Posted: Wed Nov 05, 2014 11:58 am Post subject: lithium facts |
Math check! 24/300 = 8%... but 2% is 10's complement, for what
that's worth (my mind works that way, at least...)
Paul
Good catch! I was mousing it out on the uSoft
Windows calculator . . . which has problematic
ergonomics . . . especially for ol' farts.
An eye-ball check would have raised the flag . . .
Posted: Wed Nov 05, 2014 12:15 pm Post subject: lithium facts |
At 12:46 2014-11-05, you wrote:
Well, all I can say - I'm amazed.
I wonder why I never read anything anywhere but 3.6V to 3.7V - with
dire warnings about exceeding much...
I suspect the 3.7 figure is the supplier's
safe-haven. You can't hurt the cell by limiting
to this value as demonstrated by countless examples
of 4-cell stacks in vehicular DC power systems.
I've got some 'wall-wart' single-cell chargers
I'm going to study in detail . . .
I note that these chargers are supplied in both
3.7v . . .
http://tinyurl.com/nr8m5t8
and 4.2 volt . . .
http://tinyurl.com/nu55dth
. . . versions but without explanation as to
the difference . . .
Here's one add that speaks to 3.7/4.2 volts in
one breath . . .
http://tinyurl.com/opmcjb9
but in the fine print, we see that they claim
a 4.2 volt output for cells spec'd in the 3.6
to 4.2 range. I read this to mean that they're
going to charge your battery to a 4.2 volt endpoint
irrespective of how it was 'rated'.
Interesting link. Thanks!
I'll have to study it a bit . . .
Posted: Wed Nov 05, 2014 12:23 pm Post subject: lithium facts |
By the way, these people show 90% charge at 3.6V (100% at 4.2V):
http://www.powerstream.com/LLLF.htm
Check out this page . . .
http://tinyurl.com/2349lq2
and the links cited thereon. Isidor Buchmann is
about as knowledgeable as they come about batteries
exceeded only by his generosity for sharing what
he knows.
jan_de_jong(at)casema.nl Guest
Posted: Thu Nov 06, 2014 3:29 am Post subject: lithium facts |
On 11/5/2014 9:22 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> <jan_de_jong(at)casema.nl>
he knows.
Interesting.
It remains difficult to know when generic "Li-ion" data applies and when
specific data is needed for one of the cathode chemistries: "LCO",
"LMO", "LFP", "NMC", "NCA", "LTO"
see
http://batteryuniversity.com/learn/article/types_of_lithium_ion
http://batteryuniversity.com/learn/article/lithium_based_batteries
What I am guessing at the moment:
- the aging mechanisms and lifetime statistics are similar
but some are more robust than others
- the maximum cell voltage (4.2V) applies to all
- charging method and charging phases are similar
but they have different capacity vs. final charging voltage curves
charging LFP beyond 3.6V doesn't add much, charging LCO beyond 3.8V
to 4.2V adds most of the charge
see http://www.powerstream.com/lithuim-ion-charge-voltage.htm
(the average force required to get an ion into a crystal location is
different)
- they have different (slow) discharge voltage curves (LFP flat at about
3.2V, LCO steadily decreasing from 3.9V)
I could be wrong.
Jan de Jong
jimkale(at)roadrunner.com Guest
Posted: Fri Nov 07, 2014 11:18 pm Post subject: lithium facts |
I have been studying lithium batteries for several years, when and where I
can find information. I am not a chemist, or electrical battery engineer.
Just a guy who uses lots of lithium batteries. I use them to power large
radio control models aircraft. Common RC models these days use batteries
similar to the type you would use in a homebuilt airplane. The RC models I
fly typically use 4 cell, 14.4 nominal volt batteries. They are discharged
at the rate of about 30 to 150 amps and get totally drained in about 10
minutes. Us modelers have also found that stopping the discharge at about
20 to 30 percent capacity remaining helps keep the cells cool and increases
their life substantially.
I have seen some lithium batteries catch fire in flight and the RC model
(normally fairly expensive - a few hundred dollars and normally built from
wood or plastic) goes down in flames.
All of the multi cell lithium batteries I use are charged with each cell in
the battery pack getting charged individually from a very special charger
normally called a balancing charger. That means if you have 4 cells, there
are 5 wires coming from a balancing charger that independently charges and
monitors each cell while it is charging. I believe that some of the high
end lithium batteries in use today have some balancing technology built into
each cell and these special batteries may be charged form a common source
like an alternator, with a single total charge voltage, sort of like the
lead acid battery charging we are all familiar with . Inside each cell or
these special lithium batteries, the automatic circuitry keeps each
individual cell at a controlled charge current and the proper float voltage
when the cell is topped off at the proper voltage for the chemistry being
used. All of this automatic control inside each cell, just means there are
many potential failure points. If any individual cell, or its automatic
charge circuitry goes bad, the whole battery may fail in a mild manor (just
quits working) or catastrophic manor (fire).
All of this automatic cell monitoring is very expensive. Failures may be
dangerous, or just very expensive.
The bottom line is if you want to switch to lithium batteries, you should
have your charge system designed by some highly qualified folks. Just
buying and installing a lithium battery can be very expensive at best, or
very dangerous at worst. Let the home builder beware. You can bet Boeing
spent some very large sums of money for that lithium battery that caught
fire in their 787 Dreamliner. Catastrophic failure is always possible no
matter how much you spend for hardware.
I work as a flight training systems instructor for a USAF squadron that
flies helicopters. For the past 50 years or so, the military forces used
Nickel Cadmium batteries in their aircraft. These batteries costs about 8
times as much as lead acid batteries, and required many man hours of service
and tests every 4 months. Recently we switched to sealed lead acid
batteries (Gel Cells). Now we pay about 5 times less than the NICADs costs,
and they don't need any regular maintenance. We just use them till they
don't come up to standards, and replace them. Much like you maintain your
car. A giant leap backwards, and we save lots of money and get better
reliability and performance, not to mention improved safety (those NICADs
had a tendency to melt down every now and then.) It doesn't get much better
than that. Of course, the quality and performance of sealed lead acid
batteries has improved by leaps and bounds over the last 50 years.
Jim Kale
henador_titzoff(at)yahoo. Guest
Posted: Sat Nov 08, 2014 5:35 am Post subject: lithium facts |
Jim,
You sound like a man of real world experience with the batteries mentioned below. I'm guessing the following:
- Much of your RC model airplane experience with lithium batteries is based on what you've been doing in the military world
- You and your military friends have been exposed to more information about lithium battery testing than us civilians have, especially as applied to aviation.
- This is probably why your military friends have not converted to lithium; instead, they went SVLA.
- The lithium data that Bob N. is testing for has probably already been generated and reported but is proprietary and/or classified.
I'm also speculating the reason Boeing has had bad luck with lithium batteries in their Dreamliner is they either didn't do enough testing, or the naysayers were overridden by the politicians who wanted to cut weight everywhere. Throw out a piece of failed test data here and there, and you're good to go thinking. They were probably in a hurry to leap frog the Frogs and Airbus. All speculation, mind you.
I could be wrong about all this, but it's my hunch.
Henador Titzoff
[quote] From: Jim Kale <jimkale(at)roadrunner.com>
Sent: Saturday, November 8, 2014 2:16 AM
Subject: RE: lithium facts
--> AeroElectric-List message posted by: "Jim Kale" <jimkale(at)roadrunner.com (jimkale(at)roadrunner.com)>
Jim Kale
Posted: Sat Nov 08, 2014 8:25 am Post subject: lithium facts |
I doubt it. Given the ease with which I have acquired
more knowledge demonstrates that the data is not the
the least bit 'secret'. Simple-ideas I've discovered
for myself are alluded if not specifically addressed
in Isador Buccmann's missives cited earlier.
I think it a certainty that any supplier who fails to included
'my' discoveries in their promotional/disclosure literature
are either ignorant of such information, don't see
why their customer would have an interest in such
esoteric knowledge or they're not eager to reveal
information that is counter-productive to a marketing
effort.
I'm reluctant to believe that anything is being deliberately
withheld for dishonorable reasons . . . there's more
tort lawyers per capita in the US than in any other
nation. Perfectly honorable suppliers are already at
considerable risk from this source of cultural misery . . .
deliberate obfuscation of hazards by any suppler
puts them at 1000x the risk.
I think the Boeing story is exceedingly complicated and
yes, fraught with some unhappy trade-offs. The testing
was extensive but went mostly toward the notion of
assessing risk based on failure rates which in turn
were based on things not known to be poor assumptions.
This is why my teachers encouraged me to assume the
worst - assume a failure rate of 1 per flight hour
then mitigate the risks of that failure. This is
the approach ultimately adopted by Boeing and friends.
It's the approach adopted by True Blue and has become
the regulatory modus operandi as well.
The BIG difference between the Boeing experience and
the OBAM (or True Blue) experience is chemistry. The
products of intense interest to us exploit LiFePO couples
common to what now must be billions of examples ranging
from the tiniest of consumer electro-whizzies up to
the hybrid automobiles. The Tesla uses THOUSANDS of
AA sized, LiFePO cells in parallel. The True Blue
is a similarly complex array of cylindrical cells
produced in the millions per week.
I'll respond to Jim's generous sharing of experience
and insights in depth . . . but right now, there are
two car-loads of children and grand-children on their
way to M.L. help grandma and grandpa take down a
dying tree . . . and trim up some others.
Posted: Sat Nov 08, 2014 9:07 am Post subject: lithium facts |
This is rather unusual, Bob, that you responded to my email to the AE list, yet my two previous emails have not made it to the list. If you are filtering my emails to the list, then it's okay with me, but you've never told me why you are filtering them. If you want me off your list, why not simply take me off the email roster?
Henador Titzoff
[quote] From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Saturday, November 8, 2014 11:25 AM
Subject: Re: lithium facts
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
effort.
and insights in [quote][b]
lyleapgmc
Posted: Sat Nov 08, 2014 11:28 am Post subject: lithium facts |
I have been looking at lithium battery packs and find there is a wide variation in the per-cell voltage. Some are as low as 1.2V and up to 1.8V and 3.7V. The discussion here indicates that 3.7V is the standard for lithium cells.
Were there or are there lithium cells of lower voltage?
[quote]--
Lyle
Sent from my Gateway E4610D desktop
Posted: Sat Nov 08, 2014 11:53 am Post subject: lithium facts |
On 11/8/2014 8:31 AM, Henador Titzoff wrote:
| Quote: | Jim,
| I would guess not. Rather that the RC model community is, and has been, deep into lithium battery technology for some time. Perhaps leaders in the field, at least from an OBAM standpoint. My brother has been in RC competitively for decades. As many other have, he has converted 100% to lithium (probably LiPo) battery power for his competition aircraft. They buy them, use them, abuse them, measure them and fail them. I'm sure there's a wealth of real world experience AND DATA there, but I have no idea whether it would be useful in our environment.
[quote] - You and your military friends have been exposed to more information about lithium battery testing than us civilians have, especially as applied to aviation.
Henador Titzoff
| Quote: | From: Jim Kale <jimkale(at)roadrunner.com> (jimkale(at)roadrunner.com)
Jim Kale
Posted: Sat Nov 08, 2014 12:49 pm Post subject: lithium facts |
At 11:03 2014-11-08, you wrote:
| Quote: | This is rather unusual, Bob, that you responded to my email to the
Henador Titzoff
I have no ability nor inclination to 'filter' anyone.
I've had to ask several individuals to quit the list
over the years but I've not advocated for any form
of 'firewall' against anyone.
Posted: Sat Nov 08, 2014 12:50 pm Post subject: lithium facts |
Tesla does not use LiFePO4, but something more energetic, I believe:
http://batteryuniversity.com/learn/article/safety_of_lithium_ion_batteries
Posted: Sat Nov 08, 2014 2:15 pm Post subject: lithium facts |
At 14:48 2014-11-08, you wrote:
here is one of several articles I see that prompted my
assertion . . .
http://tinyurl.com/pqo59cr
raymondj(at)frontiernet.n Guest
Posted: Sat Nov 08, 2014 2:36 pm Post subject: lithium facts |
Greetings Mr. Titzoff,
I have been on this list for a number of years and have seen several
glitches that resulted in my and other's emails not showing up.
Sometimes it was something that the sender changed, sometimes it was a
change made by the sender's ISP, and sometimes it was something Matt D.
did. I don't really have any helpful suggestions, just wanted to
mention all the possible places where things can go awry. If I can be
of assistance in helping sort this out, please let me know.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 11/08/2014 02:48 PM, Robert L. Nuckolls, III wrote:
> Henador Titzoff
Posted: Sat Nov 08, 2014 4:38 pm Post subject: lithium facts |
Raymond,
I appreciate your offer to troubleshoot my problem, but I've already input a trouble ticket to my ISP. Let me see what they have to say about this first, then I'll contact you if they or I don't resolve the problem.
Thank you very much.
Henador Titzoff
[quote] From: rayj <raymondj(at)frontiernet.net> To: aeroelectric-list(at)matronics.com Sent: Saturday, November 8, 2014 5:34 PM Subject: Re: lithium facts
--> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>Greetings Mr. Titzoff,I have been on this list for a number of years and have seen several glitches that resulted in my and other's emails not showing up. Sometimes it was something that the sender changed, sometimes it was a change made by the sender's ISP, and sometimes it was something Matt D. did. I don't really have any helpful suggestions, just wanted to mention all the possible places where things can go awry. If I can be of assistance in helping sort this out, please let me know.do not archiveRaymond JulianKettle River, MNThe things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968)On 11/08/2014 02:48 PM, Robert L. Nuckolls, III wrote:> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III"> <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>>> At 11:03 2014-11-08, you wrote:>> This is rather unusual, Bob, that you responded to my email to the AE>> list, yet my two previous emails have not made it to the list. If you>> are filtering my emails to the list, then it's okay with me, but>> you've never told me why you are filtering them. If you want me off>> your list, why not simply take me off the email roster?>>>> Henador Titzoff>> I have no ability nor inclination to 'filter' anyone.> I've had to ask several individuals to quit the list
ceengland7(at)gmail.com Guest
Posted: Sat Nov 08, 2014 6:47 pm Post subject: lithium facts |
I would 2nd Raymond's observations.
Over the last 6 or 8 months, I've sent numerous emails to various
unrelated lists (not all Matt's) that never appeared as an email from
the list back to me, but have seen others' replies to those emails. When
checking the archives, the original email appears there.
If you're saying that you didn't get your own email but saw a reply to
it on the list, then it obviously went to the rest of the list, but
wasn't returned to you by the (automated) list. Or, according to some
googling, it might be related to your own ISP or email provider.
FWIW,
Charlie
On 11/8/2014 4:34 PM, rayj wrote:
Raymond Julian
Kettle River, MN
(1902-1968)
>> Henador Titzoff
> Bob . . .
Posted: Sun Nov 09, 2014 3:50 am Post subject: lithium facts |
Charlie,
I've read on this list of others having problems like what you describe below and have even seen the very same problem on two other lists, non-Matt related. If it works for many and not for a few, then it has to be related to those few, including me. When Bob wrote me back, it confirmed exactly what you describe below - something is wrong on my end of the pipe. I'm actively checking it out and in fact, this email is a test email to see if a "fix" solves the problem. Yes, IT works on weekends, cause I have them on the Essential bus.
Henador Titzoff
[quote] From: Charlie England <ceengland7(at)gmail.com>
Sent: Saturday, November 8, 2014 9:45 PM
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
FWIW,
Charlie
[quote] --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>
Raymond Julian
Kettle River, MN
(1902-1968)
>> Henador Titzoff
> over the years but I've not [quote][b]
Posted: Sun Nov 09, 2014 9:06 am Post subject: lithium facts |
At 01:16 2014-11-08, you wrote:
--> AeroElectric-List message posted by: "Jim Kale" <jimkale(at)roadrunner.com>
An excellent narrative illustrating a substantial difference in the way the aviation community uses batteries.
Unlike ALL motive power applications, the engine-crank/standby applications use about 4% of the battery's capacity during a few seconds per flight cycle . . . recharging is not expected to complete in less than 30 minutes. But most important . . . there are NO conditions under which our batteries are expected/ permitted to experience substantial temperature rise.
I suggest that the only 'connection' between the motive power applications (from model airplanes up to plug-n-drive forklifts and cars) and virtually all crank-and-sit applications (most cars, trucks, and airplanes) is the word 'lithium'.
I'm pretty sure these were not lithium-iron phosphate cells. However, it is certain that they were HIGHLY stressed compared to aviation expectations/design goals.
normally called a balancing charger. If any individual cell, or its automatic charge circuitry goes
bad, the whole battery may fail in a mild manor (just quits working)
To be sure, the battery management systems (BMS) included as part of the qualified True Blue products adds significant cost to the battery. But be aware that "BMS" can mean anything from a simple poly-fuse built into the end-cap of a cell all the way up to a Cray-sized byte thrasher that monitors cell voltage, input-output currents, temperatures, local barometric pressure and phases of the moon.
The Boeing experience has few more parallels to our design and risk reduction goals than motive power applications but they're not terribly germane. We can draw more on the lessons-learned by Cessna and True-Blue than upon anything that happened in a 787
The manner in which we will use lithium will not stress the cells hard at all. We're only going to charge to 50-60% of the chemistry's potential. We only discharge to the tune of 4-5% per flight cycle at most . . . the give 30 minutes to replace that trivial taxation of store energy. Ideally, we NEVER deeply discharge the battery. A totally different world than what is expected of most lithium products in service today.
Exactly. Your story has been repeated many times over the years. Skip Koss at Concorde can recite a number of instances were Concorde SVLA products have successfully replaced Ni-Cad in military and air-transport applications for much improved cost of ownership benefits. The sealed lead-acid battery took cost of ownership a quantum jump in the right direction. However, my own limited studies into the lithium opportunities suggest that 'going-lithium' just to save weight while giving up performance and risk benefits of SVLA may not be justifiable in every owner-operator's play-book.
Watch this space . . .
Posted: Sun Nov 09, 2014 4:52 pm Post subject: lithium facts |
| Quote: | Interesting.
when specific data is needed for one of the cathode chemistries:
"LCO", "LMO", "LFP", "NMC", "NCA", "LTO"
see
I note that in BU-204, the chart cites an LFP
charge limit of 3.6 volts . . . which is contrary
to the claims and practices of the market place
offerings of LFP cells . . . and not in agreement
with my tests either.
| Quote: | What I am guessing at the moment:
agreed
| Quote: | - the maximum cell voltage (4.2V) applies to all
agreed . . . I've not seen any literature that
argues with this with the exception noted above.
| Quote: | - charging method and charging phases are similar
How do you arrive at this? The cells that I'm
testing demonstrate a doubling of stored energy
by extending the charge beyond 3.6 volts. The
fact remains that incorporating an array of 4-cell
strings into lead-acid optimized power systems
will indeed limit charge voltage to something on
the order of 3.7 volts . . . and even if we COULD
charge the cell to 100%, it seems unlikely we can
always exploit that energy due to its elevated
delivery voltage.
May well be. Don't have any of those cells to test and
besides, we really NEED the LPF characteristic that
tolerates heave discharge values along with the
lower levels of risk.
| Quote: | - they have different (slow) discharge voltage curves (LFP flat at
about 3.2V, LCO steadily decreasing from 3.9V)
Not sure that 'flatness' of discharge has any big
significance in our applications. The battery-only
loads in aircraft are functional from 15 down to 11
volts (which is right at the recommended limit for
discharging lithium in a 4-cell string).
Posted: Mon Nov 10, 2014 3:26 pm Post subject: lithium facts |
Interesting article concerning LiFePO4 and dynamic behaviour:
http://epg.eng.ox.ac.uk/sites/default/files/Howey/HEVC_IET_Birkl_Howey.pdf
An equivalent circuit was developed for an A123 APR18650 cell with 3
series elements:
a series resistance of a few tens of mOhm,
a time constant of a few seconds that resolves to a series resistance of
few mOhm,
a time constant of a few tens of seconds that resolves to a series
(there are extremes at high and low temperatures and high and low SOC)
Something to think about when designing a balancing algorithm.
A voltage observed a couple of seconds after the application of a shunt
cannot be compared directly to that voltage before the shunt application.
Estimating the final voltage (from slope and value at two moments )
would take tens of seconds...
Something else I would want to hear about from a supplier of batteries
with built-in BMS.
Jan de Jong
