snaproll(at)whidbey.com Guest
Posted: Wed Feb 04, 2015 1:49 pm Post subject: 1984 Glasair SH 1 |
I have a 1 x 1 area that I need to re Gel Coat. Glasair is of no help. Fortunately airplane has always been hangered so I don’t think too much UV fade. This has fleck in it and I believe it was called pearl back in the day. Does anyone have a matching code that may be a start point for me? Looks like Sea Ray boats had a pearl gel coat in that time frame but difficult to choose of an LCD screen. Any Help Appreciated!!!!
Cheers,
Bob Granley
| | - The Matronics Glasair-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Craymondw(at)aol.com Guest
Posted: Wed Feb 04, 2015 2:15 pm Post subject: 1984 Glasair SH 1 |
Gel coat is used to easily remove parts from a mold and to cover the fabric with a smooth finish. I painted my Glasair Diamond white to protect it from the sun's rays. If you haven't painted the gel coat I would bring a chip of it to a paint store to match it. But I would first spray on Feather Fill to fill in the area. I know a painter that repaints damaged areas that uses a feathering technique. After he paints the repaired area he mists out twice the area repaired and it is hardly noticeable. His name is Jeff and works out of Cartersville airport in Georgia. If you decide to repaint the whole plane, I would use first use a white epoxy primer and Pittsburg three process system of base coat, clear metalic and top coat. I sanded off my first paint job and replaced it using the Pittsburg system and shed over forty pounds off the plane. Before you paint it, to avoid peeling, rough up both the gel coat and epoxy primer using 220 grit paper. My finish is nine years old and looks new!! Chuck Raymond Glasair N16CD
In a message dated 2/4/2015 4:49:54 P.M. Eastern Standard Time, snaproll(at)whidbey.com writes:
Cheers,
Bob Granley
href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigator?Glasair-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Thu Feb 05, 2015 10:32 am Post subject: 1984 Glasair SH 1 |
Good Morning Chuck,
Thanks so much for the quick response. Your suggestions make a lot of sense as I do not have any experience with gel coat. I really do not want to paint the whole airplane as it is in good shape. This is a repair of a damaged area that is quite small. I made some auumptions that were wrong in that I thought the gel coat was pearl where in fact it does look like a pearl paint on top of a white gel coat. Your feather technique looks like best method for me.
Thanks Again
Bob Granley
From: Craymondw(at)aol.com [mailto:Craymondw(at)aol.com]
Sent: Wednesday, February 04, 2015 2:15 PM
To: glasair-list(at)matronics.com
Subject: Re: 1984 Glasair SH 1
In a message dated 2/4/2015 4:49:54 P.M. Eastern Standard Time, snaproll(at)whidbey.com (snaproll(at)whidbey.com) writes:
Cheers,
Bob Granley
| 0123456789 | Quote: | | ==================================== | 0 | Quote: | | ==================================== | 1 | Quote: | | ==================================== | 2 | Quote: | | ==================================== | 3 | Quote: | | ==================================== | 4 | Quote: | | ==================================== | 5
