bill mcclellan
Posted: Tue Jan 20, 2015 12:03 pm Post subject: Jamar finger brakes |
I have installed the Jamar dual brake cylinders and I have Grove brakes. It appears that Jamar requires Dot 3 or 4 brake fluid and Grove requires MIL-5606 hydraulic fluid as does Matco. I don't believe these two fluids are not compatible. Does anyone have Jamar brakes cylinders with Grove or Matco brakes? If so what brake fluid do you use and find compatible with this brake combination?
Bill McClellan
nigel_graham(at)m-tecque. Guest
Posted: Tue Jan 20, 2015 12:51 pm Post subject: Jamar finger brakes |
Bill,
The definitive document on all things "Europa Brake Fluid" can be found
on the club website at:
http://www.theeuropaclub.org/wp-content/uploads/2012/03/Brake-Fluid-review.pdf
Ian Rickard's excellent research even gives you the supplier of
replacement master and slave cylinder "O" rings for whichever fluid
system you decide on.
Nigel
On 20/01/2015 20:03, bill mcclellan wrote:
Bill McClellan
http://forums.matronics.com/viewtopic.php?p=437336#437336
christoph.both(at)acadiau Guest
Posted: Tue Jan 20, 2015 12:52 pm Post subject: Jamar finger brakes |
I have the original Jamar and Matco Brakes. I only use DOT 5.0 100%
silicone fluid. Works very well. Just don¹t get the fluid on the unpainted
plane - hard to remove!
Christoph Both
#223 Classic 912 ULS Woodcomp SR3000
Nova Scotia Canada.
Bill McClellan
tonyrenshaw268(at)gmail.c Guest
Posted: Tue Jan 20, 2015 2:16 pm Post subject: Jamar finger brakes |
Hi Bill,I hope alls we'll in your world and your first flight is getting closer. How are you progressing? I am not far from putting the top on, but am doing a major pool restoration at the moment which has become another distraction. I gather though of you haven't been building you may still have been flying. I still envy that back country flying in the canyons.Â
Tony Renshaw
On Wednesday, January 21, 2015, bill mcclellan <wilwood(at)earthlink.net (wilwood(at)earthlink.net)> wrote:
Quote: | --> Europa-List message posted by: "bill mcclellan" <[url=javascript:;]wilwood(at)earthlink.net[/url]>
Bill McClellan
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
     -Matt Dralle, List Admin.
pa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
FORUMS -
Sent from Gmail Mobile
bill mcclellan
Posted: Wed Jan 21, 2015 8:38 am Post subject: Jamar finger brakes |
Thanks, Nigel, that's helpful.
Bill
bill mcclellan
Posted: Wed Jan 21, 2015 9:57 am Post subject: Re: Jamar finger brakes |
Christoph, that's good to know that the Matco seals and plungers can take the DOT 5.0 silicon based fluid given what each manufacturer says to use. How long has your brake system been in use?
Bill
Posted: Wed Jan 21, 2015 11:40 am Post subject: Jamar finger brakes |
In use since July 2013. I noticed that callipers stick a bit once the
plane has not moved for a few weeks. Sticking both at Matco Side or Hand
Brake. But moving the handle broke it free easily. This never happened
once the plane was in use (flying once a week)
Christoph
Bill
http://forums.matronics.com/viewtopic.php?p=437418#437418
budyerly(at)msn.com Guest
Posted: Wed Jan 21, 2015 6:14 pm Post subject: Jamar finger brakes |
Bill,
Go on my website www.customflightcreations.com and download the bleeding
procedure in the Techniques section.
For your setup use only Dot 5 (not 5.1) and it works with everything as its
silicone.
Read the bleeding procedure for the Jamar. Then loctite in the Allen head
pivot bolts because they do eventually loosen and you are blessed with one
brake handle in your hand when least expecting it and needing to brake.
Bud Yerly
bill mcclellan
Posted: Tue Jan 27, 2015 4:21 pm Post subject: Jamar finger brakes |
Bud,
I had to get a new set of plungers and seals as I ruined the last set in the Jamar cylinder by usingthe 5605 fluid Grove recommends. So now I need to drain an clean the rEst of the lines to use the silicone DOT 5 fluid. Do you have a recommendation for what to use to flush the MIL-5606 out. I don't think I want to mix the DOT 5 with the 5606 residue.
Bill
Posted: Tue Jan 27, 2015 7:24 pm Post subject: Jamar finger brakes |
OOH Bill.
Dot 5 is the best for our little aircraft. Yet I have 5606 in my aircraft.
5606 only works in systems designed for mineral oil based fluid such as
Matco and Grove systems. Anything automotive is normally the standard Dot
3-4-5 types. Don't mix fluids, ever.
That said: Flushing out the lines, calipers, park brake and reservoir is a
chore. In any flush, if you choose to flush with Dot 5, the silicone can
get clumpy if you mix it with 5606. Then you have a disaster.
According to ASA: Naptha or Varsol are used to flush 5606. 5606 is mineral
based based so Naptha will keep the seals in the calipers in shape.
In automotive systems where hydraulic fluid is added accidentally to a DOT
fluid system, alcohol is recommended by automotive sites. It normally will
not hurt the caliper seals and it disolves oil based contamination. Use
about 20 psi air or more of dry air to blow out the lines and calipers.
This is messy to say the least. Wash everything afterwards, the plane, you
and the interior.
Then go ahead and reassemble the lines and push copious amounts of DOT 5
through the system calipers and lines into a clear bucket to verify the
fluid is clean and clear. Then get the brake system ready for bleeding
again. Bench bleed your master or just use my website techniques procedure
to re-bleed.
That is about all I know.
Bud Yerly
