paulf(at)ncsu.edu Guest
Posted: Mon Jan 16, 2006 1:38 pm Post subject: Gascolotor |
I was changing the oil on Sunday in my RV-4, and my "assistant" noticed gas
pouring out of my gascolator when I ran the electric fuel pump. The fuel
pump is in the cockpit (behind the battery) and the gascolator is on the
pressure side of the pump, which is most likely not where it is meant to be.
Question is what should I do? It seems to me that the easiest thing would
be to change the gascolator to one that can take the pressure. Looking at
Aircraft Spruce, there seems to be two candidates that seem to claim they do
- Andair and Usher. I can't tell much from the photos in the catalog. The
Andair is 2x the price of the Usher, but I can't tell if the Usher has a
sump drain sample valve.
Any suggestions or experience, please?
Paul D. Franzon
N418GM
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
Lenleg(at)aol.com Guest
Posted: Mon Jan 16, 2006 1:49 pm Post subject: Gascolotor |
I have the Andair ... had one small problem ... had a pin size hole in the
bottom and when I turned on the pump .. gas sprayed out ...
Had the hole closed by a professional ... no problems since.
Len
In a message dated 1/16/2006 4:38:59 PM Eastern Standard Time,
paulf(at)ncsu.edu writes:
Paul D. Franzon
N418GM
bill28104(at)yahoo.com Guest
Posted: Mon Jan 16, 2006 2:21 pm Post subject: Gascolotor |
Paul, sounds like the gasket just went bad. you can
get a new screw-in fuel poppet and replace current one
and prob. be fine...i did that some yrs. back. bill c
--- "Paul D. Franzon" <paulf(at)ncsu.edu> wrote:
fuel pump. The fuel
Paul D. Franzon
N418GM
browse
Subscriptions page,
FAQ,
Admin.
Steve Glasgow
Posted: Mon Jan 16, 2006 2:24 pm Post subject: Gascolotor |
I have the ANDAIR and have had no problems.
Cappy
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
sportav8r(at)aol.com Guest
Posted: Mon Jan 16, 2006 2:29 pm Post subject: Gascolotor |
I have no gascolator and have had no problems.
Stormy
libertyva(at)msn.com Guest
Posted: Mon Jan 16, 2006 3:34 pm Post subject: Gascolotor |
Bill,
What is a "fuel poppet" ????
Paul,
I had the same thing happen after servicing the gascolator........scared the
poop out of me, seeing fuel spray out.......so glad we did a systems check
before run up.......
now I'm not an A&P......but I know how to service a gascolator (from tractor
days)
but I found after close inspection the gasket is very susceptable to being
pushed to the inside of the cup. I always keep new gaskets on hand to
replace worn ones.......this one didn't look worn, so I didn't replace
it.......but I replace then every time now.
I have a carb to ..........and the gascolator is suposed to handle the fuel
pressure........
I have agree.......the andair looks very good to me........
but I have admit.......I kinda agree with Stormy toooo......I think it can
cause more possible harm then the little good it is doing.
Thats why they call it EXPERMENTAL........
Good Luck.
Bob Martin
RV-6
Louisa Va
Bill
| Quote: | From: bill crothers <bill28104(at)yahoo.com>
Reply-To: rvsoutheast-list(at)matronics.com
Subject: Re: RE: Gascolotor
Date: Mon, 16 Jan 2006 14:20:57 -0800 (PST)
> fuel pump. The fuel
> Paul D. Franzon
> N418GM
> browse
> Subscriptions page,
> FAQ,
> Admin.
Posted: Mon Jan 16, 2006 4:19 pm Post subject: Gascolotor |
Thanks everyone. I am still concerned about having a regular gascolator on
pressure side of a pump. I might go ahead and replace it with the Andair,
since it specifically states it can go on the pressure side.
BTW, I used to not have a gascolator too. After a few problems with water
contamination, my A&P suggested we put one in.
Paul D. Franzon
Alumni Distinguished Professor of ECE
443 Monteith GRC
paulf(at)ncsu.edu 919.515.7351 fax. 919.515.2285
www.ece.ncsu.edu/erl/faculty/paulf.html
USPS : ECE Box 7914, NCSU, Raleigh NC 27695
FedEx: EGRC 419, 2410 Campus Shore Dr., Raleigh NC 27606
sawad13(at)msn.com Guest
Posted: Mon Jan 16, 2006 5:36 pm Post subject: Gascolotor |
My RV-4 has a gascolator on the pressure side of the pump and I have had no
problems. Don't know what brand it is, but it looks to be one of the cheaper
ones.
I sump the tanks after every fill up and before the next flight if the plane
sat for a day or two. I only check the gascolator when I change the oil
since it is very hard to get under the cowling to sump it and also the fuel
pump has to be running as well to get much out of it.
Ron Awad
[quote]From: "Paul D. Franzon" <paulf(at)ncsu.edu>
To: <rvsoutheast-list(at)matronics.com>
Subject: RE: RE: Gascolotor
Date: Mon, 16 Jan 2006 19:19:24 -0500
Paul D. Franzon
443 Monteith GRC
Can't think of REAL name, but its same as gizmo where
you ck. fuel under wing.
--- BOB martin <libertyva(at)msn.com> wrote:
Bill,
Paul,
days)
gaskets on hand to
so I didn't replace
pressure........
me........
doing.
Good Luck.
Bob Martin
RV-6
Louisa Va
Bill
can
one
bill c
my
electric
> > fuel pump. The fuel
the
not
that
the
candidates
> > Paul D. Franzon
> > N418GM
> > browse
> > Subscriptions page,
> > FAQ,
> > Admin.
browse
Subscriptions page,
FAQ,
Admin.
vitez(at)carolina.rr.com Guest
Posted: Mon Jan 16, 2006 5:44 pm Post subject: Gascolotor |
Quick drain (part # CAV-110)?
Posted: Mon Jan 16, 2006 5:46 pm Post subject: Gascolotor |
bill crothers wrote:
quick drain?
Posted: Mon Jan 16, 2006 5:51 pm Post subject: Gascolotor |
yeah Rad, thats it...
--- Radomir Zaric <vitez(at)carolina.rr.com> wrote:
Zaric" <vitez(at)carolina.rr.com>
tannerav8(at)earthlink.ne Guest
Posted: Mon Jan 16, 2006 7:37 pm Post subject: Gascolotor |
Paul,
I have an Andair that I am not going to use, I was going to put it on my 8,
but I am fuel injected and don't need it now. It is new in the box, let me
know if you want it.
Scott Tanner
tannerav8(at)earthlink.net
