		bigginsking
  Joined: 25 Sep 2012 Posts: 27 Location: San Diego, California
				 Posted: Wed Jan 21, 2015 8:14 am    Post subject: Leakguard tubes belong in the trash |
				Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
 The tube just wore through and leaked. I've never seen this happen to any other brand of tube.
 Of course it happened at a rather inconvenient time, I was landing at Brown Field, coming back from Mexico, when you are not supposed to get out the the aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun.
 Fly Safe,
 Bill Judge
 N84WJ, RV-8, 1103 hrs
 http://rv-8.blogspot.com/
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Bill Judge
N84WJ, RV-8 |
		kellemsm(at)yahoo.com Guest
				 Posted: Wed Jan 21, 2015 8:34 am    Post subject: Leakguard tubes belong in the trash |
				Did you put talc in when installing?
 Tough times don't lastTough people do!!
  Mike 931-993-7623
 On Jan 21, 2015, at 10:12, Bill Judge <bjudge(at)gmail.com (bjudge(at)gmail.com)> wrote:
 [quote]Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
 Fly Safe,
 Bill Judge
 ot;">www.aeroelectric.com
 books.com"">www.buildersbooks.com
 quot;">www.homebuilthelp.com
 quot;">www.mypilotstore.com
 ">www.mrrace.com
 st"">http://www.matronics.com/Navigator?RV-List
 //forums.matronics.com
				 Posted: Wed Jan 21, 2015 8:49 am    Post subject: Leakguard tubes belong in the trash |
				I had a flat once on landing rollout - ended up being caused by a sticker inside the tire rubbing the tube.  I first thought the tube was junk - until I saw the wear pattern and the respective sticker....
 Might not be your case here - but I thought I would share my failure mode.....
				 Posted: Wed Jan 21, 2015 8:55 am    Post subject: Leakguard tubes belong in the trash |
				And I had used talc.....
		steve282s(at)yahoo.com Guest
				 Posted: Wed Jan 21, 2015 11:11 am    Post subject: Leakguard tubes belong in the trash |
				All of the talc in the world will not prevent an inner tube leak if there is dirt/sand/stickers/grass/rocks/etc between the tube and tire. Even a small grain of sand will cause a leak.  Imagine the pressure between the tube and tire and then add the punishment of high speed taxi/takoffs, braking and landings.
 Steve
      On Wednesday, January 21, 2015 11:07 AM, Ralph E. Capen <recapen(at)earthlink.net> wrote:
  --> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
				 Posted: Wed Jan 21, 2015 12:49 pm    Post subject: Leakguard tubes belong in the trash |
				In my (limited) experience, a tube will       only wear through if assembled without talc or was underinflated.
        I talc everything .... tube, inside of tire and even the wheel       hub.  Extra talc on the tire bead will make tire removal much       easier down the road ... er ... airway               .
        Linn
        On 1/21/2015 11:12 AM, Bill Judge wrote:
      [quote]       Folks,         I just got a second flat and the culprit was again the           leakguard inner tube. If you're using these I recommend you           get rid of them the next time you have your tires off or           sooner.
          Fly Safe,
          Bill Judge
 No virus         found in this message.
          Checked by AVG - www.avg.com
          01/21/15     [b]
		Pilots2(at)yahoo.com Guest
				 Posted: Wed Jan 21, 2015 1:53 pm    Post subject: Leakguard tubes belong in the trash |
				Had the exact same problem a few years ago with the Dresser No Leaks. 2 of them let go on landings (about a month apart).  One split on a seam, the other had cracks like it was
 old rubber and very poor quality. I don't buy Dresser tubes anymore. Mitchelin much better quality.
 7A  7WT
 Sent from my I doohickey
 On Jan 21, 2015, at 12:48 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
 [quote]                   In my (limited) experience, a tube will       only wear through if assembled without talc or was underinflated.
        Linn
       	  | Quote: | 	 		         Folks,         I just got a second flat and the culprit was again the           leakguard inner tube. If you're using these I recommend you           get rid of them the next time you have your tires off or           sooner.
          Fly Safe,
          Bill Judge
          01/21/15
		HCRV6(at)comcast.net Guest
				 Posted: Wed Jan 21, 2015 4:32 pm    Post subject: Leakguard tubes belong in the trash |
				What Linn said, but more so.  I have over 1200 hours on a set of leakguard tubes that have been through three sets of tires so far.   Use copious amounts of talc, in my case plain ole' baby powder on all surfaces, always very slightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it around to make sure, then deflate just enough to mate the wheel halves, making certain that the tube doesn't get pinched between the wheel halves.  With all the talc you should have spread on the tube and inside the tire casing the tube moves around easily.  After the bolts are tight, partially inflate the tube again and bounce it on the floor a couple of times to again make sure the tube has no kinks or folds, then deflate once more and do it again for good measure before finally inflating to your desired pressure.  Takes a few minutes longer but sure beats flat tires.
 BTW, with my leakguards my tires lose one psi or less in six or eight weeks.
 Harry Crosby
 RV-6, coming up on 1300 hours
 To: "RV-List" <rv-list(at)matronics.com>
 Sent: Wednesday, January 21, 2015 12:48:26 PM
 Subject: Re: Leakguard tubes belong in the trash
  Linn
  	  | Quote: | 	 		  Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner.
 Fly Safe,
 Bill Judge
  01/21/15
 _blank" data-mce-href="http://www.aeroelectric.com">www.aeroelectric.com
 " target="_blank" data-mce-href="http://www.buildersbooks.com">www.buildersbooks.com
 ="_blank" data-mce-href="http://www.homebuilthelp.com">www.homebuilthelp.com
 ="_blank" data-mce-href="http://www.mypilotstore.com">www.mypilotstore.com
 ank" data-mce-href="http://www.mrrace.com">www.mrrace.com
 _blank" data-mce-href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
 t="_blank" data-mce-href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
 ta-mce-href="http://forums.matronics.com">http://forums.matronics.com
				 Posted: Wed Jan 21, 2015 4:53 pm    Post subject: Leakguard tubes belong in the trash |
				Just to expand .... pun intended ....       when the valve core is removed I inflate/deflate the tube often       using my air gun to prevent folds that Harry talks about.  One       other problem I've seen are the wrong size tube installed ....       both too small and too big.  Happens a lot when the plane uses       5.00-5 on the nose and 6.00-6 on the mains.  Not all that hard to       switch tubes.
        Linn
        On 1/21/2015 7:29 PM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote:
      [quote]                What Linn said, but more so.  I           have over 1200 hours on a set of leakguard tubes that have           been through three sets of tires so far.   Use copious amounts           of talc, in my case plain ole' baby powder on all surfaces,           always very slightly inflate the tube before mating the wheel           halves to make certain that the tube is straight in the tire           with no folds or kinks, even wiggle it around to make sure,           then deflate just enough to mate the wheel halves, making           certain that the tube doesn't get pinched between the wheel           halves.  With all the talc you should have spread on the tube           and inside the tire casing the tube moves around easily.            After the bolts are tight, partially inflate the tube again           and bounce it on the floor a couple of times to again make           sure the tube has no kinks or folds, then deflate once more           and do it again for good measure before finally inflating to           your desired pressure.  Takes a few minutes longer but sure           beats flat tires.
          Harry Crosby
                   From: "Linn           Walters" <flying-nut(at)cfl.rr.com> (flying-nut(at)cfl.rr.com)
            To: "RV-List" <rv-list(at)matronics.com> (rv-list(at)matronics.com)
              Linn
                Fly Safe,
                Bill Judge
		Gary.A.Sobek
				 Posted: Wed Jan 21, 2015 8:13 pm    Post subject: Leakguard tubes belong in the trash |
				Been running Michelim Air Stop tubes since May 2005.  Almost 1,300 flight hours on the tubes according to log and not sure how many tires without going through the log more.  Also using plain old baby talc with procedures and service like Harry Crosby.  Looks like I had 1,671 hours on the tubes that Van provided.  They needed air once a month.
 Gary A. Sobek
 2,954+ Flying Hours Pennsylvania, USA
 Date: Wed, 21 Jan 2015 19:52:22 -0500
 To: rv-list(at)matronics.com
 Subject: Re: RV-List: Leakguard tubes belong in the trash
        Linn
          Harry Crosby
              Linn
                Fly Safe,
                Bill Judge
 _blank">www.aeroelectric.com
 " target="_blank">www.buildersbooks.com
 ="_blank">www.mypilotstore.com
 ank">www.mrrace.com
 get="_blank">http://www.matronics.com/Navigator?RV-List
		Ollie Washburn
  Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
				 Posted: Thu Jan 22, 2015 6:02 am    Post subject: Leakguard tubes belong in the trash |
				I'm with you Harry, I've had the same results. I do carry a spare nose tire tube.
 Ollie
 On Jan 21, 2015, at 7:29 PM, HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote:
 [quote]What Linn said, but more so.  I have over 1200 hours on a set of leakguard tubes that have been through three sets of tires so far.   Use copious amounts of talc, in my case plain ole' baby powder on all surfaces, always very slightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it around to make sure, then deflate just enough to mate the wheel halves, making certain that the tube doesn't get pinched between the wheel halves.  With all the talc you should have spread on the tube and inside the tire casing the tube moves around easily.  After the bolts are tight, partially inflate the tube again and bounce it on the floor a couple of times to again make sure the tube has no kinks or folds, then deflate once more and do it again for good measure before finally inflating to your desired pressure.  Takes a few minutes longer but sure beats flat tires.
 Harry Crosby
 From: "Linn Walters" <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
 To: "RV-List" <rv-list(at)matronics.com (rv-list(at)matronics.com)>
  Linn
 ">www.mrrace.com
  _________________ Ollie RV6-A & Rans S7S
  Central FL |
