Roland
Posted: Tue Oct 13, 2015 2:48 am Post subject: Heavy duty starter for Rotax 914? |
Hi all,
since I'm planning to move (the much lighter) LiFePo battery
http://www.accu-24.de/ALIANT-LiFePO4-Ultralight-Battery-X4-13-2-V-92-Ah from the baggage compartment onto the right footwell and having to change the Rotax sprug clutch this winter (lots of kick backs on starting), I'm also thinking about installing a heavy duty starter like this one http://silent-hektik.com/UL_912_Anlasser.htm .
I seem to remember, that it's most advisable to retrofit it on the 912 S with its higher compression.
Did anyone of you install such a heavy duty starter on the 912 or 914 or is it just overkill for this engine?
Roland
PH-ZTI
Europa XS TG 914
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Tue Oct 13, 2015 3:03 am Post subject: Re: Heavy duty starter for Rotax 914? |
Hi Roland.
Get the Soft start model, from Con Air.
Problem solved.
Alan
Roland
Posted: Tue Oct 13, 2015 3:44 am Post subject: Re: Heavy duty starter for Rotax 914? |
Hi Alan,
I watched the Bully Hawk Video - also a good idea to cure the kick back, but one also needs to deactivate one ignition circuit on starting to get the best results.
I'll also consider this - thanks.
Roland
Alan Carter
Posted: Tue Oct 13, 2015 7:12 am Post subject: Re: Heavy duty starter for Rotax 914? |
Hi, Roland.
I take it you have a Key ignition switch and not two separate on and off switches.
If so you can still use the same switch as L and R mag, and Both.
All you need do is deactivate the starter position and take those wires to a separate Starter Button.
Job Done.
The Soft Start then takes about 20 minutes to fit.
Its an easy job to do.
Alan
Guy Buchanan
Posted: Tue Oct 13, 2015 8:49 am Post subject: Heavy duty starter for Rotax 914? |
Or you can disable the hard start module by routing it through a switch
you'll keep off when you start. In my case it was avionics power, which
I don't switch on until after start. Once started I switch on the
avionics, which also activates my B, non soft start, module. That
allowed me to use my existing key switch as before. It also allows me to
kill the B module before I shut down, which helps as well.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again.
Now a glider pilot, too.
On 10/13/2015 8:12 AM, Alan Carter wrote:
Hi, Roland.
Job Done.
Alan
http://forums.matronics.com/viewtopic.php?p=447882#447882
Deceased K-IV 1200
A glider pilot too. |
brian.davies(at)clara.co. Guest
Posted: Tue Oct 13, 2015 9:52 am Post subject: Heavy duty starter for Rotax 914? |
So does that mean if you switch off the avionics master because you have an
electrical fault that you lose one of your ignition systems? Hm...
Brian Davies
Guy Buchanan
Posted: Tue Oct 13, 2015 11:28 am Post subject: Heavy duty starter for Rotax 914? |
Yes it does, but my avionics are simple in the extreme and very unlikely
to catch fire. Any shorts should be handled by the fuses. Not optimal, I
know, but best I could do without a major rework. (The install was a
retrofit.)
Guy
Brian Davies
Deceased K-IV 1200
Roger Lee
Posted: Tue Oct 13, 2015 4:02 pm Post subject: Re: Heavy duty starter for Rotax 914? |
This starter is longer and depending on your engine mounts may be too long.
Some who have used after market starters have had oil leak back into them due to bad seals.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
