Nose gear leg cutout length?
rv10rob(at)gmail.com
PostPosted: Wed Jun 10, 2015 12:14 pm    Post subject: Nose gear leg cutout length? Reply with quote
I lengthened the nose gear leg cutout in the bottom of my cowl to make it easier to remove and replace the lower cowl.  I want to construct an aluminum panel to cover the cowl material I removed.  Can someone tell me the distance between the rear of the cowl and the front of the cutout?  I forgot to measure it before removing material from the cowl.  Thanks..
-Rob
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Albert Gardner
PostPosted: Wed Jun 10, 2015 3:47 pm    Post subject: Nose gear leg cutout length? Reply with quote
This is what I did for my 3 bladed prop. The measurments are from the nose scoop heading aft even though the pics imply it was measured from the rear. I still have to hold the tail down to let the gear leg drop as much as possible and then protect the prop edges as I remove the lower cowl.
Albert Gardner
N991RV
Yuma, AZ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Wednesday, June 10, 2015 1:11 PM
To: rv10-list
Subject: Nose gear leg cutout length?
-Rob
Rob Kochman
Woodinville, WA
 Filesize:  438.83 KB
 Viewed:  3195 Time(s)
 Filesize:  419.21 KB
RV-9A N872RV
RV-10 N991RV
PostPosted: Wed Jun 10, 2015 5:34 pm    Post subject: Nose gear leg cutout length? Reply with quote
Awesome... thank you!
On Wed, Jun 10, 2015 at 4:43 PM, Albert <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
Albert Gardner
N991RV
Yuma, AZ
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kochman
To: rv10-list
Subject: RV10-List: Nose gear leg cutout length?
-Rob
Rob Kochman
Woodinville, WA
Rob Kochman
Woodinville, WA
