bob88
Posted: Wed Dec 31, 2014 1:56 pm Post subject: propellor governor |
I have a new governor from Vans (but not a Vans supplied engine). The model is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I thought I got it for the IO 540...is the governor OK for either engine?
larkrv10(at)gmail.com Guest
Posted: Wed Dec 31, 2014 2:24 pm Post subject: propellor governor |
Bob that's what they sent me for my IO 540. I just rotated the control arm on mine for proper alignment with the prop cable. If you're interested, search "MT P-860-3 Governor rotation" on VAF.
Rick
#40956
Southampton, Ont
On Wed, Dec 31, 2014 at 4:56 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=436467#436467
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
     -Matt Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
Kelly McMullen
Posted: Thu Jan 01, 2015 7:29 am Post subject: propellor governor |
Nice to see that nothing has changed at Van's. They only sell the governor with the gear ratio for the narrow deck engine, because that is what 410RV was built with. Of course all the engines they sell are new wide deck which is supposed to have a different gear ratio. MT P-860-5 if I recall correctly is the correct one and only needs some repositioning of the arm, depending on whether you run the cable below or above the cylinders.
On Wed, Dec 31, 2014 at 3:20 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote]Bob that's what they sent me for my IO 540. I just rotated the control arm on mine for proper alignment with the prop cable. If you're interested, search "MT P-860-3 Governor rotation" on VAF.
Rick
#40956
Southampton, Ont
| Quote: | --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Thu Jan 01, 2015 7:46 am Post subject: propellor governor |
As Kelly says the P-860-3 fits the narrow deck engine, which is what mine is
Bob Turner
Posted: Thu Jan 01, 2015 8:04 pm Post subject: Re: propellor governor |
Well, I bought the Hartzel governor directly from Vans, and it works fine.
[quote="Kelly McMullen"]Nice to see that nothing has changed at Van's. They only sell the governor with the gear ratio for the narrow deck engine, because that is what 410RV was built with. Of course all the engines they sell are new wide deck which is supposed to have a different gear ratio. MT P-860-5 if I recall correctly is the correct one and only needs some repositioning of the arm, depending on whether you run the cable below or above the cylinders.
On Wed, Dec 31, 2014 at 3:20 PM, Rick Lark <larkrv10> wrote:
| Quote: | Bob that's what they sent me for my IO 540.� I just rotated the control arm on mine for proper alignment with the prop cable.� If you're interested, search "MT P-860-3 Governor rotation" on VAF.
Rick
#40956
Southampton, Ont
On Wed, Dec 31, 2014 at 4:56 PM, bob88 <marty> wrote:
| Quote: | --> RV10-List message posted by: "bob88" <marty>
[b] |
_________________ Bob Turner
RV-10 QB |
Kellym
Posted: Thu Jan 01, 2015 8:23 pm Post subject: propellor governor |
Well, the question was concerning the MT P-860-3.
I don't know how Hartzell deals with the differing gear ratio (gears)
inside the Lycoming narrow deck vs wide deck. Until about 3-4 years ago
Vans only offered the MT P-860-3.
On 1/1/2015 9:04 PM, Bob Turner wrote:
> Rick
> #40956
> Southampton, Ont
> [b]
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=436518#436518
KCHD |
rv10flyer
Posted: Sun Jan 04, 2015 8:20 pm Post subject: Re: propellor governor |
I have flown with my -3 for three years. It is perfect.
The -3 or -5 refers to splined control arm position and max rpm adjustment. Both can be adjusted. Contact MT if you must. I already did 3 1/2 yrs ago. 1-386-736-7762.
_________________ Wayne G. |
