Posted: Wed Jun 10, 2015 5:11 am Post subject: re annual C I |
You cannot do the conditional inspection an log “I certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of Appendix D to Part 43, and was found to be in a condition for safe operation” without doing the oil change and filter inspection.
See Part 43 Appendix D (d)(3).
Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net
Sent: Wednesday, June 10, 2015 8:06 AM
To: RV-List Digest Server
Subject: re anual C I
Thanks for all the replies, I anticipated the answer, but then again, maybe? I have been doing most of it, then my A&P finishes with me and does the logs. Now, re oil change with so little time.(thinking 100 hr comparison) What advise there? I am thinking change oil but not filter, or would you advise, not even changing oil? Thanks in advance, Charlie Heathco
www.avast.com
Quote: | http://www.matronics.com/Navigator?RV-List | 01234567
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Wed Jun 10, 2015 6:26 am Post subject: re annual C I |
I think we’ll get a debate going here, because Part 43 does not apply to:
“(1) Any aircraft for which the FAA has issued an experimental certificate, unless the FAA has previously issued a different kind of airworthiness certificate for that aircraft; or
(2) Any aircraft for which the FAA has issued an experimental certificate under the provisions of §21.191 (i)(3) of this chapter, and the aircraft was previously issued a special airworthiness certificate in the light-sport category under the provisions of §21.190 of this chapter.”
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Wednesday, June 10, 2015 8:11 AM
To: rv-list(at)matronics.com
Subject: RE: re annual C I
Carl
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of cheathco(at)cox.net (cheathco(at)cox.net)
www.avast.com
01234567890123456789
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Kellym
Posted: Wed Jun 10, 2015 7:15 am Post subject: re annual C I |
Not much of a debate. It is in the standard operating limitations..which
not everyone has, but in general you must use a checklist for your
condition inspection that at a minimum includes everything in Part 43,
Appendix D.
The inspection is the same as type certified aircraft. Only the wording
and who can do it are different.
Kelly
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Carl Froehlich
*Sent:* Wednesday, June 10, 2015 8:11 AM
*To:* rv-list(at)matronics.com
*Subject:* RE: re annual C I
inspection.
Carl
<mailto:owner-rv-list-server(at)matronics.com>
*cheathco(at)cox.net <mailto:cheathco(at)cox.net>
*Sent:* Wednesday, June 10, 2015 8:06 AM
*To:* RV-List Digest Server
*Subject:* re anual C I
Charlie Heathco
Avast logo <https://www.avast.com/antivirus>
www.avast.com <https://www.avast.com/antivirus>
*http://www.matronics.com/Navigator?RV-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
KCHD |
Gary.A.Sobek
Posted: Wed Jun 10, 2015 7:18 am Post subject: re annual C I |
BUT the Operating Limitations that were issued with the 8130-7 Special Airworthiness Certificate says:
Quote: |
Condition inspections must be recorded in the aircraft maintenance records showing the following, or a similarly worded, statement:
“I certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of 14 CFR part 43 appendix D, and was found to be in a condition for safe operation.”
The entry will include the aircraft’s total time-in-service, and the name, signature, certificate number, and type of certificate held by the person performing the inspection. 96 800x600 <![endif]--> Normal 0 false false false EN-US JA X-NONE <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]--> | 43 Appendix D part (d)(3) says nothing about oil change.
http://rgl.faa.gov/Regulatory_and_Guidance_Library%5CrgFAR.nsf/0/F7054277E4C9DC9586257913006500B2?OpenDocument
Quote: | (d) Each person performing an annual or 100-hour inspection shall inspect (where applicable) components of the engine and nacelle group as follows: (3) Internal engine--for cylinder compression and for metal particles or foreign matter on screens and sump drain plugs. If there is weak cylinder compression, for improper internal condition and improper internal tolerances. | IF the owner operator recently did an oil change and the Repairman / A&P was not around to witness, the oil could be returned to the engine after the pickup screen is inspected. The pickup screen inspection would remove all the oil out of the engine. The cost for the labor to do the task in this manor could approach the price of new oil.
On 06-10-2015 10:25 AM, Bob Collins wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Carl Froehlich
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Carl
www.avast.com
0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9
0 [b]
john(at)trollingers.com Guest
Posted: Wed Jun 10, 2015 7:51 am Post subject: re annual C I |
Looking at Part 43, I do not see where it requires an oil change? It only mentions oil twice and neither time does it refer to changing the oil.
On Wed, Jun 10, 2015 at 9:10 AM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
You cannot do the conditional inspection an log “I certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of Appendix D to Part 43, and was found to be in a condition for safe operation” without doing the oil change and filter inspection.Â
Â
Â
Carl
Â
Â
Â
Subject: RV-List: re anual C I
Â
Thanks for all the replies, I anticipated the answer, but then again, maybe? I have been doing most of it, then my A&P finishes with me and does the logs. Now, re oil change with so little time.(thinking 100 hr comparison) What advise there? I am thinking change oil but not filter, or would you advise, not even changing oil? Thanks in advance, Charlie HeathcoÂ
Â
www.avast.com
 01234567
8
Posted: Wed Jun 10, 2015 8:14 am Post subject: re annual C I |
Good point – but it does say to look at screens and such for metal particles or foreign matter. I guess you can do this without changing the oil or you can drain the oil and reuse it. I’d offer that the pain and mess to do either is not worth it.
I also read this as needing to cut open the oil filter to look for metal particles. Other may disagree.
So – while not optimal ground run the engine to get the oil temp up and just change the oil and filter.
Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Trollinger
Sent: Wednesday, June 10, 2015 11:51 AM
Subject: Re: re annual C I
Carl
www.avast.com
01
234567890123456789
