ceengland7(at)gmail.com Guest
Posted: Wed Jul 15, 2015 2:15 pm Post subject: Insulation displacement connectors???? |
Anyone know if any type of insulation displacement crimp connectors have ever been used in aircraft applications? I used hundreds (thousands?) of EA-7759 Plain B Wire Connectors, similar to http://www.ebay.com/itm/371364009928?rmvSB=true
in burglar alarm & other data cable installations, & never have had a failed connection in 3 decades (though admittedly, I was stripping & twisting the wires prior to crimping). For those who haven't seen these, they have 'teeth' inside that pierce the insulation when crimped.
I'm looking at the need to 'daisy chain' several signal grounds from a single dSub pin (in this case, an intercom), and these tiny connectors really look attractive to stagger the joints over several inches of wire near the pin. I tested one by opening the closed end with a pair of pliers, running the 'trunk' wire through the connector, inserting the 'branch' wire, and crimping (no wire stripping involved). Seems to work fine in penetrating the tefzel insulation, and I can't budge the wires with a manual tug test.Â
I have no desire to do this for high current applications, but for signal wires, it sure makes an attractive package due to it's small size. Not sure about the type of insulation, but I'm pretty sure it won't spontaneously combust & drag the plane out of the sky.
Thoughts?
billp(at)wwpc.com Guest
Posted: Wed Jul 15, 2015 2:58 pm Post subject: Insulation displacement connectors???? |
Charlie,
I know splicers use to love these things but even the telco's outlawed these in the 70's (i think). I'm surprised you can even find them on eBay.
I guess you can use whatever you want to bet your life on in experimental but I'd stick with what's in common aeronautical use.
On 7/15/15 3:12 PM, Charlie England wrote:
[quote] Anyone know if any type of insulation displacement crimp connectors have ever been used in aircraft applications? I used hundreds (thousands?) of EA-7759 Plain B Wire Connectors, similar to http://www.ebay.com/itm/371364009928?rmvSB=true
Thoughts?
Posted: Wed Jul 15, 2015 5:27 pm Post subject: Insulation displacement connectors???? |
At 05:12 PM 7/15/2015, you wrote:
| Quote: | Anyone know if any type of insulation displacement crimp connectors have ever been used in aircraft applications? I used hundreds (thousands?) of EA-7759 Plain B Wire Connectors, similar toÂ
in burglar alarm & other data cable installations, & never have had a failed connection in 3 decades (though admittedly, I was stripping & twisting the wires prior to crimping). For those who haven't seen these, they have 'teeth' inside that pierce the insulation when crimped |
Suggest you use bussed d-sub connectors
http://tinyurl.com/nzm3e2f
I've got some bussing boards available if
you want them.
Bob . . . [quote][b]
Posted: Thu Jul 16, 2015 4:54 am Post subject: Insulation displacement connectors???? |
Outlawed in the '70s? Maybe so on that particular connector, but I've watched AT&T techs use http://www.specialized.net/Specialized/3M-Scotchlok-IDC-UR2-Connectors-1926-AWG-100Pk-4051.aspx
as recently as a few weeks ago.Â
I appreciate the 'be safe' sentiment, but 'bet your life' on the signal wires in an intercom? Isn't that a bit of a knee-jerk reaction to anything unfamiliar? If I'm not mistaken, this list came out of the desire to find products and techniques that are *not* 'in common aeronautical use', so we can improve on the products and/or techniques. We wouldn't have composite airframes (or even aluminum ones) if someone hadn't been the 1st to use something that was not 'in common aeronautical use'.
It would be more helpful to me if you could say something at least marginally quantified, like, 'That terminal fails in 0.05% of connections, vs a 0.00004% failure rate for PIDG terminals'.
On Wed, Jul 15, 2015 at 5:57 PM, Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)> wrote:
[quote] Charlie,
| Quote: | Anyone know if any type of insulation displacement crimp connectors have ever been used in aircraft applications? I used hundreds (thousands?) of EA-7759 Plain B Wire Connectors, similar to http://www.ebay.com/itm/371364009928?rmvSB=true
Thoughts?
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
Posted: Thu Jul 16, 2015 5:10 am Post subject: Insulation displacement connectors???? |
On Wed, Jul 15, 2015 at 8:25 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
 you want them.
Thanks, Bob; I've already got one of those dSub avionics GND busses mounted in the plane. My specific application for those crimps is the signal ground terminal in a DRE intercom (it has two ground pins in the 25pin dSub which are electrically common internally). My intent was to run one of the gnd pins to the avionics GND bus and the other to the gnd terminals of the various inputs/outputs (mic, headset, music, etc) to the intercom. The crimps would have been used to bring the various signal ground wires to within the 1st few inches of dSub connector on the DRE.
Would it work as well to just take all those signal grounds to the avionics dSub ground bus? I was trying to take the signal grounds directly to the intercom to keep ground loop possibilities to an absolute minimum, and an additional dSub bus for just 3 or 4 wires seems to be overkill (and bulky).
Posted: Thu Jul 16, 2015 6:48 am Post subject: Insulation displacement connectors???? |
I know a lot of guys have the old beans squirreled away but they tend to make noisy connections and are corrosion prone. The Scotchloks are what the telco's moved to after they outlawed the beans.
I take things about my airplane very seriously. If nothing else I use the "How stupid would I feel" rule. Like how stupid would I feel if my intercom quit on short final to a busy towered airport in marginal weather because I didn't take the time to strip the wires and use the right connectors?
It's a human factors thing. People can handle about 3 things going wrong before they completely unravel. If the weather suddenly gets bad you can turn around and go the other way, add strong winds in that reverse direction now depleting your fuel faster than you planned. If the intercom goes out and you can't contact Flightwatch or ATC to find out where the closest open airport is and you've got a real problem It wouldn't have been a big problem in CAVU but this day it's the third thing. I don't mean to say that every shortcut you take is going to kill you but you never know what the third thing is going to be.
There are old pilots and there are bold pilots but there are very few old bold pilots.
 On 7/16/15 05:52, Charlie England wrote:
[quote] Outlawed in the '70s? Maybe so on that particular connector, but I've watched AT&T techs use http://www.specialized.net/Specialized/3M-Scotchlok-IDC-UR2-Connectors-1926-AWG-100Pk-4051.aspx
| Quote: | Charlie,
Thoughts?
| [b]
Posted: Thu Jul 16, 2015 7:00 am Post subject: Insulation displacement connectors???? |
It would be more helpful to me if you could say something at least marginally quantified, like, 'That terminal fails in 0.05% of connections, vs a 0.00004% failure rate for PIDG terminals'. |
How about, "I used ID connectors and ribbon cable
in a pitch trim project on a Lear waaayyy back when.
At about the 15-year mark, I inquired of the field
service guys who were supporting that product. Failure
rates were pleasingly low; that product was
a fleet retrofit of about 500+ airplanes and the
pitch trim controllers came in for attention about
5x a year . . . so about 1%/year for the design.
The ID connection devices accounted for about 50% of the
service issues.
Further, that box was located in the vertical fin,
just under the leading edge of the stabilizer . . .
hence, subject to about the worst of the sheltered
environs on the aircraft.
From that experience I would deduce that while
the failure rates for ID connections were low,
they still accounted for the majority of field
failures in the design.
Keep in mind also that the teleco's and network
communities have been using ID connections for
decades . . . of course the environments are not nearly
as severe as the interior of a biz-jet's vertical fin . . .
but still subject to humidity, temperature cycles and
exposure to noxious atmosphere. It would seem that
an ID connector used with wires in the connector's
design window is a low risk venture.
Posted: Thu Jul 16, 2015 7:08 am Post subject: Insulation displacement connectors???? |
Would it work as well to just take all those signal grounds to the avionics dSub ground bus? I was trying to take the signal grounds directly to the intercom to keep ground loop possibilities to an absolute minimum, and an additional dSub bus for just 3 or 4 wires seems to be overkill (and bulky). |
The core idea for the AGB was to craft a single
point ground for all signals, power and shields.
If it's just 3-4 wires and just shields, why
not solder and heat-shrink?
In reliability studies, a connector drives up
parts count . . . a soldered joint is calculated
as the joining of several parts into one part
such that there is better than 10 to the minus
bazillion reliability. Solder and shrink is almost
never a bad idea. Is is frowned upon in the factories
because solder is a skill-driven process with tools
that burn fingers, upholstery, carpets, etc. But
for the OBAM aircraft crowd, solder should represent
no unsurmountable hazard.
edpav8r(at)yahoo.com Guest
Posted: Thu Jul 16, 2015 7:48 am Post subject: Insulation displacement connectors???? |
One additional data point. I used IDCs very similar to those in the OP's question (mine were blue and slightly smaller) to wire an alarm system in my last home in 2004. Those connections were in an attic in Phoenix, where under-roof temperatures were regularly above 120 deg F (no mechanical stress or vibration, and very low humidity). The alarm system was functioning perfectly when I sold the house in March, almost eleven years after installation.
Eric
On Jul 16, 2015, at 7:59 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] | Quote: |
service issues.
Posted: Thu Jul 16, 2015 9:58 am Post subject: Insulation displacement connectors???? |
On July 16, 2015 10:05:36 AM CDT, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
Solder/shrink is what I've done in other places, so that's no problem. But a 10 second operation vs a 10 minute one surely is tempting.
dlj04(at)josephson.com Guest
Posted: Thu Jul 16, 2015 11:01 am Post subject: Insulation displacement connectors???? |
In a word, no. B connectors are ugly, but work well given two
conditions: (a) DC sealing current to re-establish connection when
compromised by oxidation, and (b) no vibration. The later jelly-B
connectors try to solve the oxidation problem by immersing the pierces
wire in vaseline to keep air out. Not in my airplane.
