zeroing error over a 100*C range which would be acceptable to me
if that was the case and other errors were minor. This particular sensor
may be outside of stated tolerances. In any case, the compensation
temperature range of -20 to +80*C seems to be meaningless. I'd also
hoped to replace the oil pressure sensor but it seems these economical
sensors are not the answer for under the cowl.
Ken
Brand new pressure transducer. 316 Stainless steel body.
Input: 0-30 psi(Gauge Pressure);
Output: 0.5-4.5V linear voltage output. 0 psi outputs 0.5V, 15 psi
outputs 2.5V, 30 psi outputs 4.5V.
Works for oil,fuel or air pressure.Can be used in oil tank,gas
tank,diesel tank etc.
Accuracy: +/-1%FS;
Thread: 1/8” NPT;
Wiring Connector: Packard plug-in unit is included;
Wiring: Red: +5V; Black: ground; Green: signal output;
It's an advance pressure sender than traditional mechanical pressure sender;
Overload Capacity: 2-4 times;
Working Temperature: -40—+120ºC;
Compensation Temperature: -20—+80ºC;
Protection Class: IP67;
Pressure Medium: The gas and liquid which is compatible with 316L
stainless steel;
Load Resistance: ≤((supply power-6.5V/0.02A)Ω;
Long-term stability: Less than 0.1%FS/year;
Temperature Effect on Zero: Typical:0.02%FS/ºC; Maximum:0.05%FS/ºC;
Temperature Effect on Sensitivity: Typical:0.02%FS/ºC; Maximum:0.05%FS/ºC;
Shock Resistance: 1000g;
Anti-Shock: ≤+/-0.01%FS(X,Y,Z axes, 200Hz/g);
Response Time: ≤1ms;
Insulation Resistance: >100mΩ 500VDC;
Weight: 55g;
Explosion-proof Class: ExiaTTCT6;
Electromagnetism Compatibility: EN50051-1.
Posted: Tue Jun 03, 2014 10:23 am Post subject: Economical solid state pressure sensors |
name brand electromechanical engine pressure
sensors so I tried a 30 psi $25. solid state
Quite a bit cheaper than what I was using and
seemingly good specifications which I've copied
temperature, it reads at least 5 psi low when it
gets hot (ie. 4 psi when it should be 9). The
this with raw voltage readings and scope traces
to make certain. This sensor was mounted on the
the coolant likely warmed it up to about 80*C.
Seems it would need to be installed on a stub
useful. The temperature specification of
Maximum:0.05%FS/ºC would indicate up to 1.5 psi
acceptable to me if that was the case and other
errors were minor. This particular sensor may be
compensation temperature range of -20 to +80*C
seems to be meaningless. I'd also hoped to
these economical sensors are not the answer for under the cowl.
I have one of those transducers in a 300 psi version . . .
in fact . . . it's in my pocket right now. We ordered
it in to consider for a future development program.
I'll see if I can get a quick look-see on accuracy
and temperature effects.
The numbers you're citing are pretty poor . . . I can't
imagine anyone putting so much into a stainless case
and cutting short the electronics . . . electronics
that are pretty much jelly-bean parts. If you're going
to round-file the aberrant transducer, drop it to
me in the mail . . . I'd like to peek at it on the
bench too.
