p-a.austin(at)xnet.co.nz Guest
Posted: Fri Mar 27, 2015 11:56 pm Post subject: Europa-List Digest: 2 Msgs - 03/27/15 |
___________________________ Message 2 _____________________________________
Time: 05:31:50 PM PST US
Subject: Skyforce GPS
From: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
I experienced the same problem, traced to the Skyforce antenna wire, my GPS sits above my Radio (Becker)and the coiled up Antenna wire had moved close to the Radio. wrapped the coil in tin foil put it above the GPS and attached it to the underside of the Panel, problem solved.
Hope this helps.
Peter
ZK-ZEB
[quote]Hi, All.
Have the standard GPS installation in my Europa, and I am getting a constant timed
flash of interference coming through the head set.
Switch the GPS OFF and the flash of interference stops,
Pull the unit out of its housing by about 3 inches with it turned on and the interference
has gone,
What is causing this constant timed flash of interference.
1.If I can fix the cause of it,
2.How can I shield the GPS unit from picking this signal up,
As I said pull the unit away from its housing by about 3 " and its gone.
Regards.
Alan
http://forums.matronics.com/viewtopic.php?p=439968#439968
- The Europa-List --> &n========================
