jrlark
Posted: Thu Sep 11, 2014 5:55 am Post subject: Side windows |
Hi all, I'm trying to decide how to finish the little gap between my side windows and the inside of the canopy. I have used Geoff Combs adhesive and will not have a head liner. First thing to mind is black silicon, but there are rubber butyl and urethane caulks out there as well.
What have others used?
Thx
Rick
#40956
Southampton, ont
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Thu Sep 11, 2014 6:21 am Post subject: Side windows |
I'm actually just putting together a video about this process.
First, I masked the inside of the windows, with about 1/4" extra exposed for the fillet. When you're bonding the windows in place, you will have some extra lord adhesive squeeze out on the inside. You can just use your fingers (in rubber gloves) to form a nice fillet.
While I am going with a headliner, on the door windows, this is going to be my finished transition. I'll be painting the adhesive along with the rest of the inside of the door. This looks as good as any car window transition that I've seen.
On Thu, Sep 11, 2014 at 8:55 AM, jrlark <jrlark(at)bmts.com (jrlark(at)bmts.com)> wrote:
[quote]--> RV10-List message posted by: "jrlark" <jrlark(at)bmts.com (jrlark(at)bmts.com)>
Thx
Rick
#40956
Southampton, ont
http://forums.matronics.com/viewtopic.php?p=430361#430361
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
Posted: Thu Sep 11, 2014 8:17 am Post subject: Side windows |
I painted the inside of the cabin with Zolatone. I have to spray the
rivet backing strips anyway so I'll mask off the windows .... again ....
and spray around the windows too.
Linn .... slather, sand, spray, sand ..... finishing around the outside
of the cabin top/cowl with UV Smoothprime.
On 9/11/2014 9:55 AM, jrlark wrote:
Thx
Rick
#40956
Southampton, ont
Checked by AVG - www.avg.com
rv10flyer
Posted: Thu Sep 11, 2014 8:24 am Post subject: Re: Side windows |
I did as Ed...used my finger to form a fillet using Weld-On 45(thicker version of 10).
No liner. Painted interior gray. We like it al lot.
Ed, I think he said in the above post that he "used" Geoff's adhesive, so I am guessing it is cured.
The outside joint with a thin layer of fg on the other hand has small paint cracks in some areas due to different expansion rates.
_________________ Wayne G. |
jrlark
Posted: Thu Sep 11, 2014 8:45 am Post subject: Side windows |
Hey guys, yes it's the Lord Adhesive I used several weeks ago. The adhesive
is white which I don't want to see as the interior of the canopy is/will be
light grey. So my intention is to add a decorative bead between the window
and the fibreglass. Does anyone know if the Lord adhesive can be painted.
By the looks of it I would doubt it.
Thx, Rick
aerosport1
Posted: Thu Sep 11, 2014 2:04 pm Post subject: Side windows |
The lord adhesive is urethane and will expect paint very nice. Just make a
real nice fillet with the lord adhesive when putting in the
Windows and then tape-off the window right up to your bead and paint to your
desired color. It looks great. I would not use
silicone or a sealer that would peel off in time.
Geoff Combs
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
larkrv10(at)gmail.com Guest
Posted: Thu Sep 11, 2014 4:16 pm Post subject: Side windows |
Thx Geoff
I never thought of painting the Lord adhesive so that will make the whole process way easier. I never left a fillet when I installed the windows, so I'll go back and do that, and then paint the cabin top.
Rick
[quote] On Sep 11, 2014, at 6:02 PM, "Geoff Combs" <g.combs(at)aerosportmodeling.com> wrote:
Geoff Combs
