tonyrenshaw268(at)gmail.c Guest
Posted: Sat Oct 04, 2014 1:05 pm Post subject: Turnbuckles. |
Hi Duncan,I too have the GS mod, but don’t recall any chain in my bits. Did GS give it to you in the kit?
As for re-wirelocking, thats where those really expensive ones from ACS become handy, as there are two small wire pins you insert to lock it up. Worth the money. I’m hoping I can fit them in directly onto shackle attachments to the main control attachment, the one sandwiched between the two triangular plates that support it to the aft internal bulkhead, that way they are as far forward as possible, and reachable too for adjustment.
Tony Renshaw
On 4 Oct 2014, at 5:08 pm, ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net) wrote:
[quote] Operationally with the Singleton tailwheel crank, I never had difficulty with adjustment by means of adding/removing the standard folded-steel chain links. It can be a bit of a fiddle through a small inspection hole, but so is re-wirelocking turnbuckles!
DMcF.
