Alfred Buess
Posted: Tue Nov 11, 2014 10:18 am Post subject: AW: classic tail wheel |
Frank,
Where are you located? I have a spare stern post if you need to redo the
whole spring installation.
Regards, Alfred
Alfred Buess
CH-3700 Spiez, Switzerland
Europa XS HB-YKI, Ercoupe 415-E N94804
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von spcialeffects
Gesendet: Dienstag, 11. November 2014 18:49
An: europa-list(at)matronics.com
Betreff: classic tail wheel
--> <spcialeffects(at)aol.com>
Hello all. I am building a classic mono and am fitting the tail wheel at the
moment. I am also using the XS stern post instead of the classic build
option. Today i drilled the hole in the stern post, in the correct location
BUT i followed the wrong line. I drilled it in line with the angle of the
spring mount of the wheel and not the fuselage bottom . I have the
correct distance from the bottom of the fuselage and the spring end 235mm,
plus i have a good fit around the spring arm through the stern post but i
now need 12 plys or shims under where the bolt goes.
SO what im asking is should i go with the 12 shims and use a longer
bolt OR file the hole at the bottom and and get the correct 5 or so shims
but have an untidy fit around the stern post area? All views/advice welcome.
Thanks Frank
http://forums.matronics.com/viewtopic.php?p=433387#433387
spcialeffects
Posted: Tue Nov 11, 2014 11:30 am Post subject: Re: AW: classic tail wheel |
Thanks Alfred but thats a bit drastic to start again. All can be corrected its just which is the best way forward
