dlm34077
rvdave
Posted: Sat Jun 13, 2015 4:22 pm Post subject: Re: baggage area and CG |
What do you have for your rear battery?
_________________ Dave Ford
Cadillac, MI |
Lenny Iszak
Posted: Sat Jun 13, 2015 4:45 pm Post subject: Re: baggage area and CG |
Temperatures on the firewall are not very friendly to the battery. I measured them using thermocouple probes and don't remember the exact numbers but it was in the 170-180s just before takeoff. Much less in flight. After shutdown it gets really toasty in there for a few minutes. I would check on that battery occasionally to make sure it still holds its rated capacity.
Kelly McMullen
Posted: Sat Jun 13, 2015 8:41 pm Post subject: baggage area and CG |
Who are you asking? I think Dave has two PC680s, which seem to be perhaps slightly more popular than the single PC925L. I don't recall anyone using the plans recommended RG25XC.
On Sat, Jun 13, 2015 at 5:22 PM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=443470#443470
FORUMS -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sat Jun 13, 2015 9:22 pm Post subject: baggage area and CG |
Many people are using the RG25XC. It's a good battery and fits stock. Seldom do I have a problem with them.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Sent from my iPad
On Jun 13, 2015, at 11:38 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Who are you asking? I think Dave has two PC680s, which seem to be perhaps slightly more popular than the single PC925L. I don't recall anyone using the plans recommended RG25XC.
| Quote: | --> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
FORUMS -
b Site -
List"">http://www.matronics.com/Navigator?RV10-List
rvdave
Posted: Sun Jun 14, 2015 3:04 pm Post subject: Re: baggage area and CG |
| Quote: | | I have added a 680 on the firewall as aux battery for the avionics. This allows powering the avionics separately from the starting battery until the engine is running. Then the alternator recharges the starting battery and trickle charges the avionics battery on the firewall. The firewall battery is insulated and is used to improve W&B characteristics |
Just wondering if the starting battery is a 680 also, that's what I'm considering doing and wondered about its starting capacity in this configuration or do you have option for joining the two batteries?
...Also from PC680 info website-
The PC680MJT (MJ=Metal Jacket), means the battery is housed in a metal jacket. This enables the battery withstand higher ambient temperatures. The PC680MJ is rated to withstand temperatures of 176 degrees Fahrenheit vs. the standard PC680 is rated at 140 degrees Fahrenheit.
I will be adding a Y off the rear baffle to direct air on the firewall battery and air shutter while reducing hot air to tunnel area. Although this won't help shutdown temps the metal jacket and other insulation should assist with that.
Cadillac, MI |
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Mon Jun 15, 2015 10:21 am Post subject: baggage area and CG |
I agree with Lenny. I was planning on putting a battery on the FW, and after Lenny collected the temp data for me, I ended up mounting an EarthX battery in the stock location.
On Sat, Jun 13, 2015 at 7:45 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
[quote]--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
http://forums.matronics.com/viewtopic.php?p=443472#443472
FORUMS -
b Site -
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
