Thumper
Posted: Sat Jul 26, 2014 6:47 am Post subject: Oil Usage with Oil Injectin? |
Roger or others.
With a 582, one take off and one landing, cruising at 5800 rpm what should the oil usage be? Should it use the equivalent of 50-1 (12 gallons of gas used and 32 ounces of oil) or will be it somewhat less. At idle the mark on the oil pump lever is slightly advanced from the mark on the pump which indicates it should be using more oil than normal? Is the same lever used on all engines? Seems like each displacement engine should use different amount of oil since they all use different amounts of fuel per throttle opening? Just trying to know what is right since this is the first Rotax I have used with oil injection.
Dennis
_________________ Dennis Long
Oakland TN
2000 Aeroprakt A20 Vista Cruiser, 2016 A22LS Aeroprakt
Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar.
1200+hours since 1/1/2009 |
Guy Buchanan
Posted: Sat Jul 26, 2014 11:15 pm Post subject: Oil Usage with Oil Injectin? |
I measured rates between 50 and 70 to one, and ground idle time
definitely kept things more toward the 50 side of things. Indeed it was
hard to get it up toward 70.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
On 7/26/2014 7:47 AM, Thumper wrote:
Roger or others.
Dennis
Dennis Long
Oakland TN
700+hours since 1/1/2009
http://forums.matronics.com/viewtopic.php?p=427366#427366
Deceased K-IV 1200
A glider pilot too. |
