oil cooler deflector
cjhukill(at)cox.net
PostPosted: Fri Jun 27, 2014 2:03 pm    Post subject: oil cooler deflector Reply with quote
Does anyone have any feedback on the affectivity of the oil cooler deflectors. I’m not convinced that I should install it, as Tim Olsen says it actually raised his temperatures. Anyone else have anything to report?
Chris Hukill
Tim Olson
PostPosted: Fri Jun 27, 2014 2:29 pm    Post subject: oil cooler deflector Reply with quote
I don't think the theory is too bad on the device, but with all the variability between builders I don't know how actually effective it was for me. If it raised my temps it wasn't by much. I doubt you'll hurt anything by using it though.
On Jun 27, 2014, at 5:03 PM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
[quote] Does anyone have any feedback on the affectivity of the oil cooler deflectors. I’m not convinced that I should install it, as Tim Olsen says it actually raised his temperatures. Anyone else have anything to report?
Chris Hukill
rv10flyer(at)live.com
PostPosted: Fri Jun 27, 2014 2:31 pm    Post subject: oil cooler deflector Reply with quote
I have totally normal 190f-200f range with deflector. OAT temps are 90f-50f
Sent: Friday, June 27, 2014 3:03 PM
Subject: oil cooler deflector
Chris Hukill
rleffler
PostPosted: Fri Jun 27, 2014 3:01 pm    Post subject: oil cooler deflector Reply with quote
If you also put a damper vent to reduce airflow, you need to ensure the vent is perpendicular to the deflector.   Otherwise when the vent is partially closed, you'll only be sending air through half the oil cooler.
I don't have any comparison temps, but I'm not having problems with oil temps being high with the deflector
On Jun 27, 2014, at 6:30 PM, "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
Chris Hukill
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
larkrv10(at)gmail.com
PostPosted: Sat Jun 28, 2014 6:01 pm    Post subject: oil cooler deflector Reply with quote
Chris, just a FYI  wrt oil coolers.  I have bought and installed an Air Flow  2007X, the next larger sized cooler offered.  I have no intentions of installing the baffle or deflector with the larger capacity cooler.  I do however have Bob Newmans butterfly valve and electronic controller if its required to regulate oil temp.
Having said that I`m not flying yet so this info is worth .02 or less   Wink
Rick
#40956
Southampton, Ont
On Fri, Jun 27, 2014 at 6:03 PM, Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
Chris Hukill
tp://forums.matronics.com
aerosport1
PostPosted: Mon Jun 30, 2014 5:09 am    Post subject: oil cooler deflector Reply with quote
Chris
I have the larger oil cooler without the deflector in it. I also have a valve to control oil temperatures and everything works very good. I would recommend
The oil door and the deflector would be your call. 4 plus years with this setup and still works great. In the winter months I can set oil temps to pretty much
Where I want to run. In the summer it is usually wide open.
Geoff
Geoff Combs
Aerosport
8090 Howe Industrial Parkway
Canal, Winchester, Ohio 43110
614-834-5227
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Friday, June 27, 2014 6:03 PM
Chris Hukill
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Kelly McMullen
PostPosted: Mon Jun 30, 2014 12:48 pm    Post subject: oil cooler deflector Reply with quote
Geoff,
When you say "larger" do you mean the 2006X or 2007X? Both have more capacity than the Vans cooler and I think are both a bit larger.
On Mon, Jun 30, 2014 at 6:08 AM, Geoff Combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)> wrote:
Chris
Geoff
Geoff Combs
Aerosport
[url=tel:614-834-5227]614-834-5227[/url]
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Chris Hukill
Does anyone have any feedback on the affectivity of the oil cooler deflectors. I&rsquo;m not convinced that I should install it, as Tim Olsen says it actually raised his temperatures. Anyone else have anything to report?
Chris Hukill
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
