KIS Designations
bakerocb
PostPosted: Thu Jul 09, 2015 3:46 pm    Post subject: KIS Designations Reply with quote
7/9/2015
Hello Fellow KIS (Pulsar) Owners, If you go to this web site:
http://www.icao.int/publications/DOC8643/Pages/Manufacturers.aspx
search the Manufacturers Code for Pulsar, and click on the photo for the KIS2 you will see a photo of N660C, my airplane.
OC
Sent: Thursday, July 09, 2015 6:21 PM
Subject: Re: KIS logo
For the FAA the document is JO 7340.2A "Contractions". It is the same as ICAO Doc 8643. On Thursday, July 9, 2015, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
The ICAO document for all aircraft designations is at: http://www.icao.int/ DOC 8643
If you go on line and search for the KIS4 and view the official photo you will see my airplane (N819PR) prominently displayed.
On Thursday, July 9, 2015, Galin Hernandez <[url=javascript:_e(%7B%7D,\'cvml\',\'galinhdz(at)gmail.com\');]javascript:_e(%7B%7D,'cvml','galinhdz(at)gmail.com');[/url]> wrote:
The official ICAO and FAA designator for the TR-4 is KIS4. This is to be used for flight plans.
punchy(at)frontiernet.net
PostPosted: Thu Jul 09, 2015 10:23 pm    Post subject: KIS Designations Reply with quote
it is a .png and appears to be an icon of some sort, by the way neight firefox nor Chrome will display it at all.
Rob
On 07/09/2015 04:45 PM, Owen Baker wrote:
[quote] 7/9/2015
OC
Keith.Miller(at)esa.int
PostPosted: Thu Jul 09, 2015 11:49 pm    Post subject: KIS Designations Reply with quote
Rob
Internet explorer 8 works (just )
....but i thought OC had a real KIS not a Pulsar Sport 150 !!!
( only joking OC/ Mark - don't react !!!)
OC question , what is the access panel below the horizontal stabilizer used
for ?
Keith ( 525hrs on KIS2 )
To: kis-list(at)matronics.com,
Date: 07/10/2015 08:25 AM
Subject: Re: KIS Designations
Sent by: owner-kis-list-server(at)matronics.com
Rob
7/9/2015
OC
as ICAO  Doc 8643.
DOC 8643
On Thursday, July 9, 2015, Galin Hernandez <javascript:_e
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
bakerocb
PostPosted: Fri Jul 10, 2015 5:44 pm    Post subject: KIS Designations Reply with quote
7/10/2015
Hello Keith, You wrote: ".....what is the access panel below the horizontal
stabilizer used
for ?"
I did not run my rudder cables all the way to the rudder horn which would
have required having one of the cables exit the fuselage side in order to
connect to the rudder horn.
Instead I created a bell crank mounted internally at the rear end of the
fuselage that the rudder cables connected to. Then I ran a pushrod
internally to connect to a modified rudder horn. Makes for a much neater,
entirely internal, arrangement.
The access panel below the horizontal stabilizer gives me access to the bell
crank and the rudder cables and push rod connections.
OC (473 hours on KIS 2)
PS to Rob: I share your frustration. I can't even bring up the photo now
using my own link that worked previously. Damn computers.
Sent: Friday, July 10, 2015 3:49 AM
Rob
for ?
Rob
7/9/2015
OC
bakerocb
PostPosted: Sat Jul 11, 2015 2:38 am    Post subject: KIS Designations Reply with quote
7/11/2015
Hello Rob, I just (6:36 AM 7/11/2015) used bing to successfully see the KIS2 picture of my plane at:
OC
Sent: Friday, July 10, 2015 2:22 AM
Rob
[quote] 7/9/2015
OC
fredorosa(at)gmail.com
PostPosted: Sat Jul 11, 2015 11:05 am    Post subject: KIS Designations Reply with quote
I can't get it with Safari.
On Sat, Jul 11, 2015 at 6:37 AM, Owen Baker <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote] 7/11/2015
OC
Rob
OC
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
kentpyle(at)iland.net
PostPosted: Fri Jul 17, 2015 3:36 pm    Post subject: KIS Designations Reply with quote
Elevator horn. Kent
