floridawing
Posted: Wed Dec 31, 2014 11:52 am Post subject: Field of grounds with local bat ground |
Hello, I have a HR2. The battery is mounted in the back with a local ground. The engine is grounded to the engine mount with a strap through a engine mount bolt. There is a field of grounds mounted to the firewall. The field of grounds is only receiving its ground through the firewall and no other straps. All my avionics are grounded to this. My question is is the firewall a good enough ground for all the avionics? Thank you.
voltar(at)vx-aviation.com Guest
Posted: Thu Jan 01, 2015 8:54 am Post subject: Field of grounds with local bat ground |
I have a similar config, except I grounded the engine directly to the firewall using the brake reservoir bolt. No problems.
I was reluctant to ground to the engine mount due to the remote possibility of increased corrosion of the highly stressed engine mount bolts.
Vern
Quote: | On Dec 31, 2014, at 11:52 AM, floridawing <lb757(at)hotmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=436461#436461
ceengland7(at)gmail.com Guest
Posted: Thu Jan 01, 2015 9:55 am Post subject: Field of grounds with local bat ground |
Plus the fact that steel is a relatively poor conductor, and running
current through it creates at least a mediocre magnet (fun for
compasses, etc).
Charlie
Vern
floridawing
Posted: Thu Jan 01, 2015 1:01 pm Post subject: Re: Field of grounds with local bat ground |
Thank you Vern and Charlie. Would I be better off adding a second ground strap to the engine and running it up to the field of grounds on the firewall or should I only use the one strap I have but remove the end attached to the engine mount and attach it instead to the field of grounds on the firewall? Thank you!
jimkale(at)roadrunner.com Guest
Posted: Thu Jan 01, 2015 5:02 pm Post subject: Field of grounds with local bat ground |
Grounds can be tricky on composite or wood airplanes. It is easy to get
different parts of the airplane with grounds not being well bonded to each
other. In that case, grounds can have different voltages on them and you
get what is commonly referred to as GROUND LOOPS. All sorts of funny things
happen to electrical equipment which don't want to operate like they should.
It is extremely difficult to trace the problems. Be very careful to have
all ground points bonded to each other very well with redundant paths if
possible. On metal airplanes, grounds are less difficult, but any metal
corrosion can cause the same problems.
tim2542(at)sbcglobal.net Guest
Posted: Thu Jan 01, 2015 8:51 pm Post subject: Field of grounds with local bat ground |
I would add be careful adding additional grounds between the engine case and battery. Any electrical equipment installed on the engine should be grounded to the engine. If you run separate grounds for other equipment and the main engine ground is compromised then your Pmag or whatever will begin to carry the starter and alternator loads. Unless it's sized for that load....smoke.
[quote] On Jan 1, 2015, at 5:01 PM, <jimkale(at)roadrunner.com> <jimkale(at)roadrunner.com> wrote:
floridawing
Posted: Fri Jan 02, 2015 6:24 am Post subject: Re: Field of grounds with local bat ground |
Thank you everyone for the information!
Posted: Fri Jan 02, 2015 3:51 pm Post subject: Field of grounds with local bat ground |
Actually, DC POWER grounding in composite airplanes is stone simple.
See chapter 15 of the 'Connection.
BONDING for purposes of achieving grounds at radio frequencies
and issues of LIGHTNING protection are another matter entirely
. . . usually ignored in OBAM aircraft as physically, economically
and operationally impractical. Adding the necessary and useful
ground plane under comm and xponder antennas is generally
all that's required . . . also stone simple . . . see
chapter 13 . . .
Posted: Fri Jan 02, 2015 6:47 pm Post subject: Field of grounds with local bat ground |
It is only STONE SIMPLE if one knows where to get the information, can
understand and apply the information. Thank you for the reference.
