dlm34077
Posted: Fri Jun 13, 2014 12:13 pm Post subject: N62DN |
Does anyone know whether this aircraft was an electronic ignition aircraft? I read the preliminary NTSB report and the survivor interview where she stated that the engine went silent and the electronics failed immediately thereafter?
dlm34077
Posted: Fri Jun 13, 2014 12:14 pm Post subject: N62DN |
NTSB Identification: WPR14FA218
14 CFR Part 91: General Aviation
Accident occurred Saturday, May 31, 2014 in Toldeo, OR
Aircraft: NEBERT VANS RV-10, registration: N62DN
Injuries: 2 Fatal,1 Serious.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. NTSB investigators either traveled in support of this investigation or conducted a significant amount of investigative work without any travel, and used data obtained from various sources to prepare this aircraft accident report.
On May 31, 2014, about 1620 Pacific daylight time, a single-engine experimental Nebert Vans RV-10, N62DN, experienced a loss of power and departed control flight while the pilot was maneuvering for a forced landing in Toledo, Oregon. The private pilot and four-year old passenger were fatally injured; the adult passenger sustained serious injuries. The airplane was registered to and being operated by the pilot under the provisions of 14 Code of Federal Regulations Part 91. The personal flight departed Newport Municipal Airport, Newport, Oregon with a planned destination of Seattle, Washington. Visual meteorological conditions prevailed and no flight plan had been filed.
Numerous witnesses located in Toledo reported observing the airplane flying at a low altitude from the north. The witnesses reported hearing no sound from the airplane's engine and saw it progressively descend in altitude. The airplane approached the Georgia Pacific paper mill and made a steep turn to the left. The airplane subsequently made a rapid descent and impacted terrain in a nose-low near-vertical attitude.
The surviving passenger recalled the flight although was heavily medicated during the recounting of the events that transpired. She stated that she was in the aft right seat and her daughter was buckled in a car seat positioned in the aft left seat. Luggage was strapped in the front right seat in an effort to compensate for the aft weight. The departure seemed normal and the pilot commented that the engine sounded the best ever had prior. The airplane continued the takeoff climb through some cloud wisps and ascended above a lower cloud cover, with an overcast layer above.
The passenger further stated that suddenly the engine experienced a total loss of power, which she described as the airplane stopping forward motion and there was no engine sound. An alarm sounded and shortly thereafter, all of the airplane electric system failed. She recalled observing the screen in front of the pilot flickered and then went blank. The pilot was busy pressing buttons and maneuvering levers and indicated that they were going to land at the closest airport [which was Toledo]. The airplane descended through clouds heading toward the airport. The pilot stated that they were going to make it to the airport and he was looking for a place to land. The airplane made an alert sound, which she thought indicated the airplane was moving too slow. The pilot made a left turn and tried to pull up but the airplane spiraled down harder to the ground.
The accident site was located in the paper mill adjacent to the Yaquina River in Toledo, Oregon, with the debris confined to the immediate area near the main wreckage. The closest airport to the accident was in Toledo, Oregon and was located 0.7 nm for the accident site on a heading of 192-degrees. The wreckage came to rest in a flat area which was a portion of dirt road on the perimeter of the mill. Surrounding the site were 20 ft high stacked bales of crushed cardboard boxes and a railroad track with parked train cars. Additionally, a northwest-southeast oriented 12 ft-diameter tubular conveyer was near the accident site that was about 70 feet high and 1,625 ft long.
The main wreckage, which consisted of nearly the entire airplane, was on a heading of 310 degrees. The initial point of impact consisted of a ground scar and disrupted dirt located about 25 feet and on the bearing of 220 degree from the cockpit section of the main wreckage. Embedded in the dirt were fragments of red lens and shards of paint and fiberglass, consistent with the left wing impacting first.
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Fri Jun 13, 2014 12:41 pm Post subject: N62DN |
From his build site: http://websites.expercraft.com/douglasn/index.php?q=log_entry&log_id=51251
....it looks like he was running mags on a carbureted engine.
On Fri, Jun 13, 2014 at 3:12 PM, DLM <dlm34077(at)cox.net (dlm34077(at)cox.net)> wrote:
[quote] Does anyone know whether this aircraft was an electronic ignition aircraft? I read the preliminary NTSB report and the survivor interview where she stated that the engine went silent and the electronics failed immediately thereafter?
tp://forums.matronics.com
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
n801bh(at)netzero.com Guest
Posted: Fri Jun 13, 2014 12:48 pm Post subject: N62DN |
Sad deal.. But.. Like many other crashes after a engine failure....... FLY the plane and do NOT get slow.....
Ben Haas
N801BH
www.haaspowerair.com
bobw
Posted: Sun Jun 15, 2014 8:03 am Post subject: N62DN |
Interesting to note that there is a Lycoming Mandatory Service Bulletin #554 (dated Sept 30, 2002) that mandated a Crankshaft Gear Retaining Bolt Replacement. Excerpt below.
“ All O, IO, (L)TIO or AEIO-540 engines that have had a crankshaft bolt replaced during maintenance or overhaul between November 27, 1996 and November 10, 1998. Lycoming has determined that a metallurgical condition has caused crankshaft gear retaining bolts to fail in service. The crankshaft gear drives both magnetos and the camshaft. Failure of the retaining bolt results in total loss of power without prior warning. Lycoming requires that the crankshaft gear retaining bolt be replaced with the new bolt P/N STD-2209 (cadmium plated and silver in color).”
Bob Wilson
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ed Kranz
Sent: Friday, June 13, 2014 4:41 PM
Subject: Re: RV10-List: N62DN
On Fri, Jun 13, 2014 at 3:12 PM, DLM <dlm34077(at)cox.net<mailto:dlm34077(at)cox.net>> wrote:
_________________ Bob Wilson
bob@rjw.cc |
rv10flyer
Posted: Sun Jun 15, 2014 8:08 pm Post subject: Re: N62DN |
Does not explain electrical power loss unless maybe he turned it off per his emergency checklist. That will be one of the last items before an off field landing. He was trying to make it that last .7 nm to the airport. I think I will go practice stalls and slow flight with the airspeed tape covered again.
_________________ Wayne G. |
dlm34077
Posted: Mon Jun 16, 2014 6:12 am Post subject: N62DN |
This obviously does not apply for low altitude failure on takeoff but a failure at altitude; it may be possible to turn on the AP while troubleshooting. My Trutrak will maintain altitude until a minimum of 80 KIAS them start giving up altitude for airspeed. Also prop control should be full aft. This would allow full attention to a restart. Of course it would have to hand flown later but it may be acceptable to troubleshoot without also having to control the aircraft.
rv10flyer
Posted: Mon Jun 16, 2014 8:00 am Post subject: Re: N62DN |
Same here....80 kts MAS on mine .
cooprv7(at)yahoo.com Guest
Posted: Mon Jun 16, 2014 4:18 pm Post subject: N62DN |
I've been mulling whether to add my .02 to thus, but having experienced a catastrophic engine failure in an RV-6 I'll submit my thoughts. This is not a critique of what happened in any way as I don't have all the facts, but simply lessons learned from my experience. As many have said in a number of posts, fly the airplane first, no matter how exciting things get. I'm not sold on the autopilot use since the airplane trims so nicely, but by all means use whatever it takes to keep flying airspeed. I flew fighters for 20 years and lived on angle of attack indicators, however in light airplanes the stall and max range speeds really don't vary much within the acceptable weight range so I would argue a solid airspeed cross check and good feel for the airplane is far more important. The RV-10 has a very subtle stall which is good, but with occasional practice it is still very perceptible. It is also very important to know the best range airspeed engine out, in my airplane's case it's about 80 knots. If you are faster when the engine quits, trade airspeed for altitude which will result in time and options.
As my RV-6 glider was cruising over heavily forested hills in search of a place to land a few important things became clear. First of all, when it gets grim don't worry about what's best for the airplane, that's what insurance is for. Do what's best to make sure the pink bodies in the airplane are going to fare as well as possible. I actually made a conscientious decision that the airplane was a write off and focused on survivability and am very thankful for it.
Second, fly the airplane at max range speed until landing is assured where you want to go. My passenger was a very low time private pilot and as we cruised in silence he recommended a runway off in the distance on an island. I pointed out that it was rising in the windscreen which means we couldn't make it. Stretching out a glide by slowing down only works when you are just about to land and have the airspeed above stall to spare, too many accidents have been caused by trying to make the airplane fly farther than aerodynamics will allow.
Third, be very sensitive to what the airplane is telling you. Once I had the small clearing I thankfully found made, I was doing small S turns to eliminate the extra airspeed and altitude. I had also delayed extending the flaps until landing was assured. During one of the turns I sensed the tickle of an oncoming accelerated stall and quickly backed off. The airplane is happy to talk to you, but make sure you are listening.
Finally, the accident happened at a time in my flying career when I was most proficient at engine out situations. As an additional duty I ran the small T-34C program and therefore routinely flew this essentially light airplane fairly often and doing practice engine out approaches was a routine event. I have to admit I don't practice them now as much as I would advocate, but they are a great idea regardless of one's experience. Not only for getting the procedures down, but also getting a realistic expectation of how far the airplane will glide and what that looks like out the window.
Enough rambling, hope this helps someone,
Marcus
40286
Wayne G.
http://forums.matronics.com/viewtopic.php?p=424914#424914
flyboy(at)gmail.com Guest
Posted: Mon Jun 16, 2014 5:37 pm Post subject: N62DN |
On 06/16/2014 08:12 AM, DLM wrote:
| Quote: | This obviously does not apply for low altitude failure on takeoff but a
This sounds like a terrible idea at any altitude. You should, above all
else, be flying the airplane. When an engine quits in a single-engine
aircraft, I don't really care what else you do, but you should land the
aircraft safely. [note, some speculation follows...] It would appear
from the NTSB preliminary report that the pilot in question failed to
fly the airplane. The autopilot wouldn't have helped him here: he
picked a field he couldn't make, and apparently never realized he
couldn't make it since he forced the airplane into a stall trying.
If you've got the autopilot flying some random heading, maintaining best
glide, hoping to restart the engine, you will probably kill yourself. I
would much rather read about someone who had an engine failure that
could have been restarted by flipping a switch, but instead landed
safely (albeit unnecessarily) in a field than the alternative. An
engine failure should *not* be a life-threatening event, and I'm sick of
reading about pilots killing themselves and others because they failed
to fly the airplane.
Once you've picked a landing spot, figured out how you're going to
maneuver the aircraft to that landing spot (I'm a big fan of practicing
power-off 360s until you know how to do this), then, and only then,
should you attempt an engine restart.
By setting the autopilot, you're in effect giving yourself permission to
not fly the airplane. As you say, "this would allow full attention to a
restart," which, in my not-so-humble opinion is exactly what you should
never do. If you trim the airplane for best glide (or, better, minimum
sink if you're able to pick a field that's mostly underneath you), it
will maintain that speed without input from you. No autopilot
necessary, and you'll be paying a lot more attention to which direction
you're flying than you would be by moving some heading bug around.
The advice for set the prop control to the highest pitch (lowest speed)
possible is good assuming you're trying to maximize gliding distance or
time aloft.
Berck
Posted: Mon Jun 16, 2014 6:29 pm Post subject: N62DN |
Berck,
Are you flying your -10 yet? If not, then don't assume you can just trim for a certain speed and it will stay. It's no Cessna. I told my instructor, when I was working on my IFR that it was hard to hold altitude accurately. He didn't believe me until he tried. Any slight stick pressure can give you a 500fpm climb or descent. I'm not arguing for using the autopilot, just saying that it isn't as simple as just trimming for a certain airspeed. With almost 700 RV-10 hours I still feel the same way, that I would not fly this plane IFR without an autopilot.
Do not archive.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
| Quote: | On Jun 16, 2014, at 9:36 PM, "Berck E. Nash" <flyboy(at)gmail.com> wrote:
time aloft.
Berck
Posted: Mon Jun 16, 2014 7:01 pm Post subject: N62DN |
On 06/16/2014 08:29 PM, Jesse Saint wrote:
| Quote: | Are you flying your -10 yet? If not, then don't assume you can just trim for a certain speed and it will stay. It's no Cessna. I told my instructor, when I was working on my IFR that it was hard to hold altitude accurately. He didn't believe me until he tried. Any slight stick pressure can give you a 500fpm climb or descent. I'm not arguing for using the autopilot, just saying that it isn't as simple as just trimming for a certain airspeed. With almost 700 RV-10 hours I still feel the same way, that I would not fly this plane IFR without an autopilot.
I am not, but I have yet to fly an airplane that cannot be trimmed for
an airspeed. An airplane that cannot be trimmed for an airspeed
essentially exhibits negative dynamic stability. I'm sure that's not
the case for the RV-10. I've flown everything from Cessnas, to
turboprops, to jets, and have yet to find an airplane that cannot be
easily trimmed for airspeed. Not saying one doesn't exist, but they're
not normal, and I don't think the RV-10 is one of them.
Maintaining altitude is a different story. As long as you've got
positive dynamic stability, you're still going to get a diminishing set
of diversions that converge on the airspeed you're trimmed for, though a
very maneuverable airplane will take more time to stabilize than a less
maneuverable (more stable) airplane. That doesn't mean it won't trim for
airspeed, but may hunt a bit for it. The jets I've flown have all been
hard to hand-fly in level flight. When I started flying for the
airlines, almost all the training the sim was autopilot-centric, and it
took quite a few hours in the plane to get proficient hand flying it.
The hardest hand-flown maneuver in an airliner, for me, was leveling off
from a climb and accelerating to cruise speed with no autopilot or
flight director. Very twitchy, the trim very sensitive, the aircraft
extremely pitch-sensitive to thrust changes, and all equipped with
flight attendants that will bitch if they can tell you're hand-flying
while they're walking around. Still, they're all very easy to trim for
a stabilized climb/descent at a specific airspeed. Flying a stabilized
approach by hand was cake in comparison to flying level.
So, yes, I can believe that maintaining altitude in an RV-10 (known for
being maneuverable) is tricky. I *do* believe that descents are as
simple as trimming for airspeed in a descent. If you've got a +/-5 hunt
for airspeed, close enough! Maybe even better that it hunts a bit, I'd
rather you were paying attention to airspeed than trying to restart your
engine, because maybe you'll land safely.
As a somewhat snide side remark that I still hope you'll think about for
a second: If you can't fly an RV-10 IFR without an autopilot, I hope you
either
(a) don't fly an RV-10 IFR or
(b) have two fully redundant autopilots installed.
Berck
Bob Turner
Posted: Mon Jun 16, 2014 8:53 pm Post subject: Re: N62DN |
Eye witness testimony is often wrong, not to mention being sedated, but if in fact there was a complete electrical failure then neither the autopilot, nor the trim, would work. (I note she later heard what may have been the stall horn, which is electric).
As for ifr, of course the -10 can be hand flown. It's just more tiring.
_________________ Bob Turner
RV-10 QB |
cjay
Posted: Mon Jun 16, 2014 9:15 pm Post subject: Re: N62DN |
| dlm34077 wrote: | This obviously does not apply for low altitude failure on takeoff but a failure at altitude; it may be possible to turn on the AP while troubleshooting. My Trutrak will maintain altitude until a minimum of 80 KIAS them start giving up altitude for airspeed. Also prop control should be full aft. This would allow full attention to a restart. Of course it would have to hand flown later but it may be acceptable to troubleshoot without also having to control the aircraft.
Is this a trutrak setting for glide? I'll have to practice this.
Despite other's objections, if your comfortable with both hand flying glide and autopilot glide this makes sense to me especially if you're attempting a restart. The -10 stall is very easy to detect and manage (if you have altitude to play with).
The other nice feature to have on your EFIS (if you still have electrical juice) is a glide map overlay that takes into account wind. This is on the Chelton's, but not sure if the others have adopted this very simple tool. Doing this with your senses and in your head would take quite a bit of practice to become proficient in an emergency situation.
Now my question I need help on, is prop full aft the best feathering no power glide setting? Frankly, I'm embarrassed that I don't know this.
cjay
Bob Turner
Posted: Mon Jun 16, 2014 10:35 pm Post subject: Re: N62DN |
| cjay wrote: | | dlm34077 wrote: | This obviously does not apply for low altitude failure on takeoff but a failure at altitude; it may be possible to turn on the AP while troubleshooting. My Trutrak will maintain altitude until a minimum of 80 KIAS them start giving up altitude for airspeed. Also prop control should be full aft. This would allow full attention to a restart. Of course it would have to hand flown later but it may be acceptable to troubleshoot without also having to control the aircraft.
cjay |
It's not designed to give you best glide,but rather to keep the autopilot from inadvertantly stalling the aircraft. I'd recommend setting the minimum speed closer to 70 kias, in case you want the autopilot to fly an approach at, say, 75 kias. (Trio has the same feature).
The GRT EFIS will show you how far you can glide. You need the gps working, too, and you have to enter as the target altitude the ground or airport elevation.
Yes, if the engine is windmilling, the rpm within governing range, you have oil pressure, etc., then minimum rpm setting (full out) will give you minimum drag. You can also reduce the drag by full open (forward) throttle.
RV-10 QB |
Posted: Tue Jun 17, 2014 5:10 am Post subject: N62DN |
I didn't say couldn't, I said wouldn't. Big difference.
Do not archive.
Jesse Saint
352-427-0285
Sent from my iPad
| Quote: | On Jun 16, 2014, at 11:00 PM, "Berck E. Nash" <flyboy(at)gmail.com> wrote:
either
Berck
cjay
Posted: Tue Jun 17, 2014 5:34 am Post subject: Re: N62DN |
| Bob Turner wrote: |
cjay |
| Quote: | | It's not designed to give you best glide,but rather to keep the autopilot from inadvertantly stalling the aircraft. I'd recommend setting the minimum speed closer to 70 kias, in case you want the autopilot to fly an approach at, say, 75 kias. (Trio has the same feature). |
ok that makes sense, thanks.
Yes, if the engine is windmilling, the rpm within governing range, you have oil pressure, etc., then minimum rpm setting (full out) will give you minimum drag. You can also reduce the drag by full open (forward) throttle. |
ok thanks, two new questions.
1. If the engine stopped for benign reasons, e.g., fuel depletion in one tank, and you switched tanks, won't the wind resistance on the prop jump start the engine? and if so, is it better to have the prop in max setting or min setting for this?
2. Why does open throttle reduce drag?
Posted: Tue Jun 17, 2014 6:08 am Post subject: N62DN |
(Sorry if this is a repeat, my first try didn't seem to go through)
Marcus
40286
Wayne G.
bobw
Posted: Tue Jun 17, 2014 6:59 am Post subject: N62DN |
I guess I'd have to agree with Berck. I look at an autopilot as an assist not a primary. With it on it's sort of like having a copilot and I used it frequently to shoot approaches. But, unless I could actually fly the machine myself and shoot the approach without the autopilot I wouldn't put myself in a situation that the approach was required. As I have yet to build or even fly one I have paid particular attention to the handling qualities in general as well as the ability to fly it "hands on" in IFR condition. Based on that it appears to be an excellent choice. All airplanes require a certain amount of "finesse" to hand fly and the only way to develop that is to fly it.
Bob Wilson
bob@rjw.cc |
Bob Turner
Posted: Tue Jun 17, 2014 6:18 pm Post subject: Re: N62DN |
[quote="cjay"] | Bob Turner wrote: |
2. Why does open throttle reduce drag? |
1. If you run a tank dry, the mechanical fuel pump, which does not pump air well, won't help much, so RPM doesn't really matter. You'll need the boost pump.
2. Windmilling engine is expending energy pumping air, like a vacuum cleaner. Opening the throttle removes a restriction, raises MP, engine doesn't do as much work.
RV-10 QB |
