ward.t(at)xtra.co.nz Guest
Posted: Tue Sep 08, 2015 1:43 pm Post subject: Vacuum Pump Blank |
Hi all,
I am changing from Analog to EFIS for my flight instruments and will have to remove my vacuum pump from the Rotax 912s engine. Has anyone got a blank that covers the connection of the pump to the engine?
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
Rick Moss
Posted: Sat Sep 12, 2015 2:51 am Post subject: Re: Vacuum Pump Blank |
I believe that you can simply remove the vac pump; you will still have a rotatiing shaft sticking out of the rear of the gearbox, but that should pose no issue?
Posted: Sat Sep 12, 2015 4:48 am Post subject: Vacuum Pump Blank |
Thanks Rick.
Must look at the manuals.
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
| Quote: | On 12/09/2015, at 10:51 pm, Rick Moss <Rkwmoss(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=447018#447018
Posted: Sat Sep 12, 2015 4:49 am Post subject: Vacuum Pump Blank |
Thanks Rick.
Haven't looked at the removal yet nor the manuals so that would be excellent.
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
paul.the.aviator(at)gmail Guest
Posted: Sat Sep 12, 2015 5:30 am Post subject: Vacuum Pump Blank |
Tim, I just made a flat cover out of aluminum when I removed mine. - Paul
europapa
Posted: Sat Sep 12, 2015 9:19 am Post subject: Re: Vacuum Pump Blank |
years ago I removed the vacuum pump too and made a cover out of 4mm PTFE.
Simple.
