bob88
Posted: Fri Aug 29, 2014 7:31 am Post subject: Conduit in the wing |
Here's a question about running the conduit in the wing. A straight through run is OK for the Nav/Strobe/Landing lights but what about interruptions along the way for pitot heat and trim/autopilot servos? Is there a way to branch wires out of the conduit along the way?
rv10flyer(at)live.com Guest
Posted: Fri Aug 29, 2014 7:40 am Post subject: Conduit in the wing |
Some advice Jesse gave me was run the conduit to the access panel and leave
a gap for access to the wires via the panel, when needed. than pickup the
conduit again to the next panel.
I installed all the conduit through the wing than cut the areas where the
panels were.
Pascal
johngoodman
Posted: Fri Aug 29, 2014 10:41 am Post subject: Re: Conduit in the wing |
I just put a slit in the convoluted conduit to get the wires out. A little heat shrink for rubbing issues.
John
_________________ #40572 Phase One complete in 2011 |
jeffwhip
Posted: Mon Sep 08, 2014 6:38 pm Post subject: Re: Conduit in the wing |
I was wondering what size of conduit to buy? Did you buy it from Van's?
Posted: Tue Sep 09, 2014 5:09 am Post subject: Conduit in the wing |
3/4" plastic coil tubing from the Aviation Department at Lowes.
Carl
