kearney
Posted: Sat Jun 06, 2015 6:44 pm Post subject: Oil On The Belly |
Hi
No this is not a kinky post .....
Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. Until recently these were lost the chaos that is my garage. As I needed to clean my belly (the RV10 that is) I decided to give this rediscovered product a go.
It did an excellent job of removing a very heavy oil layer that was deposited during my engine break-in. Much, much nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly.
Anyway. this will be my product of choice in the future.
Cheers
Les
cooprv7(at)yahoo.com Guest
Posted: Sat Jun 06, 2015 7:53 pm Post subject: Oil On The Belly |
On sale at Amazon now, $17.43/gallon and Prime available.Marcus
On Saturday, June 6, 2015 10:55 PM, kearney <kearney(at)shaw.ca> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=443160#443160
http://forums.matronics.cosp; -nics.com/contribution" target="_blank">http://www.matronics.com/contribut===============
jmjones2000(at)mindspring Guest
Posted: Sat Jun 06, 2015 8:15 pm Post subject: Oil On The Belly |
Be careful with simple green. It is very abrasive and will etch paint and aluminum. We are not allowed to use it on our King Airs, or Lear jets. Someone made the mistake of using it and although it did indeed remove the oil and carbon very well, it etched the paint and the aircraft had to be repainted.
Dawn with warm water in a squirt bottle can work well also.
Justin
| Quote: | On Jun 6, 2015, at 18:44, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
Kelly McMullen
Posted: Sat Jun 06, 2015 8:25 pm Post subject: Oil On The Belly |
There is Simple Green, original product, which the military banned from its aircraft because it was corrosive. The Extreme Aircraft Simple Green was developed to correct that, and is supposed to be safe and military approved.
On Sat, Jun 6, 2015 at 9:12 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
[quote]--> RV10-List message posted by: Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)>
Justin
> On Jun 6, 2015, at 18:44, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
> Hi
> Cheers
> Les
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
A&P/IA, EAA Tech Counselor
KCHD |
kearney
Posted: Sat Jun 06, 2015 8:43 pm Post subject: Oil On The Belly |
Justin
There is a difference between Simple Green and Extreme Simple Green. The latter is safe the former not so much.
Cheers
Led
| Quote: | On Jun 6, 2015, at 10:12 PM, Justin Jones <jmjones2000(at)mindspring.com> wrote:
Justin
> Hi
> Cheers
> Les
rv10pro(at)gmail.com Guest
Posted: Sat Jun 06, 2015 9:21 pm Post subject: Oil On The Belly |
Simple Green reformulated a new product "Aviation Approved". It is relabeled for aircraft. The issue of hydrogen embrittlement and swelling of tefzel wiring was corrected. The product Les was referencing to was offered at Oshkosh when the product was released.
The regular stuff is still bad. On Jun 6, 2015 9:17 PM, "Justin Jones" <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:[quote]--> RV10-List message posted by: Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)>
Justin
> Hi
> Cheers
> Les
flysrv10(at)gmail.com Guest
Posted: Sun Jun 07, 2015 6:39 am Post subject: Oil On The Belly |
You can use Goop and paper towel without the abrasives Does a good job too.
do no archive
| Quote: | On Jun 7, 2015, at 1:17 AM, John Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
The regular stuff is still bad. On Jun 6, 2015 9:17 PM, "Justin Jones" <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote: | Quote: | --> RV10-List message posted by: Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> Be careful with simple green. It is very abrasive and will etch paint and aluminum. We are not allowed to use it on our King Airs, or Lear jets. Someone made the mistake of using it and although it did indeed remove the oil and carbon very well, it etched the paint and the aircraft had to be repainted. Dawn with warm water in a squirt bottle can work well also. Justin > On Jun 6, 2015, at 18:44, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote: > > --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> > > Hi > > No this is not a kinky post ..... > > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. Until recently these were lost the chaos that is my garage. As I needed to clean my belly (the RV10 that is) I decided to give this rediscovered product a go. > > It did an excellent job of removing a very heavy oil layer that was deposited during my engine break-in. Much, much nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. > > > Anyway. this will be my product of choice in the future. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=443160#443160 > > > > > > > > > > =========== -List" target="_blank">http://www.matronics.com/Navigator?RV10-List =========== FORUMS - _blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ===========
brunk
Joined: 08 Jan 2013 Posts: 25 Location: Corpus Christi, texas
Posted: Sun Jun 07, 2015 6:46 am Post subject: Oil On The Belly |
I use GoJo without the abrasive on the belly. It gets the oil off easily and leaves a cleaned shiny finish. Robert
On Jun 7, 2015, at 12:17 AM, John Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
Justin
> Hi
> Cheers
> Les
_________________ Robert E. Brunkenhoefer |
Kelly McMullen
Posted: Sun Jun 07, 2015 7:12 am Post subject: Oil On The Belly |
GoJo original, in a tub, without pumice works great. Getting harder to find as marketeers think everyone wants pumice to scrub their greasy hands.
On Sun, Jun 7, 2015 at 7:43 AM, Robert Brunkenhoefer <robertbrunk(at)mac.com (robertbrunk(at)mac.com)> wrote:
Justin
> Hi
> Cheers
> Les
KCHD |
