zipper
Posted: Sat Jul 19, 2014 8:26 am Post subject: Lightning Jet empty weight |
I am doing a survey and would like to know what others have as empty weight for their Lightnings. I would like to have actual 'as weighed' numbers as opposed to what the factory has put out. Please check your weight and balance papers and respond to this forum. My plane, that is very sparsely equipped, comes in at 40 lbs heavier than the factory advertisements. Either my scales (electronic) are way off or ???? Thanks to all.
George Andre
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
dwwilt
Posted: Sat Jul 19, 2014 8:37 am Post subject: Lightning Jet empty weight |
George,
My plane came in at 886 lbs.
Dennis W. Wilt, Aviation Consultant
Communications, Navigation, and Surveillance Subject Matter Expert
Program and Project Management
757-784-8113
N616DW (Arion Lightning S/N 132)
_________________ Dennis |
vettin74(at)yahoo.com Guest
Posted: Sat Jul 19, 2014 9:09 am Post subject: Lightning Jet empty weight |
George,
What's your empty weight? And did you re weigh after the chute came out?
Nick
On Jul 19, 2014, at 11:26 AM, George Andre <glandre(at)sbcglobal.net (glandre(at)sbcglobal.net)> wrote:
[quote]I am doing a survey and would like to know what others have as empty weight for their Lightnings. I would like to have actual 'as weighed' numbers as opposed to what the factory has put out. Please check your weight and balance papers and respond to this forum. My plane, that is very sparsely equipped, comes in at 40 lbs heavier than the factory advertisements. Either my scales (electronic) are way off or ???? Thanks to all.
George Andre
ning-List"">http://www.matronics.com/Navigator?Lightning-List
//forums.matronics.com
geather
Joined: 06 Feb 2008 Posts: 23 Location: Mt Hutton Australia
Posted: Sat Jul 19, 2014 2:08 pm Post subject: Lightning Jet empty weight |
400 Kg (882 lbs). Kit 127
Geoff Eather (Aust)
On 20 Jul 2014, at 2:26 am, George Andre <glandre(at)sbcglobal.net (glandre(at)sbcglobal.net)> wrote:
George Andre
_________________ ge |
voroninmax(at)gmail.com Guest
Posted: Sat Jul 19, 2014 2:32 pm Post subject: Lightning Jet empty weight |
The one I built ended up around 820 lbs if I remember right
Epoxy primer and paint, no clear coat
S/n 93
On Jul 19, 2014, at 6:07 PM, geather <geather(at)bigpond.net.au (geather(at)bigpond.net.au)> wrote:
[quote]400 Kg (882 lbs). Kit 127
Geoff Eather (Aust)
| Quote: | I am doing a survey and would like to know what others have as empty weight for their Lightnings. I would like to have actual 'as weighed' numbers as opposed to what the factory has put out. Please check your weight and balance papers and respond to this forum. My plane, that is very sparsely equipped, comes in at 40 lbs heavier than the factory advertisements. Either my scales (electronic) are way off or ???? Thanks to all.
George Andre
lbmathias1(at)gmail.com Guest
Posted: Sat Jul 19, 2014 4:27 pm Post subject: Lightning Jet empty weight |
George,
My Lightning's empty wt is 883 lbs and has a fully IFR panel with glass cockpit.
Linda Mathias
On Jul 19, 2014, at 12:26 PM, George Andre <glandre(at)sbcglobal.net (glandre(at)sbcglobal.net)> wrote:
George Andre
Posted: Sat Jul 19, 2014 4:55 pm Post subject: Lightning Jet empty weight |
Our first demo 323AL was 830lbs, single EFIS no AP wood prop ect. N324AL was 850 with dual EFIS, AP, long wings ect. Generally around 820lbs very basic, to 900 loaded with everything. Our scales are digital racing scales and we weigh the planes in full dress with oil and no fuel. Have posted several PICs on FB of them on scales. The heaviest yet was the XS with the lycoming O320 and it was 1013 lbs.
The planes with the EAB gear are lighter, the wide track gear weighs 13lbs more, Carbon props are about 5lbs heavier than wood. The interiors from B&B Are extremely nice but are heavy as well. steps weigh 3lbs a side.
Over the years from the early SN to newer ones the airframes lost weight. The fuselages used to weigh around 115lbs now they are about 105lbs, wing panels were about 90lbs and now around 75lbs. Same win small parts ect. We have changed cores resins and layup schedules to produce lighter parts while retaining strength.
It seems the biggest weight gain is the advancement in avionics and all the stuff you can stick in a plane.
Nick
On Jul 19, 2014, at 7:24 PM, Linda Mathias <lbmathias1(at)gmail.com (lbmathias1(at)gmail.com)> wrote:
[quote]George,
Linda Mathias
George Andre
ritchie(at)wave.co.nz Guest
Posted: Sat Jul 19, 2014 4:57 pm Post subject: Lightning Jet empty weight |
My lightning's empty weight is 894 lbs. The dual Grand Rapids and Auto
pilot add that little extra weight.
regards,
Ron Ritchie
is
Thanks to all.
George Andre
Links:
[1] http://www.matronics.com/Navigator?Lightning-List
[2] http://forums.matronics.com
[3] http://www.matronics.com/contribution
barnett6088(at)msn.com Guest
Posted: Mon Jul 21, 2014 4:19 pm Post subject: Lightning Jet empty weight |
George
My factory built lightning when checked at Gregg Hobbs place weighed slightly more than 900 Lbs. dry empty weight. That was with the MK 2 tail feathers and fairings. I would give you an exact weight but the data is at the hanger and some distance away from my home.
Gary Barnett N335AL ELSA sn 133
Date: Sat, 19 Jul 2014 09:26:20 -0700
Subject: Lightning-List: Lightning Jet empty weight
To: lightning-list(at)matronics.com
George Andre
st" target="_blank">http://www.matronics.com/Navigator?Lightning-List
NowackLinden(at)gmx.de Guest
Posted: Tue Jul 22, 2014 2:16 am Post subject: Lightning Jet empty weight |
Hi,
My D-ELIY was propably the Heavyweight Champion!
The precision scales provided by my Examiner showed 410kg / 903lbs empty
incl. unusable fuel. Apparently the result of a very generous car
painter`s paintjob. White, then design, then clear coat.
D-EGFL will be somewhat better, although not lighter, of course, due to
the increased weight of ULP.390 engine and steel gear legs. But a friend
has spent hours of hard work to sand off about 40lbs of Gelcoat, and
the painter was reminded to keep the paint thin.
If I can keep it under 425kg /935lbs empty I`m happy. MTOW will be
700kg/ 1540lbs.
Gerd
Am 22.07.2014 09:00, schrieb Lightning-List Digest Server:
[quote] *
Today's complete Lightning-List Digest can also be found in either of the
of the Lightning-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-07-21&Archive=Lightning
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-07-21&Archive=Lightning
Lightning-List Digest Archive
Total Messages Posted Mon 07/21/14: 3
Today's Message Index:
1. 06:36 AM - Re: Lightning-List Digest: 8 Msgs - 07/19/14 (George Andre)
2. 06:36 AM - Re: Lightning-List Digest: 8 Msgs - 07/19/14 (George Andre)
3. 05:19 PM - Re: Lightning Jet empty weight (GARY BARNETT)
Time: 06:36:45 AM PST US
Subject: Re: Lightning-List Digest: 8 Msgs - 07/19/14
Thanks to all who responded.
My EAB jet empty weight is 895 which was strangely high because my friend with
a factory LS-1 has empty wt of 840 and has considerably more equipment (avionics
and autopilot) than mine. This 895 number is the same as original wt of plane
when equipped with a BRS chute.
I weighed with zero fuel on fancy electronic racing scales. Nick- this after chute
removed. My new LSA wing tips are heavier and we put on the steps, B&B interior
(lighter than what was in place) plus grnd adjust prop, but I have minimum
avionics, and wide track gear.
I'm happy to see others are in the same ballpark.
Thanks again....George Andr...jet kit #11
Sent from my iPad
> On Jul 20, 2014, at 2:00, Lightning-List Digest Server <lightning-list(at)matronics.com>
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-07-19&Archive=Lightning
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-07-19&Archive=Lightning
> Total Messages Posted Sat 07/19/14: 8
> 1. 09:26 AM - Lightning Jet empty weight (George Andre)
> 2. 09:37 AM - Re: Lightning Jet empty weight (Dennis W. Wilt)
> 3. 10:09 AM - Re: Lightning Jet empty weight (Nick Otterback)
> 4. 03:08 PM - Re: Lightning Jet empty weight (geather)
> 5. 03:32 PM - Re: Lightning Jet empty weight (Max Voronin)
> 6. 05:27 PM - Re: Lightning Jet empty weight (Linda Mathias)
> 7. 05:55 PM - Re: Lightning Jet empty weight (Nick Otterback)
> 8. 05:57 PM - Re: Lightning Jet empty weight (ritchie(at)wave.co.nz)
> Time: 09:26:55 AM PST US
> From: George Andre <glandre(at)sbcglobal.net>
> Subject: Lightning Jet empty weight
> ed,-comes in at 40 lbs heavier than the factory advertisements. Either my
> scales (electronic) are way off or ???? Thanks to all.=0A=0AGeorge Andre
> ________________________________ Message 2 _____________________________________
> Time: 09:37:19 AM PST US
> Subject: Re: Lightning Jet empty weight
> From: "Dennis W. Wilt" <dwwilt(at)AOL.COM>
> George,
> Regards,
> 757-784-8113
wayne42patterson(at)gmail Guest
Posted: Sat Jul 26, 2014 5:27 pm Post subject: Lightning Jet empty weight |
Hi George
My kit is #65 and weighed in at 834lb (378kg) complete with engine oil and unusable fuel (I put some fuel in each tank then pumped them dry using the electric boost pump – carbi pipe leading to a bucket). It has the “speed kit”, good epoxy paint, leather seats and a Dynon 10” Skyview. For weight saving I did a LOT of surface smoothing and sanding before painting, sanded most of the primer off before the top coat, used very light weight cockpit & baggage area lining, and replaced all steel packing washers (spar box etc) with alloy blocks. I had to weigh mine 3 times using calibrated scales – rotating each scale under each wheel – to be confident of the weight. We have another Lightning at our club which is finished very much mike mine and it is 6kg lighter.
Hope that helps!
Wayne Patterson
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of George Andre
Sent: Sunday, 20 July 2014 12:26 AM
George Andre
| Quote: | | http://www.matronics.com/Navigator?Lightning-List | 01234567
